jules Posted May 2, 2007 Share Posted May 2, 2007 I am trying to bleed the brakes and the sodding thing will not bleed up properly. RRC LSE Have I got the process right. Near side outer front off side outer front Near side inner front off side inner front near side rear off side rear. or have I got it wrong.... Quote Link to comment Share on other sites More sharing options...
Jon White Posted May 2, 2007 Share Posted May 2, 2007 Jules - has it got ABS? If so the procedure is totally, totally different! Quote Link to comment Share on other sites More sharing options...
jules Posted May 2, 2007 Author Share Posted May 2, 2007 Yep it has ABS Do tell what have I done wrong Quote Link to comment Share on other sites More sharing options...
western Posted May 2, 2007 Share Posted May 2, 2007 (edited) ABS fitted ------ refer to attachment HTH File0014.pdf Edited May 2, 2007 by western Quote Link to comment Share on other sites More sharing options...
Jon White Posted May 2, 2007 Share Posted May 2, 2007 Jules, PM me an email address and I'll email the relevant section of the manual over. I've had to do mine recently and even following the manual I had to do it twice to get all the air out! Its a piggy! Cheers Jon Quote Link to comment Share on other sites More sharing options...
Corrode Finger Posted May 2, 2007 Share Posted May 2, 2007 Aha, I am having similar issue with the ABS on my hybrid, cant get rid of all the air. Jules, If you work out how to do this, could i pop over to see you, as you are only a mile away? Bit cheeky i know, but it would be good to share the knowledge, if thats ok? Quote Link to comment Share on other sites More sharing options...
Jon White Posted May 2, 2007 Share Posted May 2, 2007 Hahahahahahah see Ralph's post above! Thats the way to do it! You'll need an assistant and my advice is to follow the manual TO THE LETTER!!! Also make sure your battery is charged up cos I found it soooooooo frustrating to get halfway through doing it, only for the battery to go flat so the sodding pump wouldnt run!! Jon Quote Link to comment Share on other sites More sharing options...
jules Posted May 3, 2007 Author Share Posted May 3, 2007 PM sent thanks so much Quote Link to comment Share on other sites More sharing options...
western Posted May 3, 2007 Share Posted May 3, 2007 Good luck with bleeding that ABs system, seems a very long job just reading about it Quote Link to comment Share on other sites More sharing options...
