no reverse gear
the reverse light never worked beforehand as one of the connectors was snapped off. there's literally no drive when its in reverse. 1st 2nd and 3rd all work fine just no backwards movement when its selected. any advice is welcomed with open arms
Sure its not just the rev light switch that needs adjusting/replacing?
I think what LR90 ment was that the reverse light switch can physically prevent reverse being selected by it being screwed to far in.
HTH
Pete.
thanks for the advice. worked a treat and saved a great deal of time. just got to put the floor back in etc as i thought the box was coming out. bit of a change of topic but do you know if you can take the wires off and wire them to a switch that would run a work light at the back?
If you fit a manual switch for the reverse lights it MUST have a in cab tell tale warning light, so you can see when the reverse lights are on, or just fit a new switch to the gearbox & keep the automatic operation then no telltale is required.
