MECCANO Posted June 5, 2007 Share Posted June 5, 2007 So then, 200tdi oil cooler pipes at the filter end. Does any one know the thread size? If you do i may actually have to kiss you *IDIOT i put it in the wrong forum* Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted June 5, 2007 Share Posted June 5, 2007 So then, 200tdi oil cooler pipes at the filter end. Does any one know the thread size? If you do i may actually have to kiss you *IDIOT i put it in the wrong forum* just to complicate matters there are early pipes and later pipes Quote Link to comment Share on other sites More sharing options...
MECCANO Posted June 5, 2007 Author Share Posted June 5, 2007 just to complicate matters there are early pipes and later pipes well all i know is it isnt 1/2"bsp or npt.. so metric??? Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted June 5, 2007 Share Posted June 5, 2007 On my 2.5TD its 1/2"BSP and im sure that our G reg disco 200 was the same. Quote Link to comment Share on other sites More sharing options...
western Posted June 5, 2007 Share Posted June 5, 2007 200Tdi filter head [block end] is common to 2.5n/a & 2.5TD engines too. Quote Link to comment Share on other sites More sharing options...
MECCANO Posted June 5, 2007 Author Share Posted June 5, 2007 200Tdi filter head [block end] is common to 2.5n/a & 2.5TD engines too. Problem solved. Yes your right it is BSP.I tried the other hole and the fitting flew in. Some one has nicely crudded up the one i was trying to use Quote Link to comment Share on other sites More sharing options...
Br00n1e Posted June 5, 2007 Share Posted June 5, 2007 Problem solved. Yes your right it is BSP.I tried the other hole and the fitting flew in. Some one has nicely crudded up the one i was trying to use Aye you have tae mak sure you get it in the richt hole :rolleyes: Quote Link to comment Share on other sites More sharing options...
