FridgeFreezer Posted May 9, 2007 Share Posted May 9, 2007 As the title says really - I know there are quite a few of you out there running MS'n'S / MS'n'EDIS so can anyone help me out with a fuel/spark map suitable for a 4.6 + EDIS to save me a bit of pratting about with mine? I'm looking forward to firing it up - there's no exhaust beyond the headers & Y-piece at the moment Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 9, 2007 Share Posted May 9, 2007 Does it have a new cam and lifters....... ? If yes............ then you need to run it at 2500 rpm for 20 minutes to correctly bed the cam and lifters together........... at no time during the 20 min period should it be allowed to run below 2000 rpm............. I can put together a VE & spark map for you ion the morning that will work OK and send via email ........................ Ian Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 10, 2007 Author Share Posted May 10, 2007 Does it have a new cam and lifters....... ? Yes it does have a new (stump puller) cam & lifters - are you serious about revving it for 20 mins? The neighbors next door won't mind but the rest of the street might Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 10, 2007 Share Posted May 10, 2007 Yes, I’ll post up the relevant cam manufacturer docs tomorrow……………… Ian Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 10, 2007 Author Share Posted May 10, 2007 Gawd I'm gonna need to buy more petrol then Not to mention wire the fans & plumb the rad in properly, tch Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 10, 2007 Share Posted May 10, 2007 I’m fairly sure your stump puller is a comps cams special …….. ground up for RS ……… Comp Cams…………………taken from here Comp.pdf Camshaft Break-in Procedure Important: On hydraulic and mechanical (solid) flat tappet cams that require dual valve springs, the inner spring must be removed during break-in. This allows the lifters to establish rotation and develop a good wear pattern. As soon as the engine fires, bring the RPM up to 2000 to 2500 during the first 30 minutes of operation. Slower engine speeds will not supply the camshaft with an adequate amount of oil for the break-in period. The engine RPM may be varied periodically between 2000 to 2500 to direct oil splash different areas of the camshaft. After the 30 minute break-in period, change the oil and filter again to be sure all contaminants and break-in lube are remove from the engine. The inner valve springs can now be replaced. Then we have the Crane cams Flat Tappet Break in procedure ………… Crane.pdf I've got another from Piper somewhere here but its being a bit illusive at the moment Ian Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted May 10, 2007 Share Posted May 10, 2007 Does it have a new cam and lifters....... ?If yes............ then you need to run it at 2500 rpm for 20 minutes to correctly bed the cam and lifters together........... at no time during the 20 min period should it be allowed to run below 2000 rpm............. Ian Really Ian Never heard that one before, even if using genuine parts or just for the special toys in life? Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 10, 2007 Share Posted May 10, 2007 Rog, As you can see from the manufacturers documents it certainly applies to the new toys ………. as to whether the OEM does this, I don’t know ………… Its something that I have always been a bit particular about over the years ………. I once read a crane article about the how the correct bedding in changes the molecular structure of the steel …….. all clever stuff and some of it was quite frightening . I’ll see if I can dig out the article ……… then I can scan and post. I guess your motor is running a little better than mine at the moment ! Ian Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted May 10, 2007 Share Posted May 10, 2007 Rog,I guess your motor is running a little better than mine at the moment ! Ian Yes mate, Im feeling quite smug at the moment, but aware that it wont last for long! Although this new found wading game has cost me a starter, alternator and some weird happenings with the eleccy windows! FF, Heres the long version of mine, it might help (can email you the msq tom morn if you wish, not on my pc at the moment) <?xml version="1.0" encoding="ISO-8859-1" ?> - <msq xmlns="http://www.msefi.com/:msq"> <bibliography author="MegaTune 2.25" writeDate="2007-03-17T14:40:48+00:00" /> <versionInfo fileFormat="4.0" nPages="9" signature="MSnS-extra format 029q *********" /> - <page number="0" size="189"> <constant name="algorithm1">"Speed Density"</constant> <constant name="alternate1">"Alternating"</constant> <constant name="baroCorr1">"On"</constant> <constant name="battFac1" units="ms/v">0.10</constant> <constant name="cltType1">"Unknown3"</constant> <constant name="divider1">2</constant> <constant name="egoCount1">37</constant> <constant name="egoDelta1" units="%">0</constant> <constant name="egoIgnCount">"Ign Pulses*^"</constant> <constant name="egoLimit1" units="%">10</constant> <constant name="egoRPM1" units="RPM">1300</constant> <constant name="egoSwitch1" units="v">0.510</constant> <constant name="egoTemp1" units="C">71</constant> <constant name="egoType1">"Narrow band"</constant> <constant name="engineType1">"Even fire"</constant> <constant name="fastIdleT1" units="C">68.8</constant> <constant name="injOpen1" units="ms">1.0</constant> <constant name="injPwmP1" units="%">100</constant> <constant name="injPwmT1" units="ms">25.5</constant> <constant name="mapBins1" rows="12" units="kPa">15 20 30 40 50 60 70 80 85 90 95 100</constant> <constant name="mapSensor1">"1"</constant> <constant name="mapType1">"250 kPa"</constant> <constant name="matType1">"Unknown3"</constant> <constant name="nCylinders1">"8"</constant> <constant name="nInjectors1">"8"</constant> <constant name="reqFuel1" units="ms">11.0</constant> <constant name="rpmBins1" rows="12" units="RPM">600 1000 1500 2000 2500 3000 3500 4000 4500 5000 5400 5800</constant> <constant name="rpmk1">1500</constant> <constant name="twoStroke1">"Four-stroke"</constant> <constant cols="12" name="veBins1" rows="12" units="%">44 42 46 46 42 42 42 50 52 53 56 56 44 45 46 47 49 49 50 56 60 60 60 60 42 42 46 53 56 56 59 65 65 65 66 68 42 45 48 55 58 62 70 74 74 74 74 74 48 48 53 57 64 66 72 78 78 78 78 78 51 54 55 57 66 70 76 78 80 80 80 80 58 59 59 62 69 74 78 79 80 80 80 80 63 65 66 64 69 74 76 79 80 80 80 80 67 70 68 67 71 75 76 78 80 80 80 80 71 72 73 70 73 75 76 78 80 80 80 80 71 72 73 71 74 75 76 78 80 80 80 80 71 72 73 71 75 76 76 79 80 80 81 81</constant> </page> - <page number="1" size="189"> <constant name="TwoLambda">"None*^(DT)"</constant> <constant name="algorithm2">"Speed Density"</constant> <constant name="alternate2">"Alternating"</constant> <constant name="baroCorr2">"On"</constant> <constant name="battFac2" units="ms/v">0.10</constant> <constant name="cltType2">"Unknown2"</constant> <constant name="divider2">2</constant> <constant name="egoDelta2" units="%">1</constant> <constant name="egoLimit2" units="%">5</constant> <constant name="egoRPM2" units="RPM">1200</constant> <constant name="egoSwitch2" units="v">2.509</constant> <constant name="egoTemp2" units="C">71</constant> <constant name="egoType2">"Wide band"</constant> <constant name="engineType2">"Even fire"</constant> <constant name="fastIdleT2" units="C">71.0</constant> <constant name="injOpen2" units="ms">1.0</constant> <constant name="injPwmP2" units="%">100</constant> <constant name="injPwmT2" units="ms">25.5</constant> <constant name="mapBins2" rows="12" units="kPa">25 35 45 58 80 100 112 125 137 150 160 170</constant> <constant name="mapType2">"250 kPa"</constant> <constant name="matType2">"Unknown2"</constant> <constant name="nCylinders2">"8"</constant> <constant name="nInjectors2">"8"</constant> <constant name="primePulse2" units="ms">1.2</constant> <constant name="reqFuel2" units="ms">5.4</constant> <constant name="rpmBins2" rows="12" units="RPM">1000 1200 1500 2100 2800 3000 3500 4000 4500 5100 5800 6000</constant> <constant name="rpmk2">1500</constant> <constant name="twoStroke2">"Four-stroke"</constant> <constant cols="12" name="veBins2" rows="12" units="%">50 48 44 45 20 20 20 20 20 20 35 60 50 48 44 45 34 34 34 34 34 34 60 60 46 49 46 45 50 53 61 62 63 71 71 71 51 52 59 57 60 66 71 72 73 74 74 74 61 68 69 70 71 72 75 77 78 86 86 86 78 79 81 82 82 83 88 89 89 89 89 89 85 94 96 98 99 99 107 108 109 109 109 109 85 94 96 100 103 107 114 116 117 117 117 117 85 94 96 101 104 107 118 120 121 121 121 121 85 94 96 103 106 109 118 121 123 123 123 123 85 94 96 105 108 111 119 122 125 125 125 125 85 94 96 105 108 115 119 126 129 129 129 129</constant> </page> - <page number="2" size="189"> <constant name="CrankAng" units="Deg">10</constant> <constant name="FixAng" units="Deg">-10</constant> <constant name="IdleAdv" units="Deg">-10</constant> <constant name="IdleAdvCLT" units="C">-40.0</constant> <constant name="IdleAdvRPM" units="RPM">500</constant> <constant name="IdleAdvTPS" units="ADC">0</constant> <constant name="IdleDelayTime" units="sec">1</constant> <constant name="IgHold">0</constant> <constant name="IgInv">"Yes"</constant> <constant name="Stg2ndParmDlt" units="kPa">0</constant> <constant name="Stg2ndParmKPA" units="kPa">0</constant> <constant name="StgCycles" units="cycles">25</constant> <constant name="TrigAng" units="Deg">60</constant> <constant name="TrigCrank">"Time Based"</constant> <constant name="Trig_plus">"0"</constant> <constant name="Trim" units="Deg">0</constant> <constant cols="12" name="advTable1" rows="12" units="deg">8 8 13 21 25 27 29 33 37 37 41 41 8 8 13 21 24 27 29 33 37 37 41 41 8 8 13 21 24 26 29 33 37 37 39 39 8 8 12 20 24 26 29 32 37 37 38 39 8 8 12 20 23 26 29 32 36 37 39 39 8 8 12 19 23 26 29 31 36 36 38 39 8 8 11 19 22 25 29 31 36 36 37 39 8 8 11 18 22 25 28 31 35 35 37 37 9 9 11 18 21 25 28 30 35 35 37 37 9 9 11 17 20 24 28 30 32 32 32 32 8 8 11 17 20 24 27 30 32 32 32 32 8 8 10 17 20 24 27 30 32 32 32 32</constant> <constant name="mapBins3" rows="12" units="kPa">20 25 30 35 40 45 50 55 60 70 80 100</constant> <constant name="oddfire">"No"</constant> <constant name="rpmBins3" rows="12" units="RPM">500 800 1000 1200 1500 2000 2200 2500 3000 4200 5000 6000</constant> <constant name="spare3_182">150</constant> <constant name="spare3_183">140</constant> <constant name="spare3_184">130</constant> </page> - <page number="3" size="189"> <constant name="AFMUse">"No AFM *^"</constant> <constant name="AccDecEnrich">"TPSdot*^(DT)"</constant> <constant name="AccelMapASE">"Normal*^"</constant> <constant name="AfrTar">"Off*^(DT)"</constant> <constant name="AfrTar2">"Off*^(DT)"</constant> <constant name="AirCorAFM">"Use IAT"</constant> <constant name="AlphBaroCor">"No"</constant> <constant name="BarroHi" units="KPa">105</constant> <constant name="BarroLow" units="KPa">90</constant> <constant name="BooTbl2Use">"Targets 2"</constant> <constant name="BoostDir">"Increase boost"</constant> <constant name="BoostMaxKn" units="KPa">0</constant> <constant name="CltAdv">"On"</constant> <constant name="ConsBarCor">"Not Fitted*^"</constant> <constant name="DecayAcPoint" units="mS">0.0</constant> <constant name="DecayAccel">"Decay"</constant> <constant name="DecelBoost">"Above