Tiger Posted May 21, 2007 Share Posted May 21, 2007 AQM, ATF, MTF 94 I've got 5 litres of Comma spec stuff for the PAS box, can I just throw this in? Quote Link to comment Share on other sites More sharing options...
white90 Posted May 21, 2007 Share Posted May 21, 2007 I used MTF94 but ATF will suit Quote Link to comment Share on other sites More sharing options...
jameslwt Posted May 21, 2007 Share Posted May 21, 2007 AQM, ATF, MTF 94 I've got 5 litres of Comma spec stuff for the PAS box, can I just throw this in? I went through this last week as it seems the Haynes manual might not be accurate......(But to be fair it does only go up to 1995 vehicles?????? so that might be why) Up to 1995, use ATF post 1995, use MTF HTH James Quote Link to comment Share on other sites More sharing options...
white90 Posted May 21, 2007 Share Posted May 21, 2007 both will suffice though Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted May 21, 2007 Share Posted May 21, 2007 Up to 1995, use ATFpost 1995, use MTF HTH James I seem to recall reading (on this forum?) that it's not dependent on the year of the vehicle - but that the service instruction changed in 95.. . Or was it all a dream? TS Quote Link to comment Share on other sites More sharing options...
western Posted May 21, 2007 Share Posted May 21, 2007 LR say MTF94 can be used in LT77,LT77S & R380 manual gearboxes without problems. or stick with ATF [the normal red fluid] Quote Link to comment Share on other sites More sharing options...
rick Posted May 22, 2007 Share Posted May 22, 2007 a proper manual trans fluid does protect bearings and gears better unless Arctic temps are to be experienced. FWIW, here no gearbox reconditioner will provide warranty if ATF is used. Quote Link to comment Share on other sites More sharing options...
Tiger Posted May 22, 2007 Author Share Posted May 22, 2007 Taken from Ashcrofts site. What oil should I use in my LT77 gearbox? We recommend ATF Dextron 2 or 3. So I'm going with that as they should know, unless its a cunning plan to get more work mwahhhahahaha!!! Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted May 22, 2007 Share Posted May 22, 2007 Taken from Ashcrofts site.What oil should I use in my LT77 gearbox? We recommend ATF Dextron 2 or 3. So I'm going with that as they should know, unless its a cunning plan to get more work mwahhhahahaha!!! Nearly all ATFs are Dextron 2 or 3 compatible Quote Link to comment Share on other sites More sharing options...
Winnet Posted May 25, 2007 Share Posted May 25, 2007 Evolution1 This is the stuff I used in my LT77 gearbox. It is expensive but it makes an amazing difference and well worth it. G. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted May 26, 2007 Share Posted May 26, 2007 Evolution1This is the stuff I used in my LT77 gearbox. It is expensive but it makes an amazing difference and well worth it. G. A difference like being able to get into first when stationary without selecting another gear first? Do you think it's worth me giving it a try or is my box beyond hope? TwoSheds Quote Link to comment Share on other sites More sharing options...
Winnet Posted May 26, 2007 Share Posted May 26, 2007 My gearbox was awkward to get into second (usual LT77 problem) and it cured that and helped improve the whole box. My latest LR 90 a '92 200tdi has a LT77 fitted as well and it feels sticky as well. I have just ordered more Evolution 1 and am pretty confident that it will make the box far smoother. I also found the box continued to improve over the following few weeks. G. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 26, 2007 Share Posted May 26, 2007 Basically anything is better than ATF, especially from a wear point of view. I am surprised at Ashcroft's recommending ATF Dexron II, though. Maybe they need the work? Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted May 26, 2007 Share Posted May 26, 2007 My gearbox was awkward to get into second (usual LT77 problem) and it cured that and helped improve the whole box. My latest LR 90 a '92 200tdi has a LT77 fitted as well and it feels sticky as well. I have just ordered more Evolution 1 and am pretty confident that it will make the box far smoother. I also found the box continued to improve over the following few weeks.G. That's fantastic! Thanks I'll get some on order when I get back from my hols... TwoSheds Quote Link to comment Share on other sites More sharing options...
