rekab69 Posted April 21, 2007 Share Posted April 21, 2007 HI, Just bought a 2nd hand axle for my 1998 110, the one installed has a casing with tubes pressed into the diff housing and the one I bought has a one piece housing... Which is which and is it ok to go ahead and install it...? cheers Dave Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 21, 2007 Share Posted April 21, 2007 Sounds like the one you've just bought is a late Td5 type.... with a removable diff unit just like the 90's have (or like the front axles have) the other type you describe (has a casing with tubes pressed into the diff housing) is a Salisbury 8HA... like this: Both are interchangable, however the later one you've got may need a slightly longer propshaft, as i think the nose of the diff isn't as far "forward" as the salisbury ones. Quote Link to comment Share on other sites More sharing options...