KPa Setpoint"</constant> <constant name="DecelKPa" units="kPa">75</constant> <constant name="DtNos">"Bank1"</constant> <constant name="EgoLim2" units="+-">5</constant> <constant name="EgoLimKPa" units="KPa">90</constant> <constant name="HCutLCSpark" units="Sparks">3</constant> <constant name="HCutLCType">"Fuel Only"</constant> <constant name="HCutSpark" units="Sparks">3</constant> <constant name="HCutType">"Spark Cut Only"</constant> <constant name="HardRevLim" units="rpm">6300</constant> <constant name="IATBoost" units="C">141.5</constant> <constant name="IATBoostSt" units="C">99.9</constant> <constant name="IStagedMode">"Off*^"</constant> <constant name="IatAdvKpa" units="KPa">80</constant> <constant name="IgAdvDeg" units="C">10.0</constant> <constant name="IgAdvTemp" units="C">54.9</constant> <constant name="IgRetDeg" units="C">10.0</constant> <constant name="IgRetTemp" units="C">45.0</constant> <constant name="InvOut1">"Normal"</constant> <constant name="InvOut2">"Normal"</constant> <constant name="KPaDotBoost">"Never"</constant> <constant name="KPaOn" units="KPa">85</constant> <constant name="KPaTarg10" units="KPa">6</constant> <constant name="KPaTarg100" units="KPa">33</constant> <constant name="KPaTarg40" units="KPa">15</constant> <constant name="KPaTarg60" units="KPa">24</constant> <constant name="KnockAdv" units="Deg">1</constant> <constant name="KnockBoost" units="KPa">0</constant> <constant name="KnockKpa" units="KPa">100</constant> <constant name="KnockMax" units="Deg">3</constant> <constant name="KnockOn">"Off"</constant> <constant name="KnockRet" units="Deg">2</constant> <constant name="KnockRpm" units="RPM">5700</constant> <constant name="KnockRpmL" units="RPM">2000</constant> <constant name="KnockSb" units="Deg">1</constant> <constant name="KnockTim" units="Sec">1</constant> <constant name="KpaTPSTar">"Speed Density"</constant> <constant name="LC_f_limangle" units="Deg">-10</constant> <constant name="LC_f_slim" units="RPM">25500</constant> <constant name="LC_flatlim" units="RPM">19000</constant> <constant name="LC_flatsel" units="RPM">25500</constant> <constant name="LachDeg" units="Deg">5</constant> <constant name="LachRpm" units="RPM">1900</constant> <constant name="LachTps" units="Raw ADC">30</constant> <constant name="LaunchLim" units="rpm">2200</constant> <constant name="MaxIatAdv" units="Deg">3.2</constant> <constant name="N2Odel_flat" units="s">2.55</constant> <constant name="N2Odel_launch" units="s">2.51</constant> <constant name="N2Oholdon" units="s">2.55</constant> <constant name="NosAngle" units="Deg">18</constant> <constant name="NosClt" units="C">48.8</constant> <constant name="NosHiKpa" units="KPa">120</constant> <constant name="NosLagSystem">"Off"</constant> <constant name="NosLowKpa" units="KPa">80</constant> <constant name="NosPWHi" units="mSec">0.3</constant> <constant name="NosPWLo" units="mSec">1.2</constant> <constant name="NosRpm" units="RPM">3000</constant> <constant name="NosRpmMax" units="RPM">6000</constant> <constant name="NosTps" units="Raw">200</constant> <constant name="OLoopEgo">"KPa"</constant> <constant name="Out1UpLim" units="raw byte or deg F +40">0</constant> <constant name="Out2UpLim" units="raw byte or deg F +40">0</constant> <constant name="Out3_Out1">"Source"</constant> <constant name="OvrBCutType">"Spark Cut Only"</constant> <constant name="OvrBKpa" units="KPa">200</constant> <constant name="OvrRunC">"Off"</constant> <constant name="OvrRunClt" units="C">71</constant> <constant name="OvrRunKpa" units="KPa">20</constant> <constant name="OvrRunRpm" units="RPM">1300</constant> <constant name="OvrRunTimr" units="Sec">2</constant> <constant name="OvrRunTps" units="Raw ADC">21</constant> <constant name="Pambient" units="kPa">100</constant> <constant name="RPM1S" units="3000RPM/Sec or 5%Slip">10.0</constant> <constant name="RPM2S" units="4000RPM/Sec or 15%Slip">12.0</constant> <constant name="RPM3S" units="6000RPM/Sec or 30%Slip">13.0</constant> <constant name="RPM4S" units="10000RPM/Sec or 70%Slip">15.0</constant> <constant name="RPMAE1" units="RPM">4400</constant> <constant name="RPMAE2" units="RPM">3500</constant> <constant name="RPMAE3" units="RPM">200</constant> <constant name="RPMAE4" units="RPM">800</constant> <constant name="RPMBAsedAE">"Normal AE*^"</constant> <constant name="RPMThresh" units="RPM/Sec">3000</constant> <constant name="RPMmS1" units="mS">1.4</constant> <constant name="RPMmS2" units="mS">1.0</constant> <constant name="RPMmS3" units="mS">0.7</constant> <constant name="RPMmS4" units="mS">0.1</constant> <constant name="ST2Delay" units="Sec">0.0</constant> <constant name="STTable2On">"Spark Table2"</constant> <constant name="ScaleFac">255</constant> <constant name="ShiftLower" units="rpm">5200</constant> <constant name="ShiftUpper" units="rpm">5600</constant> <constant name="SoftLimMax" units="s">0.0</constant> <constant name="SoftLimRetard" units="deg">15</constant> <constant name="SoftRevLim" units="rpm">6200</constant> <constant name="SparkCutBNum" units="Sparks">3</constant> <constant name="SparkCutBase" units="Sparks">10</constant> <constant name="StagedAnd">"One condition"</constant> <constant name="StagedMAP2nd">"Off*^"</constant> <constant name="StartWIKPa" units="KPa">115</constant> <constant name="StgDelta">3</constant> <constant name="StgTrans">25</constant> <constant name="TPSAFRPoint" units="Raw ADC">255</constant> <constant name="TPSBooIAT" units="Raw ADC">255</constant> <constant name="TPSRPMTarg">"RPM"</constant> <constant name="TPSTar">"Always"</constant> <constant name="TargetB1" units="Raw Value">1</constant> <constant name="TargetB2" units="Raw Value">10</constant> <constant name="TargetB3" units="Raw Value">19</constant> <constant name="TargetB4" units="Raw Value">28</constant> <constant name="TpsOn" units="Raw">0</constant> <constant name="TractCySec">"Cycle count only"</constant> <constant name="TractCyc1" units="3000RPM/Sec or 5%Slip">1</constant> <constant name="TractCyc2" units="4000RPM/Sec or 15%Slip">2</constant> <constant name="TractCyc3" units="6000RPM/Sec or 30%Slip">4</constant> <constant name="TractCyc4" units="10000RPM/Sec or 70%Slip">4</constant> <constant name="TractMode">"Vehicle Speed Sensors"</constant> <constant name="TractNOS">"No"</constant> <constant name="TractRet1" units="3000RPM/Sec or 5%Slip">5</constant> <constant name="TractRet2" units="4000RPM/Sec or 15%Slip">10</constant> <constant name="TractRet3" units="6000RPM/Sec or 30%Slip">15</constant> <constant name="TractRet4" units="10000RPM/Sec or 70%Slip">18</constant> <constant name="TractSC1" units="3000RPM/Sec or 5%Slip">1</constant> <constant name="TractSC2" units="4000RPM/Sec or 15%Slip">1</constant> <constant name="TractSC3" units="6000RPM/Sec or 30%Slip">2</constant> <constant name="TractSC4" units="10000RPM/Sec or 70%Slip">2</constant> <constant name="TractScale" units="%">9</constant> <constant name="TractSlip" units="%">5</constant> <constant name="TractSlipH" units="%">2</constant> <constant name="TractVSSMax" units="V">5.00</constant> <constant name="TractVSSMin" units="V">5.00</constant> <constant name="TractionOn">"Off*^"</constant> <constant name="UseVE3">"Dont switch*^(DT)"</constant> <constant name="VE3Delay" units="Sec">0.0</constant> <constant name="VLaunch">"Off"</constant> <constant name="WaterIIat" units="C">25.0</constant> <constant name="WaterIRpm" units="RPM">3000</constant> <constant name="WaterInj">"Off*"</constant> <constant name="bcUpdateRate" units="ms">20</constant> <constant name="bc_max_diff" units="kPa">255</constant> <constant name="boostUse">"Output1*^"</constant> <constant name="dGain" units="%">9.8</constant> <constant name="dualdizzy">"Normal"</constant> <constant name="dwellcont">"Dwell control"</constant> <constant name="dwellcrank" units="ms">5.5</constant> <constant name="dwellduty50">"50% duty cycle"</constant> <constant name="dwellrun" units="ms">3.6</constant> <constant name="edis">"Off*^"</constant> <constant name="edismulti">"Off*^"</constant> <constant name="edismultirpm" units="rpm">100</constant> <constant name="efanofftemp" units="C">83.8</constant> <constant name="efanontemp" units="C">88.2</constant> <constant name="falsetrig_dis">"Enabled*"</constant> <constant name="fidleUse">"Idle control*"</constant> <constant name="freqDiv">"39.0 Hz"</constant> <constant name="hei7">"Off*^"</constant> <constant name="hybridAN">"Off*^"</constant> <constant name="ignmode">4</constant> <constant name="inj1g">"on*^"</constant> <constant name="inj2cr">"On*^"</constant> <constant name="inj2g">"on*^"</constant> <constant name="inj2t">"1*^"</constant> <constant name="launchUse">"Off*^"</constant> <constant name="led17Use">"Spark output A"</constant> <constant name="led18Use">"Spark output C"</constant> <constant name="led18_2Use">"1"</constant> <constant name="led19Use">"Spark output B"</constant> <constant name="maeBins4" rows="4" units="ms">0.2 0.5 1.1 1.8</constant> <constant name="maeRates4" rows="4" units="ms">80 150 230 320</constant> <constant name="mapProportion4">"TPSdot*^(DT)"</constant> <constant name="mapThresh4" units="kPa/s">50</constant> <constant name="mindischg" units="ms">0.1</constant> <constant name="miss2nd">"no missing"</constant> <constant name="msnsCyl">"Off*"</constant> <constant name="neonCrank">"Off*^"</constant> <constant name="nitrousUse">"Off*"</constant> <constant name="numteeth">36</constant> <constant name="onetwo">"-1"</constant> <constant name="out1Hysis" units="raw byte or deg F">0</constant> <constant name="out1lim" units="raw byte or deg F +40">0</constant> <constant name="out1src">"Off*"</constant> <constant name="out2Hysis" units="raw byte or deg F">0</constant> <constant name="out2lim" units="raw byte or deg F +40">0</constant> <constant name="out2src">"Off*"</constant> <constant name="out3Timer" units="Sec">1.0</constant> <constant name="out3lim" units="raw byte or deg F +40">1</constant> <constant name="out3sparkd">"Spark output D"</constant> <constant name="out3src">"Off*"</constant> <constant name="out4FAN">"Source"</constant> <constant name="out4lim" units="raw byte or deg F +40">0</constant> <constant name="out4src">"Off*"</constant> <constant name="pGain" units="%">49.8</constant> <constant name="rotaryFDign">"FD Trailing"</constant> <constant name="shiftUse">"Off*^"</constant> <constant name="spkeop">"Shiftlight"</constant> <constant name="spkfop">"Knock input"</constant> <constant name="tachconf">"X5 (JS3)"</constant> <constant name="tachconfdiv">"Normal"</constant> <constant name="taeBins4" rows="4" units="ms">0.2 0.5 0.8 1.5</constant> <constant name="taeColdA4" units="ms">0.5</constant> <constant name="taeColdM4" units="%">105</constant> <constant name="taeIgnCount">"Sec*^"</constant> <constant name="taeRates4" rows="4" units="ms">1.0 2.9 5.1 8.0</constant> <constant name="taeTime4" units="ms">0.3</constant> <constant name="tdePct4" units="%">75</constant> <constant name="tfi">"Off*^"</constant> <constant name="toy_dli">"Normal*"</constant> <constant name="tpsThresh4" units="v/s">0.586</constant> <constant name="trig1">1</constant> <constant name="trig1ret">6</constant> <constant name="trig2">10</constant> <constant name="trig2fall">"falling (like IRQ)"</constant> <constant name="trig2ret">15</constant> <constant