Brake Warning Light
off the top of my head, the light will only come on if the fluid level is down (or the sender is faulty), or if the shuttle value that connects the 2 braking curcuits moves - meaning one circuit is low in pressure. You may not have a shuttle valve fitted.
Is the peddle ok? Any leaks?
On the top of reservoir cap you'll have the contacts for the float switch, two female spades on the ends of the wires. remove this and check for good contact.
I had a similar problem, topping up the reservoir ultimately solved it, couldn't find where the fluid had gone though!!
..or maybe short and see if the light goes out?
