s2hotdog Posted October 10, 2005 Share Posted October 10, 2005 I have a disco 200tdi in my 90 ............. the question is it was a turbo and I think its got the original rad and intercooler in it the rad has just sprug a very small leak when hot Thinking that easyer to replace but is a simple way to tell tdi rad from a td rad? Any body got a cheap TDi/TD rad in there shed ............... could meet up at the old sod Cheers for any help/advice Steve Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted October 10, 2005 Share Posted October 10, 2005 The TD didn't have the i, i being Intercooler, if you have an intercooler then its a TDi radiator Will Quote Link to comment Share on other sites More sharing options...
white90 Posted October 10, 2005 Share Posted October 10, 2005 I have a disco 200tdi in my 90 ............. the question is it was a turbo and I think its got the original rad and intercooler in it the rad has just sprug a very small leak when hot Thinking that easyer to replace but is a simple way to tell tdi rad from a td rad? Any body got a cheap TDi/TD rad in there shed ............... could meet up at the old sod Cheers for any help/advice Steve The TD rad is full width the TDI isn't to allow room for the intercooler. Quote Link to comment Share on other sites More sharing options...
western Posted October 10, 2005 Share Posted October 10, 2005 Tdi Rad is 3/4 width of the front other 1/4 is the intercooler. Tdi is actually T = Turbocharged & di = direct injection Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted October 10, 2005 Author Share Posted October 10, 2005 Ah ha thanks for the info chaps .................... so now I have a TDI rad and intercooler ........... could it be a Defender or Disco rad and intercooler? I'll have to have a check Cheers Anyway Steve Quote Link to comment Share on other sites More sharing options...
JST Posted October 10, 2005 Share Posted October 10, 2005 or a rangie one!!! i was quoted £99 to get my 200tdi rad recored. Paddocks do def and disco 200tdi rads for about £270+VAT IIRC however they also do Rangie tdi rads for £99. so i went for the paddocks rangie tdi rad which is now fitted and was/is exactly the same as the def/disco one. they do have different pn though. not use if the disco/def one comes with frame and int hence the x3 price Quote Link to comment Share on other sites More sharing options...
western Posted October 10, 2005 Share Posted October 10, 2005 If it's a Defender one then the connections to Rad & Intercooler will be same as this picture ---------- Quote Link to comment Share on other sites More sharing options...
steve_a Posted October 10, 2005 Share Posted October 10, 2005 mm4x4 do a 200tdi defender rad for ~£100. There's one in my garage along with the other 'spares'. Are you allowed to use the phrase spares for things that shoudl actually have been fitted for broken things rather than for when something brakes? Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted October 11, 2005 Author Share Posted October 11, 2005 Ralph I don't think its a defender one as intercooler and rad are not fixed together they are seperate although it looks very similar to the the one above ..................... so looks like I will have to get a rangie one if they are cheaper? Cheers Steve Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 11, 2005 Share Posted October 11, 2005 it's only the top bracket that holds the two together. Quote Link to comment Share on other sites More sharing options...
western Posted October 11, 2005 Share Posted October 11, 2005 Ralph I don't think its a defender one as intercooler and rad are not fixed together they are seperate although it looks very similar to the the one above ..................... so looks like I will have to get a rangie one if they are cheaper?Cheers Steve All 200Tdi/300Tdi rads/intercoolers genuine LR are like that picture, do you have a intercooler that sits in front of the rad? is yes then thats a aftermarket version or maybe a Td5 version. Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted October 12, 2005 Author Share Posted October 12, 2005 Ralph It is a guniune rad and intercooler as the pic ................ going to old sod and may get lucky Cheers Steve Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 12, 2005 Share Posted October 12, 2005 There is a difference in height between the two radiator/intercoolers. If you have a disco rad/intercooler, then the bottom of either the frame that holds the two will have had to be altered, or the two locating lugs on the front crossmember. The difference in height is only 28mm, but the bonnet won't close unless you lower them, so look for modifications. (been there, done that, etc) Les. Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted October 12, 2005 Author Share Posted October 12, 2005 Les thanks for that the bonnet is a little higher than it should be so this is pointing to a disco rad and intercooler I will check though Cheers Steve Quote Link to comment Share on other sites More sharing options...
