Dark green 90 Posted May 24, 2007 Share Posted May 24, 2007 Probably been asked before (if someone could direct me to the thread ) Will 900 x 16 fit a defender 90 with 2" lift? are there any side affects/issues ? (anything need adjusting) thanks. ps. They are on correct size rims already Quote Link to comment Share on other sites More sharing options...
Mark90 Posted May 24, 2007 Share Posted May 24, 2007 These are nominally 34" tall although in practice they do vary a bit between makes but usually 33-35". On a 2" lifted 90 33's will fit with no probs, except maybe adjust your steering stops depending on wheel offset. In addition 35's may need a little arch trimming to stop them catching, but maybe not if on small offset rim. Quote Link to comment Share on other sites More sharing options...
will_warne Posted May 24, 2007 Share Posted May 24, 2007 What Mark said; they should fit without any real problems although you may need to do a bit of arch trimming and you'll touch the top of the wheelboxes on articulation. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 24, 2007 Share Posted May 24, 2007 I've a set of 900x16 michelens that measure nearly 37" tall. these almost certainly won't fit on with just a 2" lift Quote Link to comment Share on other sites More sharing options...
