300 Disco Air-con
Pondering fitting aircon into my disco...I can get the bits fairly readily (300 disco in the scrappy down the road from me, with all the bits :D )
The question is this....do I need the air mixer thingy as well? Or does my non-air con version have the holes for the evaporator to fit? The donor disco has already had this swiped...although the evaporator is left.
After seeing exactly how much the two systems differ (everything....) I don't think I could fit a rangie system very easily - it would be a major challenge just making the pump work, and then i've got all the behind dash issues to deal with. You can't even mix and match bits of systems as all the pipe fittings are different.
Sorry...
