How noisy...
Well i tested the gearbox out, after fitting with no prop shafts connected and it was lovely and quite.
Then today after adding a rear prop and using a bit of difflock, i shifted the truck forwards and backwards a few feet. The main box is wurring at a noise level similar to a series landrover if not alittle louder. Now
This change in noise would suggest to me that the main bearing is on its way out? or are they generally this noisey in early versions?
any help is greatly appreciated
