Hybrid_From_Hell Posted May 31, 2007 Share Posted May 31, 2007 Hi all, FTC3375 - the bolts that connect the caliper to the casing M12x35mm and SX11025M Bolts that hold the stub axle to the casing M10x25mm Anyone know the rating of either / both ? ie 8.8T 10.8T 12.9T ? HELP Nige Quote Link to comment Share on other sites More sharing options...
western Posted May 31, 2007 Share Posted May 31, 2007 Defender workshop manual shows either the bolt head or one of the side faces of the hex head marked with the tensile rating , no bolt less than 8.8, nothing in EPC about tensile ratings & the SX11025M is missing a digit, it should be SX110251M Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 31, 2007 Share Posted May 31, 2007 FTC3375 is a 10.9 and we don't have any of the others on the shelf at the moment so I can't help with that one... but I have a feeling they are also 10.9 Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 31, 2007 Share Posted May 31, 2007 FTC3375 is dealer only. Unless you have another idea. For which I would be greatful. I tried using a bolt........ The head is too big. An Allen bolt would be the next thing I'll try. mike YES !! England is a free country. As long as you do as you are told. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 31, 2007 Share Posted May 31, 2007 The original bolt would have a 13mm spline head bolt, but you could get a 13mm hex head bolt with the correct thread size and grade to replace the originals. I think a 13mm long reach socket would still do it up. Les. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 31, 2007 Share Posted May 31, 2007 Just looked through my box of axle bits, and the stub axle bolts are 10.9. i've got a couple of caliper bolts, but i can't see what is cast into the end. some wording but i can't see it. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 31, 2007 Share Posted May 31, 2007 FTC3375 is dealer only. Unless you have another idea. For which I would be greatful. Why? I bet if LR won't supply one for sale over the counter, somebody else will supply the same thing under the same number - the usual suspects like Britpart or Bearmach for example. I stand to be corrected though... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 31, 2007 Share Posted May 31, 2007 Why? I bet if LR won't supply one for sale over the counter, somebody else will supply the same thing under the same number - the usual suspects like Britpart or Bearmach for example. I stand to be corrected though... bearmch definately do sell the caliper bolts, as i bought some a few months ago. same part number too. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 31, 2007 Share Posted May 31, 2007 Stratstone Stockton supply me over the counter with them. I fit new every time I remove my callipers. mike YES !! England is a free country. As long as you do as you are told. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 31, 2007 Author Share Posted May 31, 2007 Ta all, Mate arrived with 4x of them this evening and they are 12 sided F awkward B*****d Metric Bolts and 10.9 too, seems the stubs are the same but at least std 6 face So methinks I stand about as much chance as a dealer having them in stock with a cherrie "Yes Sir no Problem" as me trying to 'split the atom' with a dead fish in my left hand whilst riding a unicycle singing 'The hills are alive' Grumpy ?........... Oh Yeah ..........OK ? Nige Quote Link to comment Share on other sites More sharing options...
Mark Posted June 1, 2007 Share Posted June 1, 2007 Nige, Have you tried Premier Supply in Guildford? I am likely to be dropping in there Friday lunchtime if you want me to pick you some up? give me a ring, or a pm or whatever. Cheers Mark Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted June 1, 2007 Share Posted June 1, 2007 You could try ANC in Farnham Nige Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 1, 2007 Share Posted June 1, 2007 I can't see why the head type can have any bearing on the bolt strength. It is probably more to do with space (eg cap head) or anti tamper (12 sided). So long as the grade, thread pitch and length are comparable then any repacement will do IMHO. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 1, 2007 Share Posted June 1, 2007 As I said earlier my dealer keeps them in stock. They come in packs of five !! Yes I know you only need four for an axle set. Should your dealer not have them in stock he should have them the next day. Mine does. It is all to do with the head size. A 12mm bolt head will not fit. Yes I've tried one. I use a Halfords ratchet combination spanner to get at the heads. Specially bought to do that job. mike YES !! England is a free country. As long as you do as you are told. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 1, 2007 Author Share Posted June 1, 2007 Some long drawn out begging and whineing noises down the phone to a mate has sorted that prob out Nige Quote Link to comment Share on other sites More sharing options...
