russ3120 Posted May 14, 2007 Share Posted May 14, 2007 can anyone tell me, with out me stripping down my rear axle. How many splines it has. disco mark 1, 1992 K reg 2.5tdi Russ Quote Link to comment Share on other sites More sharing options...
300bhp/ton Posted May 14, 2007 Share Posted May 14, 2007 Assuming it has the stock ones still on it check the VIN. Paddock Spares has the vins listed for the change over in the axle section of the Discovery 1 parts list on their website. Quote Link to comment Share on other sites More sharing options...
Mark Posted May 14, 2007 Share Posted May 14, 2007 Assuming you have the mushroom head type shaft, which you should have, it will be a 10-spline axle... enjoy Mark Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 14, 2007 Share Posted May 14, 2007 Assuming you have the mushroom head type shaft, which you should have, it will be a 10-spline axle... If you mean the one-piece shafts rather than seperate flanges, then they exist as 24 spline too... All you need to do is pull out 1 half shaft anyway, no "stripping" required just 10 min with a ratchet Quote Link to comment Share on other sites More sharing options...
russ3120 Posted May 14, 2007 Author Share Posted May 14, 2007 cheers guys Quote Link to comment Share on other sites More sharing options...
