western Posted September 2, 2007 Share Posted September 2, 2007 (edited) Thanks, got the fuel gauge/sender/low fuel light wiring sussed now with your help got most of the other wires identified & labelled ready for fit too, just the ones in my earlier reply to identify now Edited September 2, 2007 by western Quote Link to comment Share on other sites More sharing options...
western Posted September 2, 2007 Share Posted September 2, 2007 think I've got all the wire colours sussed now, no traction control or abs wiring on the instrument pack, also I won't need the check engine & engine immobilsers, water in fuel sensor warning lights either. still thinking of just using the gauges/speedo with my existing warning light unit, will try it for a while & see how I get on with them after a while. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 2, 2007 Share Posted September 2, 2007 Right, 0230-6 to -10 red/slate - wiring combination to turn off ABS light function 0230-9 to -13 black/white - wiring combination to switch off brake fluid light, connect 0230-14 to brake level switch 0230-2 yellow/black - not needed 0233-6 120km/h speed limiter warning light HTH Ralph Mo Quote Link to comment Share on other sites More sharing options...
western Posted September 2, 2007 Share Posted September 2, 2007 Thanks Mo sure does, just powered up each of the warning lights as far as the wiring in the 2 plugs goes & have labelled all of them, no more spare wires to ident now. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 28, 2007 Share Posted September 28, 2007 Going from Nick orange90's question, a ) here's the wobbly wibbly thread Nick b ) Here is a complete Td5 dash for only £30 at the mo on eblag. nothing to do with me Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 4, 2007 Share Posted October 4, 2007 Anyone else need a dash? one here in Swindon where Les and I reside. no bids yet. Quote Link to comment Share on other sites More sharing options...
western Posted October 4, 2007 Share Posted October 4, 2007 I've decided to only fit the Td5 electronic speedo & fuel & temp gauges to my '89 110, I prefer my existing warning light panel as it has other lights in that the Td5 panel doesn't give me. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 10, 2007 Share Posted November 10, 2007 Just in case anyone else was contemplating doing this conversion, here's another cheap Td5 dash on eblag Quote Link to comment Share on other sites More sharing options...
western Posted November 10, 2007 Share Posted November 10, 2007 I haven't done much more to mine except to change the speedo total reading to the correct for my 110, need to run the lekky drill for a bit longer yet as it's got to increase the reading by 159,000 to match the old speedo. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 11, 2007 Share Posted November 11, 2007 All the stuff on my dash is still working marvellously If only I could find out why it won't save the trip meter reading, minor I know but I like these things to work as they should. Mo Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2007 Share Posted November 11, 2007 Looking at mine the trip reading would need a permanent 12v feed to keep it intact, just increasing the total reading on mine, & everytime I switch off the power supply the trip reverts to a 0.0 reading, it's OK if the power is left on. one of the wires needs a permanent feed via a 5amp fuse, maybe thats the trip save wire. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 11, 2007 Share Posted November 11, 2007 Ah, not just me then More detective work required methinks. Mo Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2007 Share Posted November 11, 2007 the wire that needs a 5amp fused supply is Brown/Blue trace. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 11, 2007 Share Posted November 11, 2007 Are you saying that this is the one to retain the trip meter reading, Ralph ? edit - just checked, that's the permanent 12v supply, Ralph which charges the battery inside the speedo. I have that one connected. Mo Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2007 Share Posted November 11, 2007 Are you saying that this is the one to retain the trip meter reading, Ralph ?Mo thought it was, but I'm wrong, looking at all the wiring info we've got within the thread, the brown/blue is for the alarm led., there's a purple/white that's a permanent live feed on pin 9 of the upper connector block that might be the one to save the trip reading. but don't quote me Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 11, 2007 Share Posted November 11, 2007 thought it was, but I'm wrong, looking at all the wiring info we've got within the thread, the brown/blue is for the alarm led., there's a purple/white that's a permanent live feed on pin 9 of the upper connector block that might be the one to save the trip reading.but don't quote me No, Ralph, brown/blue is perm live, alarm is pink. I can't find a purple/white in the wiring diagrams but I can find a purple/brown going to pin 9 of the 1060 connector. I'll investigate further. Mo Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2007 Share Posted November 11, 2007 No, Ralph, brown/blue is perm live, alarm is pink. I can't find a purple/white in the wiring diagrams but I can find a purple/brown going to pin 9 of the 1060 connector. I'll investigate further.Mo so that means some of the wiring info above is incorrect then. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 11, 2007 Share Posted November 11, 2007 Purple/brown going in on pin 9 goes to the alarm/immobiliser light in the speedo head. Another dead end Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2007 Share Posted November 11, 2007 wonder if it's done by a internal link then within the speedo head. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 11, 2007 Share Posted November 11, 2007 I would assume so Ralph but it's not working on either of my 2 speedos or yours so there is something we need to do to make it save (unless all three speedos are faulty, which I doubt). I wonder what it is ? Mo Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2007 Share Posted November 11, 2007 just had a play with mine, as it's indoors & racking up the total reading, with the power supply on & transducer running, I've disconnected the white/green feed & the mileage/trip reading went out, when I reconnected it the readings came back to thier previous digits. Quote Link to comment Share on other sites More sharing options...
western Posted November 30, 2007 Share Posted November 30, 2007 sent the speedo off to Digidash to have the total reading adjusted [increased] to match my 110's existing total reading, so while I'm on my Xmas holiday I can fit the new electronic speedo/fuel & temp gauges, still not sure if I'll use the illuminated heater slide parts or the Td5 warning light part. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 30, 2007 Share Posted November 30, 2007 sent the speedo off to Digidash to have the total reading adjusted [increased] to match my 110's existing total reading, I bet that took them aback, when you asked them to increase the milage!! Quote Link to comment Share on other sites More sharing options...
western Posted November 30, 2007 Share Posted November 30, 2007 I bet that took them aback, when you asked them to increase the milage!! He was fine about it, no awkward questions just wanted to know that it was a increase & the existing mileage total, sent it last Friday afternoon & due to the weekend [no delivery] it arrived @ digidash on Monday, got it back this Weds just gone, really quick service & less than 80quid inc post/packing [came back in the wrapping I sent it in] to sort it, much quicker than trying to add it myself with a electric drill & transducer, I can fine tune the total reading just before fitting the speedo & transducer & the loom you made for me Quote Link to comment Share on other sites More sharing options...
Ian M Posted December 30, 2007 Share Posted December 30, 2007 how much did the transducer cost? and where from? Quote Link to comment Share on other sites More sharing options...
