andywood Posted May 8, 2007 Share Posted May 8, 2007 Hi, the ABS light is on, replaced ecu initially worked fine for first trip, then light back on. Read code 2-3, cant find any details on what this code means. Does anyone know what this code means. Other brake light also stays on for 30 seconds when RR first started. The range rover is a 1990 vogue SE 3.9. Any help would be appreciated. Cheers Andy Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted May 8, 2007 Share Posted May 8, 2007 Hi,the ABS light is on, replaced ecu initially worked fine for first trip, then light back on. Read code 2-3, cant find any details on what this code means. Does anyone know what this code means. Other brake light also stays on for 30 seconds when RR first started. The range rover is a 1990 vogue SE 3.9. Any help would be appreciated. Cheers Andy Well this doesn't give that code. I would say start by clearing the code and see if it reappears, but replacing the ECU ought to take care of that... I guess it eliminates the ECU itself from your enquiries, too. I can't find any record of what 2-3 means either Quote Link to comment Share on other sites More sharing options...
