russ3120 Posted May 20, 2007 Share Posted May 20, 2007 Just seen this advertised, available from the 24th may, might be of some use? only £99.99 www.aldi.co.uk Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 20, 2007 Share Posted May 20, 2007 Just seen this advertised, available from the 24th may, might be of some use? only £99.99www.aldi.co.uk Are you going to get one so you can weld your spring mounts back on Quote Link to comment Share on other sites More sharing options...
russ3120 Posted May 20, 2007 Author Share Posted May 20, 2007 Are you going to get one so you can weld your spring mounts back on Cheers for that Dave got a stick welder for £50 so done my mounts might get it to weld a new boot floor in though, more rusty disco body. so me thinks its time for some drastic measures ( i can feel some major restyling coming on) Russ Quote Link to comment Share on other sites More sharing options...
rob90 Posted May 26, 2007 Share Posted May 26, 2007 Well I bought one, Tried it out today welding 3 mm plate and was impressed for the money, I used to inspect welds for a firm exporting couplings to the petrochemical industry so have a idea what a good weld is If you want a cheap hobby welder get one If the rain holds of im going to repair and reinforce my rear cross member so I will post some pics Quote Link to comment Share on other sites More sharing options...