name="trig3">19</constant> <constant name="trig3ret">24</constant> <constant name="trig4">28</constant> <constant name="trig4ret">33</constant> <constant name="trig5">0</constant> <constant name="trig5ret">0</constant> <constant name="trig6">0</constant> <constant name="trig6ret">0</constant> <constant name="wd_2trig">"Off"</constant> <constant name="wheel_old">"025 style"</constant> <constant name="wheelon">"Generic wheel"</constant> <constant name="whlsim">"off"</constant> <constant name="whlsimcnt">4</constant> <constant name="x2use">"Fan control"</constant> </page> - <page number="4" size="189"> <constant cols="12" name="advTable2" rows="12" units="deg">8 8 13 21 25 27 29 33 37 37 41 41 8 8 13 21 24 27 29 33 37 37 41 41 8 8 13 21 24 26 29 33 37 37 39 39 8 8 12 20 24 26 29 32 37 37 38 39 8 8 12 20 23 26 29 32 36 37 39 39 8 8 12 19 23 26 29 31 36 36 38 39 8 8 11 19 22 25 29 31 36 36 37 39 8 8 11 18 22 25 28 31 35 35 37 37 9 9 11 18 21 25 28 30 35 35 37 37 9 9 11 17 20 24 28 30 32 32 32 32 8 8 11 17 20 24 27 30 32 32 32 32 8 8 10 17 20 24 27 30 32 32 32 32</constant> <constant name="mapBins4" rows="12" units="kPa">20 25 30 35 40 45 50 55 60 70 80 100</constant> <constant name="rpmBins4" rows="12" units="RPM">500 800 1000 1200 1500 2000 2200 2500 3000 4200 5000 6000</constant> </page> - <page number="5" size="189"> <constant name="ASEFixDe">"Fixed then Decay"</constant> <constant name="ASEFixTemp" units="C">23.9</constant> <constant name="ASEFixTim">11</constant> <constant name="ASETable1" units="%">35</constant> <constant name="ASETable10" units="%">2</constant> <constant name="ASETable2" units="%">25</constant> <constant name="ASETable3" units="%">22</constant> <constant name="ASETable4" units="%">20</constant> <constant name="ASETable5" units="%">18</constant> <constant name="ASETable6" units="%">14</constant> <constant name="ASETable7" units="%">10</constant> <constant name="ASETable8" units="%">7</constant> <constant name="ASETable9" units="%">5</constant> <constant name="ASETime">17</constant> <constant name="VEFixASE">"Normal MAP *^"</constant> <constant name="VEFixValue" units="kpa">46</constant> <constant name="aseIgnCount">"Sec"</constant> <constant name="mapBins5" rows="12" units="kPa">20 30 35 45 50 60 65 70 80 85 95 100</constant> <constant name="rpmBins5" rows="12" units="RPM">600 1100 1600 2200 2800 3400 4000 4600 5200 5800 6400 7000</constant> <constant cols="12" name="veBins3" rows="12" units="%">22 28 32 37 40 43 44 45 44 42 41 40 24 30 35 39 43 46 47 48 47 45 44 42 25 31 36 41 45 47 49 49 48 47 45 44 26 32 38 43 47 50 52 52 51 50 48 47 27 33 39 45 49 52 53 54 53 51 50 48 28 35 41 47 52 55 57 57 56 54 52 51 29 36 42 48 53 56 58 59 58 56 54 52 30 37 43 50 54 58 60 60 59 57 55 53 32 39 46 52 57 61 63 63 62 60 58 56 32 40 47 53 59 62 64 65 64 62 60 58 34 42 49 56 61 65 67 68 67 65 62 60 35 43 50 57 63 67 69 69 68 66 64 62</constant> </page> - <page number="6" size="189"> <constant name="Nos2Angle" units="Deg">26</constant> <constant name="Nos2PWHi" units="mSec">9.5</constant> <constant name="Nos2PWLo" units="mSec">8.5</constant> <constant name="Nos2Rpm" units="RPM">12500</constant> <constant name="Nos2RpmMax" units="RPM">15000</constant> <constant name="Nos2delay" units="s">0.60</constant> <constant cols="8" name="afrBins1" rows="8" units="Volts">2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.37 2.57 2.57 2.57 2.57 2.57 2.27 2.27 2.16 2.57 2.57 2.57 2.57 2.57 2.27 2.16 2.16 2.27 2.27 2.27 2.27 2.27 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16</constant> <constant cols="8" name="afrBins2" rows="8" units="Volts">2.96 2.96 2.67 2.76 2.76 2.76 2.76 2.76 2.76 2.76 2.57 2.57 2.57 2.57 2.57 2.57 2.27 2.27 2.57 2.57 2.57 2.57 2.57 2.57 2.27 2.27 2.57 2.57 2.57 2.57 2.57 2.27 2.27 2.27 2.16 2.16 2.16 2.06 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06</constant> <constant name="mapBins6" rows="8" units="kPa">15 25 45 60 70 80 90 100</constant> <constant name="mapBins7" rows="8" units="kPa">15 30 40 60 100 120 150 160</constant> <constant name="outaoffs">"0"</constant> <constant name="outaoffv" units="deg">42.2</constant> <constant name="outboffs">"+45"</constant> <constant name="outboffv" units="deg">45.1</constant> <constant name="outcoffs">"0"</constant> <constant name="outcoffv" units="deg">45.1</constant> <constant name="outdoffs">"0"</constant> <constant name="outdoffv" units="deg">45.1</constant> <constant name="outeoffs">"0"</constant> <constant name="outeoffv" units="deg">0.0</constant> <constant name="outfoffs">"0"</constant> <constant name="outfoffv" units="deg">0.0</constant> <constant name="rpmBins6" rows="8" units="RPM">1200 2500 3000 3500 4000 4500 5000 5800</constant> <constant name="rpmBins7" rows="8" units="RPM">1000 1500 2000 2500 3000 4000 5000 6000</constant> </page> - <page number="7" size="189"> <constant cols="6" name="bcBins1" rows="6" units="kpa">20 20 20 20 20 20 50 50 50 50 50 50 80 80 80 80 80 80 100 100 100 100 100 100 130 130 130 130 130 130 160 160 160 160 160 160</constant> <constant cols="6" name="bcBins2" rows="6" units="duty">4 4 4 4 4 4 20 20 20 20 20 20 31 31 31 31 31 31 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39</constant> <constant cols="6" name="bcBins3" rows="6" units="kpa">10 10 10 10 10 10 20 20 20 20 20 20 100 100 100 100 100 100 120 120 120 120 120 120 140 140 140 140 140 140 160 160 160 160 160 160</constant> <constant name="bcrpmBins1" rows="6" units="RPM">500 1000 2000 3000 4500 6000</constant> <constant name="bcrpmBins2" rows="6" units="RPM">1000 2400 3000 4000 5000 6000</constant> <constant name="bcrpmBins3" rows="6" units="RPM">1000 2000 3000 4000 5000 6000</constant> <constant name="bctpsBins1" rows="6" units="tps%">4 20 31 39 55 63</constant> <constant name="bctpsBins2" rows="6" units="tps%">8 24 31 39 55 63</constant> <constant name="bctpsBins3" rows="6" units="tps%">10 20 40 60 80 100</constant> </page> - <page number="8" size="189"> <constant name="AlwaysPrime">"Always"</constant> <constant name="CrankPWT1" units="mS">10.0</constant> <constant name="CrankPWT10" units="mS">3.0</constant> <constant name="CrankPWT2" units="mS">8.8</constant> <constant name="CrankPWT3" units="mS">7.0</constant> <constant name="CrankPWT4" units="mS">6.0</constant> <constant name="CrankPWT5" units="mS">5.5</constant> <constant name="CrankPWT6" units="mS">5.2</constant> <constant name="CrankPWT7" units="mS">4.6</constant> <constant name="CrankPWT8" units="mS">4.2</constant> <constant name="CrankPWT9" units="mS">3.8</constant> <constant name="CrankRPM" units="rpm">300</constant> <constant name="ExFuelCrank">"On"</constant> <constant name="ExtraFMult" units="%">25</constant> <constant name="IATCTemp" rows="7" units="C">71 75 80 85 90 95 100</constant> <constant name="IATCor">"Normal Correction*^"</constant> <constant name="IATCorS" rows="7" units="%">100 98 96 94 92 90 88</constant> <constant name="IATCorTy">"IAT Corrected"</constant> <constant name="Idashdelay" units="x 0.01sec">0</constant> <constant name="Ideadbnd" units="+/- RPM">30</constant> <constant name="PrimeLate">"After 2 Secs"</constant> <constant name="PrimePulse" units="mS">2.0</constant> <constant name="PrimeTBox">"Standard Prime"</constant> <constant name="RPMRedHi" units="RPM">10000</constant> <constant name="RPMRedLo" units="RPM">10000</constant> <constant name="crankpwip">"CLT only*^"</constant> <constant name="fastIdleRPM" units="RPM">1100</constant> <constant name="fastIdleTemp" units="C">-8</constant> <constant name="fixedsplit" units="deg">-10</constant> <constant name="ictlrpm1" units="lo RPM">30</constant> <constant name="ictlrpm2" units="hi RPM">100</constant> <constant name="idlePeriod2" units="x 0.01sec">255</constant> <constant name="idleThresh" units="ADC">2</constant> <constant name="idle_dc_hi" units="dc">0</constant> <constant name="idle_dc_lo" units="dc">115</constant> <constant name="idleclosedc" units="dc">0</constant> <constant name="idlecrankdc" units="dc">50</constant> <constant name="idledashdc" units="dc">255</constant> <constant name="idledelayclock" units="x 0.01sec">1</constant> <constant name="idlefreq" units="10000/x = Frequency">255</constant> <constant name="idlemindc" units="dc">255</constant> <constant name="idleperiod" units="x 0.01sec">255</constant> <constant name="idlestartclk" units="x 0.01sec">10</constant> <constant name="irestorerpm" units="RPM">2460</constant> <constant name="pwmIdle">"PWM"</constant> <constant name="pwmidlewhen">"Warmup only"</constant> <constant name="rotary2">"Off"</constant> <constant name="slowIdleRPM" units="RPM">650</constant> <constant name="slowIdleTemp" units="C">75</constant> <constant cols="6" name="splitTable" rows="6" units="deg">-10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10</constant> <constant name="splitkpaBins" rows="6" units="kpa">0 0 0 0 0 0</constant> <constant name="splitrpmBins" rows="6" units="RPM">0 0 0 0 0 0</constant> <constant name="tpsflood" units="raw">200</constant> <constant name="wueBins9" rows="10" units="%">180 180 160 150 135 125 113 108 102 100</constant> </page> </msq> Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted May 10, 2007 Share Posted May 10, 2007 Did the internet sneeze in that post? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 10, 2007 Author Share Posted May 10, 2007 No, the settings files are standard XML so you can send it or paste it as a text file like wot Rog just did. Cheers Rog! Quote Link to comment Share on other sites More sharing options...
TomG Posted May 10, 2007 Share Posted May 10, 2007 Here's my latest: Setup is 4.6 with viper hurricane cam, tubular manifolds, no airbox (k&n into plenum) MSnS but with VR sensor mounted at standard EDIS position, 2-wire Bosch PWM idle valve in open loop, LC1 wideband (0-5v), ford gen.1 coil packs I think the VE map is ok (maybe AE is bit much), spark map is pretty advanced, doesn't pink on mine but you may want to back this off to be on the safe side. Would like to hear if i'm way out on any of the settings (hopefully not!) Cheers <?xml version="1.0" encoding="ISO-8859-1"?