white90 Posted June 1, 2007 Share Posted June 1, 2007 dunno then sorry. have you tried it using Tom Tom on the PC? to see if that works Quote Link to comment Share on other sites More sharing options...
rob90 Posted June 1, 2007 Share Posted June 1, 2007 It takes my GPS a good 3-4 mins to warm up before it starts to find any satellites MM doesnt even know its got gps fitted for that time but then after 3-4 mins all starts to work fine try leaving it for a little bit dont expect it to be instantaneous Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted June 1, 2007 Share Posted June 1, 2007 Cheers Rob. Will try that now. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted June 1, 2007 Share Posted June 1, 2007 I run fugawi on my pda and no matter what I did I couldn't get it to work. But, more by luck than judgement I clicked on close GPS and then on Open GPS and voila, it worked. I have since found I need to do this every single time to make it work whenever I open the programme. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted June 1, 2007 Share Posted June 1, 2007 Got the gps working but it's on COM200. MM doesn't give you the option of going that high or renaming the com port so that they talk to each other. Any ideas Quote Link to comment Share on other sites More sharing options...
rob90 Posted June 1, 2007 Share Posted June 1, 2007 Memory Map has a technical forum on its web site which i have found usefull in the past maybe a quick look on their might help you www.memory-map.co.uk/board/ Quote Link to comment Share on other sites More sharing options...
white90 Posted June 1, 2007 Share Posted June 1, 2007 Got the gps working but it's on COM200. MM doesn't give you the option of going that high or renaming the com port so that they talk to each other.Any ideas can you not rename the port on the PC itself? Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted June 2, 2007 Share Posted June 2, 2007 Tried doing that. Had my mate with his PC (in Kent) on the phone for 2hrs talking me through the stages. His will allow you to change port names (xp pro I think) mine XP home won't allow it or we couldn't find anywhere. I may have to take a trip to see someone for a cup of tea and some help :D . Not ideal but may have to be done. Well enough of this I'm off to the Bath & West show now. Quote Link to comment Share on other sites More sharing options...
SteveG Posted June 2, 2007 Share Posted June 2, 2007 GPSGate is very good at fixing all GPS related interface problems. Costs about 5-6 pounds IIRC. Solved all my GPS over USB issues and works on windows and Pocket PC. Franson GPSGate Cheers Steve Quote Link to comment Share on other sites More sharing options...
