LittlePrincessAnge Posted May 16, 2007 Share Posted May 16, 2007 Hi Has anyone any idea's about head gaskets? Coolant running through far too quickly, over heating & cold air blowing from the vents - presuming head gasket problem unless anyone can correct me? I know this is supposed to be a common fault but has anyone any idea's of how expensive its going to be to fix? Any recommendations for any good garage's in the north west? Warrington, Manchester, Liverpool area?? Given the history with my last landrover garage - dont think it would be a would idea to return to him!!!! Many thanks in advance. Ange.x Quote Link to comment Share on other sites More sharing options...
garyrigden Posted May 17, 2007 Share Posted May 17, 2007 HiHas anyone any idea's about head gaskets? Coolant running through far too quickly, over heating & cold air blowing from the vents - presuming head gasket problem unless anyone can correct me? I know this is supposed to be a common fault but has anyone any idea's of how expensive its going to be to fix? Any recommendations for any good garage's in the north west? Warrington, Manchester, Liverpool area?? Given the history with my last landrover garage - dont think it would be a would idea to return to him!!!! Many thanks in advance. Ange.x about 600 quid! thats providing you have not completly cooked the engine, i'd stop driving it now if i were you. Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted May 17, 2007 Share Posted May 17, 2007 You could try a local MG garage, the MGF and MGZR engines are the same, a local independant may be able to help. My MGF cost £700 to do including skimming the head. Quote Link to comment Share on other sites More sharing options...
smudge Posted May 17, 2007 Share Posted May 17, 2007 stop driving it m8, i carried on driving mine and ended up cooking the engine which cost me 1850, i take it your drivibn the petrol model. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted May 17, 2007 Share Posted May 17, 2007 This lot (LRC) seem to be very friendly although I have only bought parts from them so can't vouch for their repair work. They may also be a bit to far south for you as they are in Congleton near junction 17 of the M6. I would also recommend not using it until you can confirm it is actually a failed head gasket as you could wreck the engine. Pete. Quote Link to comment Share on other sites More sharing options...
Blippie Posted May 18, 2007 Share Posted May 18, 2007 I would also recommend not using it until you can confirm it is actually a failed head gasket as you could wreck the engine. That is crucial advice! I had a Rover 400 with a K-series engine. The HG failed on that but luckily we caught it early. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
foxminer Posted May 27, 2007 Share Posted May 27, 2007 That is crucial advice!I had a Rover 400 with a K-series engine. The HG failed on that but luckily we caught it early. Cheers Blippie Not sure where you are but i`ve just had some work done on my disco at Crewe Engines, i took the head of and dropped the whole thing off there and they performed the following: Chemical de-carb cyl head Pressure test cylinder head Reface cylinder head Labuor to strip,clean & rebuild All for a reasonable £246 inc vat. thier number is 01270 526333 I hope this will be of some help to you. Foxminer Quote Link to comment Share on other sites More sharing options...
elmscroft Posted July 9, 2007 Share Posted July 9, 2007 Hi, Just to let you know Freelander started first time, with no bangs or clatters, and running nice. ABS light is on, but some where it says is may go out above 5mph, which I can't do as daughters car is on axle stands in front. Just got to get a dipstick and cam cover breather hose. So for those out there told by a main dealer your Freelander needs a new engine take heart. I have't done anything like this before. I invested in a haynes manual, read it and read it again, took advice given by kind people on ths forum and repaired it so far, for about £100. Didn't skim the head ,but did check it using a straight edge and feeler gauges. Many Many thanks to all Mike Quote Link to comment Share on other sites More sharing options...
andyb Posted July 9, 2007 Share Posted July 9, 2007 A link to the MG Owners Club article about K-series head gaskets here HTH Quote Link to comment Share on other sites More sharing options...
elmscroft Posted July 14, 2007 Share Posted July 14, 2007 Hi All, Just an update on our Freelander, ABS light went out above 5mph as per book, got a dipstick and breather hoes from a Rover 414i car. So all looking good. Many Thanks Mike Quote Link to comment Share on other sites More sharing options...
