Les Henson Posted May 1, 2007 Share Posted May 1, 2007 I've been trying to source a steering linkage for the PAS conversion on catflap. I have been offered this item for £10, but the part number on it says QMR100080, which is not a known number. The whole assembly is Alluminium and the shaft is triangular in shape. Any idea what it's off please? Les. Quote Link to comment Share on other sites More sharing options...
MogLite Posted May 1, 2007 Share Posted May 1, 2007 Les 300TDI Disco - circa P-reg I used one on MogLite They are quite easy to shorten - if that makes the conversion easier Hope it helps Andy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 1, 2007 Author Share Posted May 1, 2007 That's great - thanks Andy. Ralph - <smack> Les. Quote Link to comment Share on other sites More sharing options...
Tonk Posted May 1, 2007 Share Posted May 1, 2007 ali ones are also used on 300 tdi defenders. Les, the conversion you are doing, if you use a rangie one its the right length Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 1, 2007 Share Posted May 1, 2007 For £10 I'd have it for spares if the UJ's are OK whether the shaft was right or not. The top half looks the same as the defender bit I used. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 1, 2007 Author Share Posted May 1, 2007 You wouldn't happen to know if the one I have is too short would you Fridge? The one I have is max 50cm, although I could squeeze another 8mm on top with a bit of filing. Les. Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2007 Share Posted May 1, 2007 That's great - thanks Andy.Ralph - <smack> Les. Not my fault the number doesn't come up in EPC, it's a newer number than my 2002 EPC so Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 2, 2007 Share Posted May 2, 2007 I've got one as well Les, i bought it at billing a year or 3 back, hopeing to use it on my 90 when the UJ's clagged out, but the one i got wasn't from a defender, it's too short (i think it's short, either way it's wrong) Quote Link to comment Share on other sites More sharing options...