> <msq xmlns="http://www.msefi.com/:msq"> <bibliography author="MegaTune 2.25" writeDate="2007-05-09T21:43:54+01:00" /> <versionInfo fileFormat="4.0" nPages="9" signature="MSnS-extra format 029q *********" /> <page number="0" size="189"> <constant name="algorithm1">"Speed Density"</constant> <constant name="alternate1">"Alternating"</constant> <constant name="baroCorr1">"On"</constant> <constant name="battFac1" units="ms/v">0.10</constant> <constant name="cltType1">"Unknown3"</constant> <constant name="divider1">2</constant> <constant name="egoCount1">37</constant> <constant name="egoDelta1" units="%">1</constant> <constant name="egoIgnCount">"Ign Pulses*^"</constant> <constant name="egoLimit1" units="%">10</constant> <constant name="egoRPM1" units="RPM">1000</constant> <constant name="egoSwitch1" units="v">2.352</constant> <constant name="egoTemp1" units="C">71</constant> <constant name="egoType1">"Wide band"</constant> <constant name="engineType1">"Even fire"</constant> <constant name="fastIdleT1" units="C">68.8</constant> <constant name="injOpen1" units="ms">1.0</constant> <constant name="injPwmP1" units="%">100</constant> <constant name="injPwmT1" units="ms">25.5</constant> <constant name="mapBins1" rows="12" units="kPa"> 15 20 30 40 50 60 70 80 85 90 95 100 </constant> <constant name="mapSensor1">"1"</constant> <constant name="mapType1">"250 kPa"</constant> <constant name="matType1">"Unknown3"</constant> <constant name="nCylinders1">"8"</constant> <constant name="nInjectors1">"8"</constant> <constant name="reqFuel1" units="ms">11.1</constant> <constant name="rpmBins1" rows="12" units="RPM"> 500 800 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 </constant> <constant name="rpmk1">1500</constant> <constant name="twoStroke1">"Four-stroke"</constant> <constant cols="12" name="veBins1" rows="12" units="%"> 28 28 32 38 40 42 42 53 51 47 68 70 35 28 44 50 48 45 50 52 59 48 67 75 43 39 41 44 50 51 59 61 73 67 70 85 43 43 45 51 53 53 69 73 87 86 83 93 45 47 55 57 58 59 66 67 80 82 77 97 47 56 60 60 62 64 65 63 74 82 77 88 50 62 65 63 64 69 72 74 74 94 81 88 52 71 70 65 67 74 77 80 83 88 80 89 60 70 76 70 70 76 83 86 88 86 85 92 75 75 77 73 71 81 85 89 89 88 84 90 74 75 82 80 78 84 89 91 90 83 76 80 80 80 87 83 81 86 89 91 91 87 84 86 </constant> </page> <page number="1" size="189"> <constant name="TwoLambda">"None*^(DT)"</constant> <constant name="algorithm2">"Speed Density"</constant> <constant name="alternate2">"Alternating"</constant> <constant name="baroCorr2">"On"</constant> <constant name="battFac2" units="ms/v">0.10</constant> <constant name="cltType2">"Unknown2"</constant> <constant name="divider2">2</constant> <constant name="egoDelta2" units="%">1</constant> <constant name="egoLimit2" units="%">5</constant> <constant name="egoRPM2" units="RPM">1200</constant> <constant name="egoSwitch2" units="v">2.509</constant> <constant name="egoTemp2" units="C">71</constant> <constant name="egoType2">"Wide band"</constant> <constant name="engineType2">"Even fire"</constant> <constant name="fastIdleT2" units="C">71.0</constant> <constant name="injOpen2" units="ms">1.0</constant> <constant name="injPwmP2" units="%">100</constant> <constant name="injPwmT2" units="ms">25.5</constant> <constant name="mapBins2" rows="12" units="kPa"> 25 35 45 58 80 100 112 125 137 150 160 170 </constant> <constant name="mapType2">"250 kPa"</constant> <constant name="matType2">"Unknown2"</constant> <constant name="nCylinders2">"8"</constant> <constant name="nInjectors2">"8"</constant> <constant name="primePulse2" units="ms">1.2</constant> <constant name="reqFuel2" units="ms">5.4</constant> <constant name="rpmBins2" rows="12" units="RPM"> 1000 1200 1500 2100 2800 3000 3500 4000 4500 5100 5800 6000 </constant> <constant name="rpmk2">1500</constant> <constant name="twoStroke2">"Four-stroke"</constant> <constant cols="12" name="veBins2" rows="12" units="%"> 50 48 44 45 20 20 20 20 20 20 35 60 50 48 44 45 34 34 34 34 34 34 60 60 46 49 46 45 50 53 61 62 63 71 71 71 51 52 59 57 60 66 71 72 73 74 74 74 61 68 69 70 71 72 75 77 78 86 86 86 78 79 81 82 82 83 88 89 89 89 89 89 85 94 96 98 99 99 107 108 109 109 109 109 85 94 96 100 103 107 114 116 117 117 117 117 85 94 96 101 104 107 118 120 121 121 121 121 85 94 96 103 106 109 118 121 123 123 123 123 85 94 96 105 108 111 119 122 125 125 125 125 85 94 96 105 108 115 119 126 129 129 129 129 </constant> </page> <page number="2" size="189"> <constant name="CrankAng" units="Deg">10</constant> <constant name="FixAng" units="Deg">-10</constant> <constant name="IdleAdv" units="Deg">-10</constant> <constant name="IdleAdvCLT" units="C">-40.0</constant> <constant name="IdleAdvRPM" units="RPM">500</constant> <constant name="IdleAdvTPS" units="ADC">0</constant> <constant name="IdleDelayTime" units="sec">1</constant> <constant name="IgHold">0</constant> <constant name="IgInv">"Yes"</constant> <constant name="Stg2ndParmDlt" units="kPa">0</constant> <constant name="Stg2ndParmKPA" units="kPa">0</constant> <constant name="StgCycles" units="cycles">25</constant> <constant name="TrigAng" units="Deg">60</constant> <constant name="TrigCrank">"Time Based"</constant> <constant name="Trig_plus">"0"</constant> <constant name="Trim" units="Deg">0</constant> <constant cols="12" name="advTable1" rows="12" units="deg"> 34 34 39 44 49 52 52 52 52 52 52 52 33 33 38 42 47 52 52 52 52 52 52 52 31 31 34 41 46 51 52 52 52 52 52 52 29 30 33 40 45 49 52 52 52 52 52 52 28 28 30 38 43 48 52 52 52 52 52 52 27 27 29 36 41 47 52 52 52 52 52 52 26 26 28 35 40 45 50 50 50 50 50 50 24 24 26 34 39 44 48 48 48 48 48 48 24 24 24 32 37 42 47 47 47 47 47 47 21 21 21 29 34 39 44 44 44 44 44 44 13 13 18 26 31 36 41 41 41 41 41 41 10 10 13 25 30 30 35 35 35 35 35 35 </constant> <constant name="mapBins3" rows="12" units="kPa"> 20 25 30 35 40 45 50 55 60 70 80 100 </constant> <constant name="oddfire">"No"</constant> <constant name="rpmBins3" rows="12" units="RPM"> 500 800 1000 1500 2000 2500 2800 3000 3500 4200 5000 6000 </constant> <constant name="spare3_182">150</constant> <constant name="spare3_183">140</constant> <constant name="spare3_184">130</constant> </page> <page number="3" size="189"> <constant name="AFMUse">"No AFM *^"</constant> <constant name="AccDecEnrich">"TPSdot*^(DT)"</constant> <constant name="AccelMapASE">"Normal*^"</constant> <constant name="AfrTar">"On"</constant> <constant name="AfrTar2">"Off*^(DT)"</constant> <constant name="AirCorAFM">"Use IAT"</constant> <constant name="AlphBaroCor">"No"</constant> <constant name="BarroHi" units="KPa">105</constant> <constant name="BarroLow" units="KPa">90</constant> <constant name="BooTbl2Use">"Targets 2"</constant> <constant name="BoostDir">"Increase boost"</constant> <constant name="BoostMaxKn" units="KPa">0</constant> <constant name="CltAdv">"Off"</constant> <constant name="ConsBarCor">"Not Fitted*^"</constant> <constant name="DecayAcPoint" units="mS">0.0</constant> <constant name="DecayAccel">"Decay"</constant> <constant name="DecelBoost">"Never*^"</constant> <constant name="DecelKPa" units="kPa">75</constant> <constant name="DtNos">"Bank1"</constant> <constant name="EgoLim2" units="+-">5</constant> <constant name="EgoLimKPa" units="KPa">90</constant> <constant name="HCutLCSpark" units="Sparks">3</constant> <constant name="HCutLCType">"Fuel Only"</constant> <constant name="HCutSpark" units="Sparks">3</constant> <constant name="HCutType">"Spark Cut Only"</constant> <constant name="HardRevLim" units="rpm">6300</constant> <constant name="IATBoost" units="C">141.5</constant> <constant name="IATBoostSt" units="C">99.9</constant> <constant name="IStagedMode">"Off*^"</constant> <constant name="IatAdvKpa" units="KPa">80</constant> <constant name="IgAdvDeg" units="C">15.0</constant> <constant name="IgAdvTemp" units="C">54.9</constant> <constant name="IgRetDeg" units="C">10.0</constant> <constant name="IgRetTemp" units="C">45.0</constant> <constant name="InvOut1">"Normal"</constant> <constant name="InvOut2">"Normal"</constant> <constant name="KPaDotBoost">"Never"</constant> <constant name="KPaOn" units="KPa">0</constant> <constant name="KPaTarg10" units="KPa">4</constant> <constant name="KPaTarg100" units="KPa">31</constant> <constant name="KPaTarg40" units="KPa">13</constant> <constant name="KPaTarg60" units="KPa">22</constant> <constant name="KnockAdv" units="Deg">1</constant> <constant name="KnockBoost" units="KPa">0</constant> <constant name="KnockKpa" units="KPa">100</constant> <constant name="KnockMax" units="Deg">3</constant> <constant name="KnockOn">"Off"</constant> <constant name="KnockRet" units="Deg">2</constant> <constant name="KnockRpm" units="RPM">5700</constant> <constant name="KnockRpmL" units="RPM">2000</constant> <constant name="KnockSb" units="Deg">1</constant> <constant name="KnockTim" units="Sec">1</constant> <constant name="KpaTPSTar">"Alpha-N"</constant> <constant name="LC_f_limangle" units="Deg">-10</constant> <constant name="LC_f_slim" units="RPM">25500</constant> <constant name="LC_flatlim" units="RPM">19000</constant> <constant name="LC_flatsel" units="RPM">25500</constant> <constant name="LachDeg" units="Deg">5</constant> <constant name="LachRpm" units="RPM">1900</constant> <constant name="LachTps" units="Raw ADC">30</constant> <constant name="LaunchLim" units="rpm">2200</constant> <constant name="MaxIatAdv" units="Deg">4.9</constant> <constant name="N2Odel_flat" units="s">2.55</constant> <constant name="N2Odel_launch" units="s">2.51</constant> <constant name="N2Oholdon" units="s">2.55</constant> <constant name="NosAngle" units="Deg">18</constant> <constant name="NosClt" units="C">48.8</constant> <constant name="NosHiKpa" units="KPa">120</constant> <constant name="NosLagSystem">"Off"</constant> <constant name="NosLowKpa" units="KPa">80</constant> <constant name="NosPWHi" units="mSec">0.3</constant> <constant name="NosPWLo" units="mSec">1.2</constant> <constant name="NosRpm" units="RPM">3000</constant> <constant name="NosRpmMax" units="RPM">6000</constant> <constant name="NosTps" units="Raw">200</constant> <constant name="OLoopEgo">"KPa"</constant> <constant name="Out1UpLim" units="raw byte or deg F +40">0</constant> <constant name="Out2UpLim" units="raw byte or deg F +40">0</constant> <constant name="Out3_Out1">"Source"</constant> <constant name="OvrBCutType">"Spark Cut Only"</constant> <constant name="OvrBKpa" units="KPa">200</constant> <constant name="OvrRunC">"On"</constant> <constant name="OvrRunClt" units="C">71</constant> <constant name="OvrRunKpa" units="KPa">20</constant> <constant name="OvrRunRpm" units="RPM">1300</constant> <constant name="OvrRunTimr" units="Sec">2</constant> <constant name="OvrRunTps" units="Raw ADC">29</constant> <constant name="Pambient" units="kPa">100</constant> <constant name="RPM1S" units="3000RPM/Sec or 5%Slip">10.0</constant> <constant name="RPM2S" units="4000RPM/Sec or 15%Slip">12.0</constant> <constant name="RPM3S" units="6000RPM/Sec or 30%Slip">13.0</constant> <constant name="RPM4S" units="10000RPM/Sec or 70%Slip ">15.0</constant> <constant name="RPMAE1" units="RPM">4400</constant> <constant name="RPMAE2" units="RPM">3500</constant> <constant name="RPMAE3" units="RPM">1500</constant> <constant name="RPMAE4" units="RPM">800</constant> <constant name="RPMBAsedAE">"Normal AE*^"</constant> <constant name="RPMThresh" units="RPM/Sec">3000</constant> <constant name="RPMmS1" units="mS">8.0</constant> <constant name="RPMmS2" units="mS">6.5</constant> <constant name="RPMmS3" units="mS">5.0</constant> <constant name="RPMmS4" units="mS">3.0</constant> <constant name="ST2Delay" units="Sec">0.0</constant> <constant name="STTable2On">"Spark Table1^"</constant> <constant name="ScaleFac">255</constant> <constant name="ShiftLower" units="rpm">5200</constant> <constant name="ShiftUpper" units="rpm">5600</constant> <constant name="SoftLimMax" units="s">0.0</constant> <constant name="SoftLimRetard" units="deg">15</constant> <constant name="SoftRevLim" units="rpm">6200</constant> <constant name="SparkCutBNum" units="Sparks">3</constant> <constant name="SparkCutBase" units="Sparks">10</constant> <constant name="StagedAnd">"One condition"</constant> <constant name="StagedMAP2nd">"Off*^"</constant> <constant name="StartWIKPa" units="KPa">115</constant> <constant name="StgDelta">3</constant> <constant name="StgTrans">25</constant> <constant name="TPSAFRPoint" units="Raw ADC">255</constant> <constant name="TPSBooIAT" units="Raw ADC">255</constant> <constant