TheBeastie Posted May 6, 2007 Share Posted May 6, 2007 Hi I have always had a bit of a leak into the back but it seems to have got worse. From what I can make out it seems to be coming in just a bit behind the drivers seat through what looks like a black sort of foam seal that runs around the side about the height of the rear bulkhead. This morning there was a fair sized puddle on the rubber mat between the wheel arches - possibly half a pint or so. I am in the process of panelling the back so it is probably a good idea to sort it now whilst I am still in process. Do I need to take off the top and replace the whole seal or could I put a bead of some silicone type sealant all along the gap? If I have to to the whole thing, how big a job is it? If a sealant bead what is best product to use since the ones you use in bathrooms give off a strong acetic acid smell which I suspect is not good for aluminium panels. Any guidance would be most appreciated Best wishes Malcy Quote Link to comment Share on other sites More sharing options...
Gromit Posted May 6, 2007 Share Posted May 6, 2007 I had the same problem on my CSW. I just ran silicone sealant along the outside of the rubber. Use washing up liquid on your fingers to smooth into position. Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted May 6, 2007 Author Share Posted May 6, 2007 Thanks Gromit Did you just use bog standard B&Q silicone as per bathrooms etc? Malcy Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted May 6, 2007 Share Posted May 6, 2007 Just drill a couple of holes in the floor, problem solved. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 6, 2007 Share Posted May 6, 2007 I thought it was a service Land Rover invented to clean the soles of your boots.... I've been dead impressed..... Quote Link to comment Share on other sites More sharing options...
Gromit Posted May 8, 2007 Share Posted May 8, 2007 Did you just use bog standard B&Q silicone as per bathrooms etc? yep, the clear stuff. While in French thunderstorms, the sunroof was leaking like a sieve. During a few hours of sunshine, all I could find was the white stuff, and I lashed it all over the sunroof seals. Looks a mess, but it worked, sortof Someday, I'll be arsed to take the lights and roofrack off and sort it properly. Quote Link to comment Share on other sites More sharing options...
