Hybrid_From_Hell Posted April 29, 2007 Share Posted April 29, 2007 Er For a mate He has a very much modified Suzuki, and I am posting this in the hope someone can help him with the Q He has a set of white 8 spokes / Grizzly claw tyres, these have more "Offset" than std wheels (they are also wider as well) but he wants MORE Offset - ie wheels moving away from axle MORE, ..............and we are looking at the old "Grind bash and reweld the centres up" Work BUT............. Was wondering if anyone here knows of any rims new or secondhand which will fit on a SJ 413 axle with more offset than a 8 spoke, which would be a whole lot less work. ?? Nige Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted April 29, 2007 Share Posted April 29, 2007 If you grab a set of early SJ410 rims (with the drum brake adjuster hole in the rim front and rear) they were designed to go on either way so will give you Large offset Also late leafer Fourtrack eight spokes will fit Quote Link to comment Share on other sites More sharing options...
nas90 Posted April 29, 2007 Share Posted April 29, 2007 My SJ410 had Rhino Ray rims with larger offset, he still does an exchange service at £30/rim go here http://www.rhinorays.co.uk/wheels.htm Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted April 29, 2007 Share Posted April 29, 2007 i had rhinoray rims, all he does is cut out the centre and reweld but his welding is spot on Quote Link to comment Share on other sites More sharing options...
portal pete Posted April 29, 2007 Share Posted April 29, 2007 i found the cheapest any easyest way was a set of spacers, 30mm are about £60 a set Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 29, 2007 Author Share Posted April 29, 2007 i found the cheapest any easyest way was a set of spacers, 30mm are about £60 a set Yes but "banned" both MSA and AWDC over 25mm Nige Quote Link to comment Share on other sites More sharing options...
