dreadnought110 Posted June 7, 2007 Share Posted June 7, 2007 If any one wants to swap there land rover gauge for a more reliable vdo gauge i now have the part no.s Quote Link to comment Share on other sites More sharing options...
madmatt Posted June 7, 2007 Share Posted June 7, 2007 If any one wants to swap there land rover gauge for a more reliable vdo gauge i now have the part no.s does that mean you get an accurate reading now? If VDO do a fuel and Rev counter I could have 3 matching gages in mine!!! Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2007 Share Posted June 8, 2007 The VDO rev counter is a good match for the standard LR gauges, I've got the V8 anniversary version in my 110. have a read of this thread Quote Link to comment Share on other sites More sharing options...
JimC Posted June 8, 2007 Share Posted June 8, 2007 You mean these numbers?: 300 Tdi: 350-104 2 1/16 80 PSI Elec. engine pressure gauge Vision $25.75 360-006 Pressure Sender: 0-80 PSI/5 Bar - M10x1K - 7.0 PSI $28.37 333-156 2 1/16 4,000 RPM Tachometer Vision $74.81 310-105 2 1/16 250F Elec. engine temp gauge Vision $25.55 323-095 Temperature Sender: 250F/120C - 1/8-27 NPT - $7.31 310-153 2 1/16 250F-1650F Pyrometer (EGT) Vision Marine $153.75 1994 3.9 V8 323-417 Temperature Sender: 250F/120C - M16x1.5 - $18.82 310-105 2 1/16 250F Elec. engine temp gauge Vision $25.55 350-104 2 1/16 80 PSI Elec. engine pressure gauge Vision $25.75 360-009 Pressure Sender, 0-80PSI/5 Bar - 1/8-27 NPT $33.34 5-1/8 F50G-S Adapter Fitting: Parker Hydraulics - $11 All these parts were sourced from eguages.com, which is a US company, so all the readings are psi, fahrenheit, etc. Also, these guages have words like "temp" "pressure" etc, because its a US requirement to have actual words. We're not smart enough for icons. The senders are the really important stuff though, the sizes being the main challenge. I've personally used each of these parts and can vouch for the correcness of the list. Note that an old oil pressure sender can have the center knocked out and a bung can be welded on to create a cheap adapter. Quote Link to comment Share on other sites More sharing options...
western Posted June 8, 2007 Share Posted June 8, 2007 JimC --- Note that an old oil pressure sender can have the center knocked out and a bung can be welded on to create a cheap adapter. just like this one VDO water temp sender into 200Tdi sender Quote Link to comment Share on other sites More sharing options...
