Timpo Posted June 3, 2007 Share Posted June 3, 2007 Hi. Our 55 TD4 is scrubbing the outer 25% of the contact tread on the nearside rear wheel. Have anyone had similar issues? It's due in for a 24k service soon so not too sure whether to mention it then, but this could be chargable as tyres fall into waring parts. Timpo. Quote Link to comment Share on other sites More sharing options...
MudAllOverIt Posted June 3, 2007 Share Posted June 3, 2007 It's certainly not a common problem. I'd mention it for sure at the next service -- it's a sign that something's not right somewhere. The obvious suspect IMHO is the rear wheel alignment -- not sure what would knock that out other than a servere kerbing. If it was mine I'd be tempted to get the four-wheel alignment checked before worrying about more exotic possible problems. A locked VC or rear diff problems could also cause this but that's unlikely in a 55 car IMHO and I'd also expect it to affect both rear wheels rather than just one. Quote Link to comment Share on other sites More sharing options...
Timpo Posted June 4, 2007 Author Share Posted June 4, 2007 It's certainly not a common problem.I'd mention it for sure at the next service -- it's a sign that something's not right somewhere. The obvious suspect IMHO is the rear wheel alignment -- not sure what would knock that out other than a servere kerbing. If it was mine I'd be tempted to get the four-wheel alignment checked before worrying about more exotic possible problems. A locked VC or rear diff problems could also cause this but that's unlikely in a 55 car IMHO and I'd also expect it to affect both rear wheels rather than just one. OK, I'll book it in for a four wheel alignment. Thanks. T. Quote Link to comment Share on other sites More sharing options...
Timpo Posted June 14, 2007 Author Share Posted June 14, 2007 OK, I'll book it in for a four wheel alignment.Thanks. T. Had the vehicle in today for a new tyre, and a four wheel alignment. The man in the centre said that he has had a couple in recently with excessive tyre wear on n/side. All done now, so I'll see how it goes. Regards. Timpo. Quote Link to comment Share on other sites More sharing options...
