C.J. Posted April 22, 2007 Share Posted April 22, 2007 Disconnested the battery to re-align the steering wheel, and predictably the radio has gone off requiring the code to be tapped back in. The'bible' gives me all the guff on how to do it, only mine hasn't got the RR3316 that it twitters on about. The only ID I can find on mine is RDS EON. It doesn't even look like the 3316, but it does look like Rover radio of sorts. It asks me to tap in the code 6504 using the pre-set buttons. Great, only I haven't got a "0" button. Am I just being my usual stupid self, looking for the difficult solution? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 22, 2007 Share Posted April 22, 2007 On my radio (non L/R) you would have to press the No1 button repeatedly until it showed 6, thenNo2 button repeatedly on it until it showed 5 and so-on. Les. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 22, 2007 Share Posted April 22, 2007 On some you press the 1 preset so the display read 1xxx then use the up/down freq keys to set the number, press 1 again to store, then do the second number with < > keys press 1 to store then the third etc etc Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted April 30, 2007 Share Posted April 30, 2007 ...It asks me to tap in the code 6504 using the pre-set buttons. Great, only I haven't got a "0" button. Which Radio Cassette does your car have? For the Phillips item fitted to early Rovers, the sequence is as follows. 1) Switch on Radio: 'CODE' should appear in the display. 2) Press either up or down tuning buttons until the first digit of the four digit code appears. Press pre-set button 1 to store. 3) Use tuning up-down button to select 2nd digit - press pre-select button 1. 4) Use tuning up-down button to select 3rd digit - press pre-select button 1. 5) Use tuning up-down button to select 4th digit - press pre-select button 1. The beep should sound and the radio function. Quote Link to comment Share on other sites More sharing options...
