OT: Memory Map and Fugawi
Is it possible to use the maps supplied with Fugawi with Memory Map and if it is how do you do it please?
The reason I ask is that I may be able to get all the UK 1:50000 O.S. maps in a digital format from the Fugawi that we use at work but I am already using memory map and don't really want to change. I will share the maps with all on here if I can get them.
Secondly, Was trying to export waypoint data from Fugawi into Memory Map but it seems that no matter what format I try memory map won't recognise them any ideas as to get round this?
Cheers
Pete.
Not sure about the answer, but I use OS 1:50K on Oziexplorer …………. I think fugawi is the same in as much that you would need to calibrate each map tile to the software, although a pain……..its an easy task………..
If getting your maps from work is an issue, then pm me ………..all of the UK fits on a DVD …….. ;)
Ian
