Corrode Finger Posted May 17, 2007 Share Posted May 17, 2007 A potential project idea, we are talking small power and torque compared to some applications. Say a max of 100bhp, but a lightweight aluminium engine. Can any LR or other transfer box be removed from its original location and be attached to the back of an alternative engine and gearbox combination. For arguments sake an engine and gearbox combination taken from a FWD donor and turned through 90degrees to run in a conventional 4x4 based buggy? Quote Link to comment Share on other sites More sharing options...
serendipity Posted May 17, 2007 Share Posted May 17, 2007 Simplest, especially if weight is your main consideration, is to use a suzuki transfer box, though they dont have a very "low" low range in comparison to say a land rover Tbox. But if you use some of the internals from a 1.3 tbox in a 1 litre tbox you can create a crawler box. There is lots of info out there on suzuki forums about such things. Or you could put your hand in your pocket and get Milners to supply one with the flanges of your choice.... Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted May 17, 2007 Share Posted May 17, 2007 You could use a G wagen set up, axles and lockers an all! The transfer box is simply connected to the gearbox by a very short propshaft. It just so happens I have one going spare with both axles and lockers Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted May 17, 2007 Share Posted May 17, 2007 Dose it need Hi range? If not just weld the dif in the gear box and run the props instad of drive shafts. A mate has done this with a Mini enging in a trials machine. Paul Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted May 17, 2007 Share Posted May 17, 2007 Most transfercases can be converted to stand alone by cutting the back off their original gearbox, which contains the rear mainshaft bearing and fitting a seal in front. A new input shaft then needs to be made, or you may be able to cut and rework an old mainshaft. Hard bolting a transfercase to a different make of gearbox, aside for the adaptor plate itself usually involves some form of resplining to either the gearbox mainshaft or the transfercase input gear, except for many US transmission as they are usually ''bought in'' assemblies from a handfull of specialist manufacturers who tend to standardise more re spline configurations etc. Bill Quote Link to comment Share on other sites More sharing options...
Bush65 Posted May 19, 2007 Share Posted May 19, 2007 ...For arguments sake an engine and gearbox combination taken from a FWD donor and turned through 90degrees to run in a conventional 4x4 based buggy? This was done once in Australia, had a couple of comps before being dropped. Never repeated to my knowledge. The engine was beside the driver and because of the reduction of the front wheel drive diff, didn't need a transfer case to get the low gearing. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 19, 2007 Share Posted May 19, 2007 This was done once in Australia, had a couple of comps before being dropped. Never repeated to my knowledge.The engine was beside the driver and because of the reduction of the front wheel drive diff, didn't need a transfer case to get the low gearing. Seen lots of trials motors like this over the years, nice lightwieght solution, no high range though. Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted May 19, 2007 Share Posted May 19, 2007 This was done once in Australia, had a couple of comps before being dropped. Never repeated to my knowledge.The engine was beside the driver and because of the reduction of the front wheel drive diff, didn't need a transfer case to get the low gearing. Here's an insane idea you can all have for free . Remake the fwd differential to have needle roller radial and thrust bearings on all the bevel gears, mount a brake to the outputshaft to the front diff, fit a dogclutch outboard of the brake to disconnect drive to the front propshaft. Apply the brake and the bevel gears will give you 2 wheel drive with a 2:1 overdrive. yes,I should try to get out more bill. Quote Link to comment Share on other sites More sharing options...
CosZuki Posted May 19, 2007 Share Posted May 19, 2007 Niva TFER boxes are strong, light and have lower ratios than the Zuk ones Quote Link to comment Share on other sites More sharing options...
Corrode Finger Posted May 19, 2007 Author Share Posted May 19, 2007 Niva TFER boxes are strong, light and have lower ratios than the Zuk ones Are they easily detachable from there original homes? And can they be made to fit on another box? Also whats there availability like, Niva's are getting scarcer now in the UK? Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 20, 2007 Share Posted May 20, 2007 Here's an insane idea you can all have for free . Remake the fwd differential to have needle roller radial and thrust bearings on all the bevel gears, mount a brake to the outputshaft to the front diff, fit a dogclutch outboard of the brake to disconnect drive to the front propshaft. Apply the brake and the bevel gears will give you 2 wheel drive with a 2:1 overdrive.yes,I should try to get out more bill. Absolutely fantastic! Posts like that are what makes this place what it is. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 20, 2007 Share Posted May 20, 2007 Are they easily detachable from there original homes?And can they be made to fit on another box? Also whats there availability like, Niva's are getting scarcer now in the UK? Niva t-cases are divorced, so a really easy fit. Quote Link to comment Share on other sites More sharing options...
CosZuki Posted May 20, 2007 Share Posted May 20, 2007 nova boxes can be picked up without too much difficulty, i seem to remeber there bein something about making sure they line up properlly so you get no vibration?!?! i need to try and dig out the link again as i thought about using one on CosZuki before i changed my mind entirely. but they are very strong boxes, especially ppre 92 i believe as thats when they were properly made, as a russian told me. dan that sig looks kinda familiar Quote Link to comment Share on other sites More sharing options...
