candpdoyle Posted April 14, 2007 Share Posted April 14, 2007 Hi There Just realised the other night that my glow plugs are not working. Have recently fitted the sherpa lump and sort of dimly remember someone saying they are wired up without the balast resister?? The engine starts fine and will only smoke on colder mornings so is not a train smash, but i would like to wire them up properly if anyone can talk me through or even better has some pics Cheers in advance Chris Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted April 14, 2007 Share Posted April 14, 2007 Put the wire from the back heater plug to the starter switch side of the old ballast resistor, the warning light wire(thin one) that was also on the opposite end of the resistor to the starter switch wire wants to go on the resistor mounting bolt to earth it and change the bulb from a 6V item to a 12V. Job done. Quote Link to comment Share on other sites More sharing options...
candpdoyle Posted April 15, 2007 Author Share Posted April 15, 2007 Cheers Phil As you said, job done. All seems fine. BUT, is there anyway of testing that they actualy are working as they should be? Chris Quote Link to comment Share on other sites More sharing options...
