Landyandy Posted June 9, 2007 Share Posted June 9, 2007 Hi. Thinking of getting some waxoil into the top corners of my 300tdi 90 bulkead. Has anyone tried drilling a hole from the inside and using one of those waxoil flexible adaptors nozzles to spray some in? Or is there a better way? Here is where I mean.. Thanks Andy Quote Link to comment Share on other sites More sharing options...
western Posted June 9, 2007 Share Posted June 9, 2007 take the top door hinge bolts out & move the hinge block away from the bulkhead [keep the door shut & don't use to much force when you put the bolts back afterwards] shove the tube in there, you should be able to guide it to the top, the bolts in your pic go through tube within a box section inside the bulkhead & where you propose to drill does too, [i found that out when doing repairs to my bulkhead] so shoving the tube into them will just put waxoyl outside all over the front wing, might also be possible to extract the rubber blanks [meant for LHD wipers] on below the screen & guide the tube in there too. Quote Link to comment Share on other sites More sharing options...
Landyandy Posted June 10, 2007 Author Share Posted June 10, 2007 Thanks for that. When you take the hinge bolts out, do the nuts behind stay in place or is there a chance they will fall? Andy. Quote Link to comment Share on other sites More sharing options...
western Posted June 10, 2007 Share Posted June 10, 2007 (edited) Thanks for that.When you take the hinge bolts out, do the nuts behind stay in place or is there a chance they will fall? Andy. the bulkhead nuts are captive BUT the can & do breakout of their cages, so if that happens you'll have to cut or drill the bolt head off & replace the parts as required. they slide in throught the rectangular hole & clip into place like this ---- Edited June 10, 2007 by western photo added Quote Link to comment Share on other sites More sharing options...
