Stewart Posted May 13, 2007 Share Posted May 13, 2007 Hi does any body have any fitting instructions for a fairey overdrive? How long do they take to fit? Is it easy? Thanks Stewart Quote Link to comment Share on other sites More sharing options...
tiagoc Posted May 13, 2007 Share Posted May 13, 2007 here: Superwinch (formerly Fairey) Overdrive Quote Link to comment Share on other sites More sharing options...
Stewart Posted May 13, 2007 Author Share Posted May 13, 2007 Hi does any body have any fitting instructions for a fairey overdrive? How long do they take to fit? Is it easy?Thanks Stewart Brilliant just the job. Thanks Quote Link to comment Share on other sites More sharing options...
rtbarton Posted May 13, 2007 Share Posted May 13, 2007 The thing most likely to bite is the tab washer. This is NOT the same as the Rover one supplied if you don't have an overdrive. The tabs on the OD one are slightly shorter, you can file the standard ones down. If you fit the standard one the OD won't slide into place. Quote Link to comment Share on other sites More sharing options...