name="TPSRPMTarg">"TPS"</constant> <constant name="TPSTar">"Always"</constant> <constant name="TargetB1" units="Raw Value">35</constant> <constant name="TargetB2" units="Raw Value">8</constant> <constant name="TargetB3" units="Raw Value">17</constant> <constant name="TargetB4" units="Raw Value">26</constant> <constant name="TpsOn" units="Raw">0</constant> <constant name="TractCySec">"Cycle count only"</constant> <constant name="TractCyc1" units="3000RPM/Sec or 5%Slip">1</constant> <constant name="TractCyc2" units="4000RPM/Sec or 15%Slip">2</constant> <constant name="TractCyc3" units="6000RPM/Sec or 30%Slip">4</constant> <constant name="TractCyc4" units="10000RPM/Sec or 70%Slip">4</constant> <constant name="TractMode">"Vehicle Speed Sensors"</constant> <constant name="TractNOS">"No"</constant> <constant name="TractRet1" units="3000RPM/Sec or 5%Slip">5</constant> <constant name="TractRet2" units="4000RPM/Sec or 15%Slip">10</constant> <constant name="TractRet3" units="6000RPM/Sec or 30%Slip">15</constant> <constant name="TractRet4" units="10000RPM/Sec or 70%Slip">18</constant> <constant name="TractSC1" units="3000RPM/Sec or 5%Slip">1</constant> <constant name="TractSC2" units="4000RPM/Sec or 15%Slip">1</constant> <constant name="TractSC3" units="6000RPM/Sec or 30%Slip">2</constant> <constant name="TractSC4" units="10000RPM/Sec or 70%Slip">2</constant> <constant name="TractScale" units="%">9</constant> <constant name="TractSlip" units="%">5</constant> <constant name="TractSlipH" units="%">2</constant> <constant name="TractVSSMax" units="V">5.00</constant> <constant name="TractVSSMin" units="V">5.00</constant> <constant name="TractionOn">"Off*^"</constant> <constant name="UseVE3">"Dont switch*^(DT)"</constant> <constant name="VE3Delay" units="Sec">0.0</constant> <constant name="VLaunch">"Off"</constant> <constant name="WaterIIat" units="C">25.0</constant> <constant name="WaterIRpm" units="RPM">3000</constant> <constant name="WaterInj">"Off*"</constant> <constant name="bcUpdateRate" units="ms">20</constant> <constant name="bc_max_diff" units="kPa">255</constant> <constant name="boostUse">"Output1*^"</constant> <constant name="dGain" units="%">9.8</constant> <constant name="dualdizzy">"Normal"</constant> <constant name="dwellcont">"Dwell control"</constant> <constant name="dwellcrank" units="ms">5.0</constant> <constant name="dwellduty50">"50% duty cycle"</constant> <constant name="dwellrun" units="ms">3.5</constant> <constant name="edis">"Off*^"</constant> <constant name="edismulti">"Off*^"</constant> <constant name="edismultirpm" units="rpm">100</constant> <constant name="efanofftemp" units="C">83.8</constant> <constant name="efanontemp" units="C">88.2</constant> <constant name="falsetrig_dis">"Enabled*"</constant> <constant name="fidleUse">"Idle control*"</constant> <constant name="freqDiv">"39.0 Hz"</constant> <constant name="hei7">"Off*^"</constant> <constant name="hybridAN">"Off*^"</constant> <constant name="ignmode">4</constant> <constant name="inj1g">"on*^"</constant> <constant name="inj2cr">"On*^"</constant> <constant name="inj2g">"on*^"</constant> <constant name="inj2t">"1*^"</constant> <constant name="launchUse">"Off*^"</constant> <constant name="led17Use">"Spark output A"</constant> <constant name="led18Use">"Spark output C"</constant> <constant name="led18_2Use">"1"</constant> <constant name="led19Use">"Spark output B"</constant> <constant name="maeBins4" rows="4" units="ms"> 0.8 2.0 4.0 8.0 </constant> <constant name="maeRates4" rows="4" units="ms"> 50 100 250 500 </constant> <constant name="mapProportion4">"TPSdot*^(DT)"</constant> <constant name="mapThresh4" units="kPa/s">50</constant> <constant name="mindischg" units="ms">0.1</constant> <constant name="miss2nd">"no missing"</constant> <constant name="msnsCyl">"Off*"</constant> <constant name="neonCrank">"Off*^"</constant> <constant name="nitrousUse">"Off*"</constant> <constant name="numteeth">36</constant> <constant name="onetwo">"-1"</constant> <constant name="out1Hysis" units="raw byte or deg F">0</constant> <constant name="out1lim" units="raw byte or deg F +40">0</constant> <constant name="out1src">"Off*"</constant> <constant name="out2Hysis" units="raw byte or deg F">0</constant> <constant name="out2lim" units="raw byte or deg F +40">0</constant> <constant name="out2src">"Off*"</constant> <constant name="out3Timer" units="Sec">1.0</constant> <constant name="out3lim" units="raw byte or deg F +40">1</constant> <constant name="out3sparkd">"Spark output D"</constant> <constant name="out3src">"Off*"</constant> <constant name="out4FAN">"Source"</constant> <constant name="out4lim" units="raw byte or deg F +40">0</constant> <constant name="out4src">"Off*"</constant> <constant name="pGain" units="%">49.8</constant> <constant name="rotaryFDign">"FD Trailing"</constant> <constant name="shiftUse">"Off*^"</constant> <constant name="spkeop">"Shiftlight"</constant> <constant name="spkfop">"Knock input"</constant> <constant name="tachconf">"X3 (JS1)"</constant> <constant name="tachconfdiv">"Normal"</constant> <constant name="taeBins4" rows="4" units="ms"> 0.5 1.0 4.0 8.0 </constant> <constant name="taeColdA4" units="ms">9.0</constant> <constant name="taeColdM4" units="%">5</constant> <constant name="taeIgnCount">"Sec*^"</constant> <constant name="taeRates4" rows="4" units="ms"> 1.0 2.9 5.1 10.0 </constant> <constant name="taeTime4" units="ms">0.8</constant> <constant name="tdePct4" units="%">75</constant> <constant name="tfi">"Off*^"</constant> <constant name="toy_dli">"Normal*"</constant> <constant name="tpsThresh4" units="v/s">0.977</constant> <constant name="trig1">35</constant> <constant name="trig1ret">4</constant> <constant name="trig2">8</constant> <constant name="trig2fall">"falling (like IRQ)"</constant> <constant name="trig2ret">13</constant> <constant name="trig3">17</constant> <constant name="trig3ret">22</constant> <constant name="trig4">26</constant> <constant name="trig4ret">31</constant> <constant name="trig5">0</constant> <constant name="trig5ret">0</constant> <constant name="trig6">0</constant> <constant name="trig6ret">0</constant> <constant name="wd_2trig">"Off"</constant> <constant name="wheel_old">"025 style"</constant> <constant name="wheelon">"Generic wheel"</constant> <constant name="whlsim">"off"</constant> <constant name="whlsimcnt">4</constant> <constant name="x2use">"Fan control"</constant> </page> <page number="4" size="189"> <constant cols="12" name="advTable2" rows="12" units="deg"> 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 9 9 9 9 9 9 9 9 9 9 9 9 10 10 10 10 10 10 10 10 10 10 10 10 12 12 12 12 12 12 12 12 12 12 12 12 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 18 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 </constant> <constant name="mapBins4" rows="12" units="kPa"> 15 20 30 40 50 60 70 80 100 120 140 160 </constant> <constant name="rpmBins4" rows="12" units="RPM"> 500 1000 1200 2000 2800 3500 4000 4500 5000 5500 5800 6000 </constant> </page> <page number="5" size="189"> <constant name="ASEFixDe">"Decay *^"</constant> <constant name="ASEFixTemp" units="C">23.9</constant> <constant name="ASEFixTim">11</constant> <constant name="ASETable1" units="%">50</constant> <constant name="ASETable10" units="%">5</constant> <constant name="ASETable2" units="%">40</constant> <constant name="ASETable3" units="%">30</constant> <constant name="ASETable4" units="%">24</constant> <constant name="ASETable5" units="%">22</constant> <constant name="ASETable6" units="%">20</constant> <constant name="ASETable7" units="%">19</constant> <constant name="ASETable8" units="%">18</constant> <constant name="ASETable9" units="%">17</constant> <constant name="ASETime">255</constant> <constant name="VEFixASE">"Normal MAP *^"</constant> <constant name="VEFixValue" units="kpa">40</constant> <constant name="aseIgnCount">"Cycles*^"</constant> <constant name="mapBins5" rows="12" units="kPa"> 20 30 35 45 50 60 65 70 80 85 95 100 </constant> <constant name="rpmBins5" rows="12" units="RPM"> 600 1100 1600 2200 2800 3400 4000 4600 5200 5800 6400 7000 </constant> <constant cols="12" name="veBins3" rows="12" units="%"> 22 28 32 37 40 43 44 45 44 42 41 40 24 30 35 39 43 46 47 48 47 45 44 42 25 31 36 41 45 47 49 49 48 47 45 44 26 32 38 43 47 50 52 52 51 50 48 47 27 33 39 45 49 52 53 54 53 51 50 48 28 35 41 47 52 55 57 57 56 54 52 51 29 36 42 48 53 56 58 59 58 56 54 52 30 37 43 50 54 58 60 60 59 57 55 53 32 39 46 52 57 61 63 63 62 60 58 56 32 40 47 53 59 62 64 65 64 62 60 58 34 42 49 56 61 65 67 68 67 65 62 60 35 43 50 57 63 67 69 69 68 66 64 62 </constant> </page> <page number="6" size="189"> <constant name="Nos2Angle" units="Deg">26</constant> <constant name="Nos2PWHi" units="mSec">9.5</constant> <constant name="Nos2PWLo" units="mSec">8.5</constant> <constant name="Nos2Rpm" units="RPM">12500</constant> <constant name="Nos2RpmMax" units="RPM">15000</constant> <constant name="Nos2delay" units="s">0.60</constant> <constant cols="8" name="afrBins1" rows="8" units="AFR"> 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.7 14.0 14.0 14.0 14.7 14.7 14.0 14.0 14.0 14.0 13.5 13.5 14.0 14.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 12.5 12.5 12.5 12.5 12.5 12.5 12.5 12.5 12.5 12.5 12.5 12.5 12.5 12.5 </constant> <constant cols="8" name="afrBins2" rows="8" units="AFR"> 15.9 15.9 15.3 15.5 15.5 15.5 15.5 15.5 15.5 15.5 15.1 15.1 15.1 15.1 15.1 15.1 14.5 14.5 15.1 15.1 15.1 15.1 15.1 15.1 14.5 14.5 15.1 15.1 15.1 15.1 15.1 14.5 14.5 14.5 14.3 14.3 14.3 14.1 14.3 14.3 14.3 14.3 14.3 14.3 14.3 14.3 14.3 14.3 14.3 14.3 14.1 14.1 14.1 14.1 14.1 14.1 14.1 14.1 14.1 14.1 14.1 14.1 14.1 14.1 </constant> <constant name="mapBins6" rows="8" units="kPa"> 15 25 45 60 70 80 90 100 </constant> <constant name="mapBins7" rows="8" units="kPa"> 15 30 40 60 100 120 150 160 </constant> <constant name="outaoffs">"0"</constant> <constant name="outaoffv" units="deg">42.2</constant> <constant name="outboffs">"+45"</constant> <constant name="outboffv" units="deg">45.1</constant> <constant name="outcoffs">"0"</constant> <constant name="outcoffv" units="deg">45.1</constant> <constant name="outdoffs">"0"</constant> <constant name="outdoffv" units="deg">45.1</constant> <constant name="outeoffs">"0"</constant> <constant name="outeoffv" units="deg">0.0</constant> <constant name="outfoffs">"0"</constant> <constant name="outfoffv" units="deg">0.0</constant> <constant name="rpmBins6" rows="8" units="RPM"> 1200 2500 3000 3500 4000 4500 5000 5800 </constant> <constant name="rpmBins7" rows="8" units="RPM"> 1000 1500 2000 2500 3000 4000 5000 6000 </constant> </page> <page number="7" size="189"> <constant cols="6" name="bcBins1" rows="6" units="kpa"> 20 20 20 20 20 20 50 50 50 50 50 50 80 80 80 80 80 80 100 100 100 100 100 100 130 130 130 130 130 130 160 160 160 160 160 160 </constant> <constant cols="6" name="bcBins2" rows="6" units="duty"> 4 4 4 4 4 4 20 20 20 20 20 20 31 31 31 31 31 31 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 </constant> <constant cols="6" name="bcBins3" rows="6" units="kpa"> 10 10 10 10 10 10 20 20 20 20 20 20 100 100 100 100 100 100 120 120 120 120 120 120 140 140 140 140 140 140 160 160 160 160 160 160 </constant> <constant name="bcrpmBins1" rows="6" units="RPM"> 500 1000 2000 3000 4500 6000 </constant> <constant