Anglo-Frenchman Posted May 16, 2007 Share Posted May 16, 2007 After recently renewing my water pump, I noticed that a new squeak seemed to have appeared. I think that it is the small tensioner that lies beneath the aircon compressor and takes up the slack in the belt for the airco. Does anyone know if this is easy to replace or even if it can be adjusted to take out the play/noise/wear? Thanks Quote Link to comment Share on other sites More sharing options...
treebloke Posted May 16, 2007 Share Posted May 16, 2007 After recently renewing my water pump, I noticed that a new squeak seemed to have appeared. I think that it is the small tensioner that lies beneath the aircon compressor and takes up the slack in the belt for the airco. Does anyone know if this is easy to replace or even if it can be adjusted to take out the play/noise/wear?Thanks If your talking about a TD5 or tdi, if you go to a main dealer they will tell you that you can only replace the whole thing which is £70/£80. Truth is you can replace just the bearing. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 16, 2007 Share Posted May 16, 2007 The bearing is exactly the same one as fitted to the fan belt tensioner at the top of the engine. This thread will help with part number. http://forums.lr4x4.com/index.php?showtopic=3904 Les. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted May 17, 2007 Author Share Posted May 17, 2007 Thanks. Its for a 200tdi. Quote Link to comment Share on other sites More sharing options...
