Height of Wheel Arch Eyebrow
Can some one please measure the height of the middle of the front wheel arch eyebrow on their standard 300tdi 130. Mine sagged when I put on a large winch and bull bar. I have now put on some other springs and it is sitting at 91cm from the floor to the wheel arch eyebrow. The 130 is on michelin XZY 7.50-16 Tyres.
Better to measure the eyebrow to the centre of the wheel, this will remove any variations caused by tyre size or tyre wear :)
I don't have this figure as I have a winch on mine, meant to measure it before I put the winch on so I could work out what I needed to do but I forgot :(
The other thing is that the 130 front springs are about the strongest LR springs that will fit anyway - they are the same as 90 HD rears I think - so you will need to go to aftermarket springs to do anything with it.
my 200Tdi 110CSW sits at 89cm from ground to centre lower edge of front wheel arch flare & it's 51.5cm from centre of the wheel centre cap, my 110 is on OME springs 751's IIRC with a Husky & matching winch bumper & RUNS ON 255/85 BFG MT's
hth :D
 Share