name="bcrpmBins2" rows="6" units="RPM"> 1000 2400 3000 4000 5000 6000 </constant> <constant name="bcrpmBins3" rows="6" units="RPM"> 1000 2000 3000 4000 5000 6000 </constant> <constant name="bctpsBins1" rows="6" units="tps%"> 4 20 31 39 55 63 </constant> <constant name="bctpsBins2" rows="6" units="tps%"> 8 24 31 39 55 63 </constant> <constant name="bctpsBins3" rows="6" units="tps%"> 10 20 40 60 80 100 </constant> </page> <page number="8" size="189"> <constant name="AlwaysPrime">"Prime Pulse>0*^"</constant> <constant name="CrankPWT1" units="mS">18.1</constant> <constant name="CrankPWT10" units="mS">2.0</constant> <constant name="CrankPWT2" units="mS">12.1</constant> <constant name="CrankPWT3" units="mS">8.1</constant> <constant name="CrankPWT4" units="mS">6.1</constant> <constant name="CrankPWT5" units="mS">5.6</constant> <constant name="CrankPWT6" units="mS">5.1</constant> <constant name="CrankPWT7" units="mS">4.6</constant> <constant name="CrankPWT8" units="mS">4.1</constant> <constant name="CrankPWT9" units="mS">2.2</constant> <constant name="CrankRPM" units="rpm">300</constant> <constant name="ExFuelCrank">"Off"</constant> <constant name="ExtraFMult" units="%">25</constant> <constant name="IATCTemp" rows="7" units="C"> 71 75 80 85 90 95 100 </constant> <constant name="IATCor">"Normal Correction*^"</constant> <constant name="IATCorS" rows="7" units="%"> 100 98 96 94 92 90 88 </constant> <constant name="IATCorTy">"IAT Corrected"</constant> <constant name="Idashdelay" units="x 0.01sec">3</constant> <constant name="Ideadbnd" units="+/- RPM">80</constant> <constant name="PrimeLate">"Power Up*^"</constant> <constant name="PrimePulse" units="mS">4.0</constant> <constant name="PrimeTBox">"Standard Prime"</constant> <constant name="RPMRedHi" units="RPM">10000</constant> <constant name="RPMRedLo" units="RPM">10000</constant> <constant name="crankpwip">"CLT only*^"</constant> <constant name="fastIdleRPM" units="RPM">900</constant> <constant name="fastIdleTemp" units="C">26</constant> <constant name="fixedsplit" units="deg">-10</constant> <constant name="ictlrpm1" units="lo RPM">80</constant> <constant name="ictlrpm2" units="hi RPM">120</constant> <constant name="idlePeriod2" units="x 0.01sec">1</constant> <constant name="idleThresh" units="ADC">50</constant> <constant name="idle_dc_hi" units="dc">72</constant> <constant name="idle_dc_lo" units="dc">90</constant> <constant name="idleclosedc" units="dc">60</constant> <constant name="idlecrankdc" units="dc">90</constant> <constant name="idledashdc" units="dc">3</constant> <constant name="idledelayclock" units="x 0.01sec">255</constant> <constant name="idlefreq" units="10000/x = Frequency">200</constant> <constant name="idlemindc" units="dc">75</constant> <constant name="idleperiod" units="x 0.01sec">15</constant> <constant name="idlestartclk" units="x 0.01sec">200</constant> <constant name="irestorerpm" units="RPM">800</constant> <constant name="pwmIdle">"PWM"</constant> <constant name="pwmidlewhen">"Closed loop only"</constant> <constant name="rotary2">"Off"</constant> <constant name="slowIdleRPM" units="RPM">850</constant> <constant name="slowIdleTemp" units="C">79</constant> <constant cols="6" name="splitTable" rows="6" units="deg"> -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 </constant> <constant name="splitkpaBins" rows="6" units="kpa"> 0 0 0 0 0 0 </constant> <constant name="splitrpmBins" rows="6" units="RPM"> 0 0 0 0 0 0 </constant> <constant name="tpsflood" units="raw">200</constant> <constant name="wueBins9" rows="10" units="%"> 140 130 135 130 127 125 120 115 108 100 </constant> </page> </msq> Quote Link to comment Share on other sites More sharing options...
TomG Posted May 10, 2007 Share Posted May 10, 2007 Rog, any chance you could paste it into a codebox in your post? I think the formatting has got a bit messed up cos it errors loading into megatune. I opened my MSQ in Notepad, copied and pasted it out into a codebox (under Insert Special Item) Cheers Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2007 Share Posted May 10, 2007 (edited) Hope this works, saves Rog doing it <?xml version="1.0" encoding="ISO-8859-1" ?> - <msq xmlns="http://www.msefi.com/:msq"> <bibliography author="MegaTune 2.25" writeDate="2007-03-17T14:40:48+00:00" /> <versionInfo fileFormat="4.0" nPages="9" signature="MSnS-extra format 029q *********" /> - <page number="0" size="189"> <constant name="algorithm1">"Speed Density"</constant> <constant name="alternate1">"Alternating"</constant> <constant name="baroCorr1">"On"</constant> <constant name="battFac1" units="ms/v">0.10</constant> <constant name="cltType1">"Unknown3"</constant> <constant name="divider1">2</constant> <constant name="egoCount1">37</constant> <constant name="egoDelta1" units="%">0</constant> <constant name="egoIgnCount">"Ign Pulses*^"</constant> <constant name="egoLimit1" units="%">10</constant> <constant name="egoRPM1" units="RPM">1300</constant> <constant name="egoSwitch1" units="v">0.510</constant> <constant name="egoTemp1" units="C">71</constant> <constant name="egoType1">"Narrow band"</constant> <constant name="engineType1">"Even fire"</constant> <constant name="fastIdleT1" units="C">68.8</constant> <constant name="injOpen1" units="ms">1.0</constant> <constant name="injPwmP1" units="%">100</constant> <constant name="injPwmT1" units="ms">25.5</constant> <constant name="mapBins1" rows="12" units="kPa">15 20 30 40 50 60 70 80 85 90 95 100</constant> <constant name="mapSensor1">"1"</constant> <constant name="mapType1">"250 kPa"</constant> <constant name="matType1">"Unknown3"</constant> <constant name="nCylinders1">"8"</constant> <constant name="nInjectors1">"8"</constant> <constant name="reqFuel1" units="ms">11.0</constant> <constant name="rpmBins1" rows="12" units="RPM">600 1000 1500 2000 2500 3000 3500 4000 4500 5000 5400 5800</constant> <constant name="rpmk1">1500</constant> <constant name="twoStroke1">"Four-stroke"</constant> <constant cols="12" name="veBins1" rows="12" units="%">44 42 46 46 42 42 42 50 52 53 56 56 44 45 46 47 49 49 50 56 60 60 60 60 42 42 46 53 56 56 59 65 65 65 66 68 42 45 48 55 58 62 70 74 74 74 74 74 48 48 53 57 64 66 72 78 78 78 78 78 51 54 55 57 66 70 76 78 80 80 80 80 58 59 59 62 69 74 78 79 80 80 80 80 63 65 66 64 69 74 76 79 80 80 80 80 67 70 68 67 71 75 76 78 80 80 80 80 71 72 73 70 73 75 76 78 80 80 80 80 71 72 73 71 74 75 76 78 80 80 80 80 71 72 73 71 75 76 76 79 80 80 81 81</constant> </page> - <page number="1" size="189"> <constant name="TwoLambda">"None*^(DT)"</constant> <constant name="algorithm2">"Speed Density"</constant> <constant name="alternate2">"Alternating"</constant> <constant name="baroCorr2">"On"</constant> <constant name="battFac2" units="ms/v">0.10</constant> <constant name="cltType2">"Unknown2"</constant> <constant name="divider2">2</constant> <constant name="egoDelta2" units="%">1</constant> <constant name="egoLimit2" units="%">5</constant> <constant name="egoRPM2" units="RPM">1200</constant> <constant name="egoSwitch2" units="v">2.509</constant> <constant name="egoTemp2" units="C">71</constant> <constant name="egoType2">"Wide band"</constant> <constant name="engineType2">"Even fire"</constant> <constant name="fastIdleT2" units="C">71.0</constant> <constant name="injOpen2" units="ms">1.0</constant> <constant name="injPwmP2" units="%">100</constant> <constant name="injPwmT2" units="ms">25.5</constant> <constant name="mapBins2" rows="12" units="kPa">25 35 45 58 80 100 112 125 137 150 160 170</constant> <constant name="mapType2">"250 kPa"</constant> <constant name="matType2">"Unknown2"</constant> <constant name="nCylinders2">"8"</constant> <constant name="nInjectors2">"8"</constant> <constant name="primePulse2" units="ms">1.2</constant> <constant name="reqFuel2" units="ms">5.4</constant> <constant name="rpmBins2" rows="12" units="RPM">1000 1200 1500 2100 2800 3000 3500 4000 4500 5100 5800 6000</constant> <constant name="rpmk2">1500</constant> <constant name="twoStroke2">"Four-stroke"</constant> <constant cols="12" name="veBins2" rows="12" units="%">50 48 44 45 20 20 20 20 20 20 35 60 50 48 44 45 34 34 34 34 34 34 60 60 46 49 46 45 50 53 61 62 63 71 71 71 51 52 59 57 60 66 71 72 73 74 74 74 61 68 69 70 71 72 75 77 78 86 86 86 78 79 81 82 82 83 88 89 89 89 89 89 85 94 96 98 99 99 107 108 109 109 109 109 85 94 96 100 103 107 114 116 117 117 117 117 85 94 96 101 104 107 118 120 121 121 121 121 85 94 96 103 106 109 118 121 123 123 123 123 85 94 96 105 108 111 119 122 125 125 125 125 85 94 96 105 108 115 119 126 129 129 129 129</constant> </page> - <page number="2" size="189"> <constant name="CrankAng" units="Deg">10</constant> <constant name="FixAng" units="Deg">-10</constant> <constant name="IdleAdv" units="Deg">-10</constant> <constant name="IdleAdvCLT" units="C">-40.0</constant> <constant name="IdleAdvRPM" units="RPM">500</constant> <constant name="IdleAdvTPS" units="ADC">0</constant> <constant name="IdleDelayTime" units="sec">1</constant> <constant name="IgHold">0</constant> <constant name="IgInv">"Yes"</constant> <constant name="Stg2ndParmDlt" units="kPa">0</constant> <constant name="Stg2ndParmKPA" units="kPa">0</constant> <constant name="StgCycles" units="cycles">25</constant> <constant name="TrigAng" units="Deg">60</constant> <constant name="TrigCrank">"Time Based"</constant> <constant name="Trig_plus">"0"</constant> <constant name="Trim" units="Deg">0</constant> <constant cols="12" name="advTable1" rows="12" units="deg">8 8 13 21 25 27 29 33 37 37 41 41 8 8 13 21 24 27 29 33 37 37 41 41 8 8 13 21 24 26 29 33 37 37 39 39 8 8 12 20 24 26 29 32 37 37 38 39 8 8 12 20 23 26 29 32 36 37 39 39 8 8 12 19 23 26 29 31 36 36 38 39 8 8 11 19 22 25 29 31 36 36 37 39 8 8 11 18 22 25 28 31 35 35 37 37 9 9 11 18 21 25 28 30 35 35 37 37 9 9 11 17 20 24 28 30 32 32 32 32 8 8 11 17 20 24 27 30 32 32 32 32 8 8 10 17 20 24 27 30 32 32 32 32</constant> <constant name="mapBins3" rows="12" units="kPa">20 25 30 35 40 45 50 55 60 70 80 100</constant> <constant name="oddfire">"No"</constant> <constant name="rpmBins3" rows="12" units="RPM">500 800 1000 1200 1500 2000 2200 2500 3000 4200 5000 6000</constant> <constant name="spare3_182">150</constant> <constant name="spare3_183">140</constant> <constant name="spare3_184">130</constant> </page> - <page number="3" size="189"> <constant name="AFMUse">"No AFM *^"</constant> <constant name="AccDecEnrich">"TPSdot*^(DT)"</constant> <constant name="AccelMapASE">"Normal*^"</constant> <constant name="AfrTar">"Off*^(DT)"</constant> <constant name="AfrTar2">"Off*^(DT)"</constant> <constant name="AirCorAFM">"Use IAT"</constant> <constant name="AlphBaroCor">"No"</constant> <constant name="BarroHi" units="KPa">105</constant> <constant name="BarroLow" units="KPa">90</constant> <constant name="BooTbl2Use">"Targets 2"</constant> <constant name="BoostDir">"Increase boost"</constant> <constant name="BoostMaxKn" units="KPa">0</constant> <constant name="CltAdv">"On"</constant> <constant name="ConsBarCor">"Not Fitted*^"</constant> <constant name="DecayAcPoint" units="mS">0.0</constant> <constant name="DecayAccel">"Decay"</constant> <constant name="DecelBoost">"Above KPa Setpoint"</constant> <constant name="DecelKPa" units="kPa">75</constant> <constant name="DtNos">"Bank1"</constant> <constant name="EgoLim2" units="+-">5</constant> <constant name="EgoLimKPa" units="KPa">90</constant> <constant name="HCutLCSpark" units="Sparks">3</constant> <constant name="HCutLCType">"Fuel Only"</constant> <constant name="HCutSpark" units="Sparks">3</constant> <constant name="HCutType">"Spark Cut Only"</constant> <constant name="HardRevLim" units="rpm">6300</constant> <constant name="IATBoost" units="C">141.5</constant> <constant name="IATBoostSt" units="C">99.9</constant> <constant name="IStagedMode">"Off*^"</constant> <constant name="IatAdvKpa" units="KPa">80</constant> <constant name="IgAdvDeg" units="C">10.0</constant> <constant name="IgAdvTemp" units="C">54.9</constant> <constant name="IgRetDeg" units="C">10.0</constant> <constant name="IgRetTemp" units="C">45.0</constant> <constant name="InvOut1">"Normal"</constant> <constant name="InvOut2">"Normal"</constant> <constant name="KPaDotBoost">"Never"</constant> <constant name="KPaOn" units="KPa">85</constant> <constant name="KPaTarg10" units="KPa">6</constant> <constant name="KPaTarg100" units="KPa">33</constant> <constant name="KPaTarg40" units="KPa">15</constant> <constant name="KPaTarg60" units="KPa">24</constant> <constant name="KnockAdv" units="Deg">1</constant> <constant name="KnockBoost" units="KPa">0</constant> <constant name="KnockKpa" units="KPa">100</constant> <constant name="KnockMax" units="Deg">3</constant> <constant name="KnockOn">"Off"</constant> <constant name="KnockRet" units="Deg">2</constant> <constant name="KnockRpm" units="RPM">5700</constant> <constant name="KnockRpmL" units="RPM">2000</constant> <constant name="KnockSb" units="Deg">1</constant> <constant name="KnockTim" units="Sec">1</constant> <constant name="KpaTPSTar">"Speed Density"</constant> <constant name="LC_f_limangle" units="Deg">-10</constant> <constant name="LC_f_slim" units="RPM">25500</constant> <constant name="LC_flatlim" units="RPM">19000</constant> <constant name="LC_flatsel" units="RPM">25500</constant> <constant name="LachDeg" units="Deg">5</constant> <constant name="LachRpm" units="RPM">1900</constant> <constant name="LachTps" units="Raw ADC">30</constant> <constant name="LaunchLim" units="rpm">2200</constant> <constant name="MaxIatAdv" units="Deg">3.2</constant> <constant name="N2Odel_flat" units="s">2.55</constant> <constant name="N2Odel_launch" units="s">2.51</constant> <constant name="N2Oholdon" units="s">2.55</constant> <constant name="NosAngle" units="Deg">18</constant> <constant name="NosClt" units="C">48.8</constant> <constant name="NosHiKpa" units="KPa">120</constant> <constant name="NosLagSystem">"Off"</constant> <constant name="NosLowKpa" units="KPa">80</constant> <constant name="NosPWHi" units="mSec">0.3</constant> <constant name="NosPWLo" units="mSec">1.2</constant> <constant name="NosRpm" units="RPM">3000</constant> <constant name="NosRpmMax" units="RPM">6000</constant> <constant name="NosTps" units="Raw">200</constant> <constant name="OLoopEgo">"KPa"</constant> <constant name="Out1UpLim" units="raw byte or deg F +40">0</constant> <constant name="Out2UpLim" units="raw byte or deg F +40">0</constant> <constant name="Out3_Out1">"Source"</constant> <constant name="OvrBCutType">"Spark Cut Only"</constant> <constant name="OvrBKpa" units="KPa">200</constant> <constant name="OvrRunC">"Off"</constant> <constant name="OvrRunClt" units="C">71</constant> <constant name="OvrRunKpa" units="KPa">20</constant> <constant name="OvrRunRpm" units="RPM">1300</constant> <constant name="OvrRunTimr" units="Sec">2</constant> <constant name="OvrRunTps" units="Raw ADC">21</constant> <constant name="Pambient" units="kPa">100</constant> <constant name="RPM1S" units="3000RPM/Sec or 5%Slip">10.0</constant> <constant name="RPM2S" units="4000RPM/Sec or 15%Slip">12.0</constant> <constant name="RPM3S" units="6000RPM/Sec or 30%Slip">13.0</constant> <constant name="RPM4S" units="10000RPM/Sec or 70%Slip">15.0</constant> <constant name="RPMAE1" units="RPM">4400</constant> <constant name="RPMAE2" units="RPM">3500</constant> <constant name="RPMAE3" units="RPM">200</constant> <constant name="RPMAE4" units="RPM">800</constant> <constant name="RPMBAsedAE">"Normal AE*^"</constant> <constant name="RPMThresh" units="RPM/Sec">3000</constant> <constant name="RPMmS1" units="mS">1.4</constant> <constant name="RPMmS2" units="mS">1.0</constant> <constant name="RPMmS3" units="mS">0.7</constant> <constant name="RPMmS4" units="mS">0.1</constant> <constant name="ST2Delay" units="Sec">0.0</constant> <constant name="STTable2On">"Spark Table2"</constant> <constant name="ScaleFac">255</constant> <constant name="ShiftLower" units="rpm">5200</constant> <constant name="ShiftUpper" units="rpm">5600</constant> <constant name="SoftLimMax" units="s">0.0</constant> <constant name="SoftLimRetard" units="deg">15</constant> <constant name="SoftRevLim" units="rpm">6200</constant> <constant name="SparkCutBNum" units="Sparks">3</constant> <constant name="SparkCutBase" units="Sparks">10</constant> <constant name="StagedAnd">"One condition"</constant> <constant name="StagedMAP2nd">"Off*^"</constant> <constant name="StartWIKPa" units="KPa">115</constant> <constant name="StgDelta">3</constant> <constant name="StgTrans">25</constant> <constant name="TPSAFRPoint" units="Raw ADC">255</constant> <constant name="TPSBooIAT" units="Raw ADC">255</constant> <constant name="TPSRPMTarg">"RPM"</constant> <constant name="TPSTar">"Always"</constant> <constant name="TargetB1" units="Raw Value">1</constant> <constant name="TargetB2" units="Raw Value">10</constant> <constant name="TargetB3" units="Raw Value">19</constant> <constant name="TargetB4" units="Raw Value">28</constant> <constant name="TpsOn" units="Raw">0</constant> <constant name="TractCySec">"Cycle count only"</constant> <constant name="TractCyc1" units="3000RPM/Sec or 5%Slip">1</constant> <constant name="TractCyc2" units="4000RPM/Sec or 15%Slip">2</constant> <constant name="TractCyc3" units="6000RPM/Sec or 30%Slip">4</constant> <constant name="TractCyc4" units="10000RPM/Sec or 70%Slip">4</constant> <constant name="TractMode">"Vehicle Speed Sensors"</constant> <constant name="TractNOS">"No"</constant> <constant name="TractRet1" units="3000RPM/Sec or 5%Slip">5</constant> <constant name="TractRet2" units="4000RPM/Sec or 15%Slip">10</constant> <constant name="TractRet3" units="6000RPM/Sec or 30%Slip">15</constant> <constant name="TractRet4" units="10000RPM/Sec or 70%Slip">18</constant> <constant name="TractSC1" units="3000RPM/Sec or 5%Slip">1</constant> <constant name="TractSC2" units="4000RPM/Sec or 15%Slip">1</constant> <constant name="TractSC3" units="6000RPM/Sec or 30%Slip">2</constant> <constant name="TractSC4" units="10000RPM/Sec or 70%Slip">2</constant> <constant name="TractScale" units="%">9</constant> <constant name="TractSlip" units="%">5</constant> <constant name="TractSlipH" units="%">2</constant> <constant name="TractVSSMax" units="V">5.00</constant> <constant name="TractVSSMin" units="V">5.00</constant> <constant name="TractionOn">"Off*^"</constant> <constant name="UseVE3">"Dont switch*^(DT)"</constant> <constant name="VE3Delay" units="Sec">0.0</constant> <constant name="VLaunch">"Off"</constant> <constant name="WaterIIat" units="C">25.0</constant> <constant name="WaterIRpm" units="RPM">3000</constant> <constant name="WaterInj">"Off*"</constant> <constant name="bcUpdateRate" units="ms">20</constant> <constant name="bc_max_diff" units="kPa">255</constant> <constant name="boostUse">"Output1*^"</constant> <constant name="dGain" units="%">9.8</constant> <constant name="dualdizzy">"Normal"</constant> <constant name="dwellcont">"Dwell control"</constant> <constant name="dwellcrank" units="ms">5.5</constant> <constant name="dwellduty50">"50% duty cycle"</constant> <constant name="dwellrun" units="ms">3.6</constant> <constant name="edis">"Off*^"</constant> <constant name="edismulti">"Off*^"</constant> <constant name="edismultirpm" units="rpm">100</constant> <constant name="efanofftemp" units="C">83.8</constant> <constant name="efanontemp" units="C">88.2</constant> <constant name="falsetrig_dis">"Enabled*"</constant> <constant name="fidleUse">"Idle control*"</constant> <constant name="freqDiv">"39.0 Hz"</constant> <constant name="hei7">"Off*^"</constant> <constant name="hybridAN">"Off*^"</constant> <constant name="ignmode">4</constant> <constant name="inj1g">"on*^"</constant> <constant name="inj2cr">"On*^"</constant> <constant name="inj2g">"on*^"</constant> <constant name="inj2t">"1*^"</constant> <constant name="launchUse">"Off*^"</constant> <constant name="led17Use">"Spark output A"</constant> <constant name="led18Use">"Spark output C"</constant> <constant name="led18_2Use">"1"</constant> <constant name="led19Use">"Spark output B"</constant> <constant name="maeBins4" rows="4" units="ms">0.2 0.5 1.1 1.8</constant> <constant name="maeRates4" rows="4" units="ms">80 150 230 320</constant> <constant name="mapProportion4">"TPSdot*^(DT)"</constant> <constant name="mapThresh4" units="kPa/s">50</constant> <constant name="mindischg" units="ms">0.1</constant> <constant name="miss2nd">"no missing"</constant> <constant name="msnsCyl">"Off*"</constant> <constant name="neonCrank">"Off*^"</constant> <constant name="nitrousUse">"Off*"</constant> <constant name="numteeth">36</constant> <constant name="onetwo">"-1"</constant> <constant name="out1Hysis" units="raw byte or deg F">0</constant> <constant name="out1lim" units="raw byte or deg F +40">0</constant> <constant name="out1src">"Off*"</constant> <constant name="out2Hysis" units="raw byte or deg F">0</constant> <constant name="out2lim" units="raw byte or deg F +40">0</constant> <constant name="out2src">"Off*"</constant> <constant name="out3Timer" units="Sec">1.0</constant> <constant name="out3lim" units="raw byte or deg F +40">1</constant> <constant name="out3sparkd">"Spark output D"</constant> <constant name="out3src">"Off*"</constant> <constant name="out4FAN">"Source"</constant> <constant name="out4lim" units="raw byte or deg F +40">0</constant> <constant name="out4src">"Off*"</constant> <constant name="pGain" units="%">49.8</constant> <constant name="rotaryFDign">"FD Trailing"</constant> <constant name="shiftUse">"Off*^"</constant> <constant name="spkeop">"Shiftlight"</constant> <constant name="spkfop">"Knock input"</constant> <constant name="tachconf">"X5 (JS3)"</constant> <constant name="tachconfdiv">"Normal"</constant> <constant name="taeBins4" rows="4" units="ms">0.2 0.5 0.8 1.5</constant> <constant name="taeColdA4" units="ms">0.5</constant> <constant name="taeColdM4" units="%">105</constant> <constant name="taeIgnCount">"Sec*^"</constant> <constant name="taeRates4" rows="4" units="ms">1.0 2.9 5.1 8.0</constant> <constant name="taeTime4" units="ms">0.3</constant> <constant name="tdePct4" units="%">75</constant> <constant name="tfi">"Off*^"</constant> <constant name="toy_dli">"Normal*"</constant> <constant name="tpsThresh4" units="v/s">0.586</constant> <constant name="trig1">1</constant> <constant name="trig1ret">6</constant> <constant name="trig2">10</constant> <constant name="trig2fall">"falling (like IRQ)"</constant> <constant name="trig2ret">15</constant> <constant name="trig3">19</constant> <constant name="trig3ret">24</constant> <constant name="trig4">28</constant> <constant name="trig4ret">33</constant> <constant name="trig5">0</constant> <constant name="trig5ret">0</constant> <constant name="trig6">0</constant> <constant name="trig6ret">0</constant> <constant name="wd_2trig">"Off"</constant> <constant name="wheel_old">"025 style"</constant> <constant name="wheelon">"Generic wheel"</constant> <constant name="whlsim">"off"</constant> <constant name="whlsimcnt">4</constant> <constant name="x2use">"Fan control"</constant> </page> - <page number="4" size="189"> <constant cols="12" name="advTable2" rows="12" units="deg">8 8 13 21 25 27 29 33 37 37 41 41 8 8 13 21 24 27 29 33 37 37 41 41 8 8 13 21 24 26 29 33 37 37 39 39 8 8 12 20 24 26 29 32 37 37 38 39 8 8 12 20 23 26 29 32 36 37 39 39 8 8 12 19 23 26 29 31 36 36 38 39 8 8 11 19 22 25 29 31 36 36 37 39 8 8 11 18 22 25 28 31 35 35 37 37 9 9 11 18 21 25 28 30 35 35 37 37 9 9 11 17 20 24 28 30 32 32 32 32 8 8 11 17 20 24 27 30 32 32 32 32 8 8 10 17 20 24 27 30 32 32 32 32</constant> <constant name="mapBins4" rows="12" units="kPa">20 25 30 35 40 45 50 55 60 70 80 100</constant> <constant name="rpmBins4" rows="12" units="RPM">500 800 1000 1200 1500 2000 2200 2500 3000 4200 5000 6000</constant> </page> - <page number="5" size="189"> <constant name="ASEFixDe">"Fixed then Decay"</constant> <constant name="ASEFixTemp" units="C">23.9</constant> <constant name="ASEFixTim">11</constant> <constant name="ASETable1" units="%">35</constant> <constant name="ASETable10" units="%">2</constant> <constant name="ASETable2" units="%">25</constant> <constant name="ASETable3" units="%">22</constant> <constant name="ASETable4" units="%">20</constant> <constant name="ASETable5" units="%">18</constant> <constant name="ASETable6" units="%">14</constant> <constant name="ASETable7" units="%">10</constant> <constant name="ASETable8" units="%">7</constant> <constant name="ASETable9" units="%">5</constant> <constant name="ASETime">17</constant> <constant name="VEFixASE">"Normal MAP *^"</constant> <constant name="VEFixValue" units="kpa">46</constant> <constant name="aseIgnCount">"Sec"</constant> <constant name="mapBins5" rows="12" units="kPa">20 30 35 45 50 60 65 70 80 85 95 100</constant> <constant name="rpmBins5" rows="12" units="RPM">600 1100 1600 2200 2800 3400 4000 4600 5200 5800 6400 7000</constant> <constant cols="12" name="veBins3" rows="12" units="%">22 28 32 37 40 43 44 45 44 42 41 40 24 30 35 39 43 46 47 48 47 45 44 42 25 31 36 41 45 47 49 49 48 47 45 44 26 32 38 43 47 50 52 52 51 50 48 47 27 33 39 45 49 52 53 54 53 51 50 48 28 35 41 47 52 55 57 57 56 54 52 51 29 36 42 48 53 56 58 59 58 56 54 52 30 37 43 50 54 58 60 60 59 57 55 53 32 39 46 52 57 61 63 63 62 60 58 56 32 40 47 53 59 62 64 65 64 62 60 58 34 42 49 56 61 65 67 68 67 65 62 60 35 43 50 57 63 67 69 69 68 66 64 62</constant> </page> - <page number="6" size="189"> <constant name="Nos2Angle" units="Deg">26</constant> <constant name="Nos2PWHi" units="mSec">9.5</constant> <constant name="Nos2PWLo" units="mSec">8.5</constant> <constant name="Nos2Rpm" units="RPM">12500</constant> <constant name="Nos2RpmMax" units="RPM">15000</constant> <constant name="Nos2delay" units="s">0.60</constant> <constant cols="8" name="afrBins1" rows="8" units="Volts">2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.57 2.37 2.57 2.57 2.57 2.57 2.57 2.27 2.27 2.16 2.57 2.57 2.57 2.57 2.57 2.27 2.16 2.16 2.27 2.27 2.27 2.27 2.27 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16</constant> <constant cols="8" name="afrBins2" rows="8" units="Volts">2.96 2.96 2.67 2.76 2.76 2.76 2.76 2.76 2.76 2.76 2.57 2.57 2.57 2.57 2.57 2.57 2.27 2.27 2.57 2.57 2.57 2.57 2.57 2.57 2.27 2.27 2.57 2.57 2.57 2.57 2.57 2.27 2.27 2.27 2.16 2.16 2.16 2.06 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.16 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06</constant> <constant name="mapBins6" rows="8" units="kPa">15 25 45 60 70 80 90 100</constant> <constant name="mapBins7" rows="8" units="kPa">15 30 40 60 100 120 150 160</constant> <constant name="outaoffs">"0"</constant> <constant name="outaoffv" units="deg">42.2</constant> <constant name="outboffs">"+45"</constant> <constant name="outboffv" units="deg">45.1</constant> <constant name="outcoffs">"0"</constant> <constant name="outcoffv" units="deg">45.1</constant> <constant name="outdoffs">"0"</constant> <constant name="outdoffv" units="deg">45.1</constant> <constant name="outeoffs">"0"</constant> <constant name="outeoffv" units="deg">0.0</constant> <constant name="outfoffs">"0"</constant> <constant name="outfoffv" units="deg">0.0</constant> <constant name="rpmBins6" rows="8" units="RPM">1200 2500 3000 3500 4000 4500 5000 5800</constant> <constant name="rpmBins7" rows="8" units="RPM">1000 1500 2000 2500 3000 4000 5000 6000</constant> </page> - <page number="7" size="189"> <constant cols="6" name="bcBins1" rows="6" units="kpa">20 20 20 20 20 20 50 50 50 50 50 50 80 80 80 80 80 80 100 100 100 100 100 100 130 130 130 130 130 130 160 160 160 160 160 160</constant> <constant cols="6" name="bcBins2" rows="6" units="duty">4 4 4 4 4 4 20 20 20 20 20 20 31 31 31 31 31 31 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39</constant> <constant cols="6" name="bcBins3" rows="6" units="kpa">10 10 10 10 10 10 20 20 20 20 20 20 100 100 100 100 100 100 120 120 120 120 120 120 140 140 140 140 140 140 160 160 160 160 160 160</constant> <constant name="bcrpmBins1" rows="6" units="RPM">500 1000 2000 3000 4500 6000</constant> <constant name="bcrpmBins2" rows="6" units="RPM">1000 2400 3000 4000 5000 6000</constant> <constant name="bcrpmBins3" rows="6" units="RPM">1000 2000 3000 4000 5000 6000</constant> <constant name="bctpsBins1" rows="6" units="tps%">4 20 31 39 55 63</constant> <constant name="bctpsBins2" rows="6" units="tps%">8 24 31 39 55 63</constant> <constant name="bctpsBins3" rows="6" units="tps%">10 20 40 60 80 100</constant> </page> - <page number="8" size="189"> <constant name="AlwaysPrime">"Always"</constant> <constant name="CrankPWT1" units="mS">10.0</constant> <constant name="CrankPWT10" units="mS">3.0</constant> <constant name="CrankPWT2" units="mS">8.8</constant> <constant name="CrankPWT3" units="mS">7.0</constant> <constant name="CrankPWT4" units="mS">6.0</constant> <constant name="CrankPWT5" units="mS">5.5</constant> <constant name="CrankPWT6" units="mS">5.2</constant> <constant name="CrankPWT7" units="mS">4.6</constant> <constant name="CrankPWT8" units="mS">4.2</constant> <constant name="CrankPWT9" units="mS">3.8</constant> <constant name="CrankRPM" units="rpm">300</constant> <constant name="ExFuelCrank">"On"</constant> <constant name="ExtraFMult" units="%">25</constant> <constant name="IATCTemp" rows="7" units="C">71 75 80 85 90 95 100</constant> <constant name="IATCor">"Normal Correction*^"</constant> <constant name="IATCorS" rows="7" units="%">100 98 96 94 92 90 88</constant> <constant name="IATCorTy">"IAT Corrected"</constant> <constant name="Idashdelay" units="x 0.01sec">0</constant> <constant name="Ideadbnd" units="+/- RPM">30</constant> <constant name="PrimeLate">"After 2 Secs"</constant> <constant name="PrimePulse" units="mS">2.0</constant> <constant name="PrimeTBox">"Standard Prime"</constant> <constant name="RPMRedHi" units="RPM">10000</constant> <constant name="RPMRedLo" units="RPM">10000</constant> <constant name="crankpwip">"CLT only*^"</constant> <constant name="fastIdleRPM" units="RPM">1100</constant> <constant name="fastIdleTemp" units="C">-8</constant> <constant name="fixedsplit" units="deg">-10</constant> <constant name="ictlrpm1" units="lo RPM">30</constant> <constant name="ictlrpm2" units="hi RPM">100</constant> <constant name="idlePeriod2" units="x 0.01sec">255</constant> <constant name="idleThresh" units="ADC">2</constant> <constant name="idle_dc_hi" units="dc">0</constant> <constant name="idle_dc_lo" units="dc">115</constant> <constant name="idleclosedc" units="dc">0</constant> <constant name="idlecrankdc" units="dc">50</constant> <constant name="idledashdc" units="dc">255</constant> <constant name="idledelayclock" units="x 0.01sec">1</constant> <constant name="idlefreq" units="10000/x = Frequency">255</constant> <constant name="idlemindc" units="dc">255</constant> <constant name="idleperiod" units="x 0.01sec">255</constant> <constant name="idlestartclk" units="x 0.01sec">10</constant> <constant name="irestorerpm" units="RPM">2460</constant> <constant name="pwmIdle">"PWM"</constant> <constant name="pwmidlewhen">"Warmup only"</constant> <constant name="rotary2">"Off"</constant> <constant name="slowIdleRPM" units="RPM">650</constant> <constant name="slowIdleTemp" units="C">75</constant> <constant cols="6" name="splitTable" rows="6" units="deg">-10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 - 10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10</constant> <constant name="splitkpaBins" rows="6" units="kpa">0 0 0 0 0 0</constant> <constant name="splitrpmBins" rows="6" units="RPM">0 0 0 0 0 0</constant> <constant name="tpsflood" units="raw">200</constant> <constant name="wueBins9" rows="10" units="%">180 180 160 150 135 125 113 108 102 100</constant> </page> </msq> Edited May 10, 2007 by western Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted May 10, 2007 Share Posted May 10, 2007 Cheers Western - although Ive edited my original post as well. Tom, thats some advance youve got there! Typically about 10° more in the mid range and 15-20° in the high range (Im only 4.3ltrs, 3.9 cam, ford gen 1 coil packs, flapper injectors, MSnS no edis) Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2007 Share Posted May 10, 2007 Both doing it at the same time, just edited my one above so FF doesn't have to walk 5 houses down to see the far end of the information Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted May 10, 2007 Share Posted May 10, 2007 Cheers Western - although Ive edited my original post as well. Ah! That explains why wierd things were happening...I was busy editing your post at the same time By the way, Rog - if you use [codebox][/codebox] instead of just 'code' then you get the proper scrolling box instead of just a pointless pink quote style background. Quote Link to comment Share on other sites More sharing options...
minivin Posted May 10, 2007 Share Posted May 10, 2007 Gawd I'm gonna need to buy more petrol then You maybe wanting to play this out of the "tunes box" while your watching the fuel gauge drop Rammstein Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 11, 2007 Author Share Posted May 11, 2007 ECU is built, settings blown in, may even get it all hooked up tomorrow! Ian, I mentioned the cam running in procedure to a friend who made this comment which seems to support your post: I've seen various things written about breaking in cams. The basic rule is not to let it idle. Obviously thats not easy with a new build but do your best. The reason is that until the cam and follower have a good working relationship, it's too easy to break through the oil film on a slow cycle. On a normal cam, the surface will scar fairly easily and yes, I have seen cams bu**ered this way.OTOH, if you're running a standard cam, not some playtex variant, the risk is pretty low. If you've just put the engine together, the cam will of course be covered in cam lube already.... ;-) Quote Link to comment Share on other sites More sharing options...
