Nato Hitch Spreader plate
Se7enUp
 Share
I have a friend who can make me a couple of spreader plates for my newly aquired Nato Hitch.
Does anyone here have a diagram, drawing or a plan showing the required dimensions of the plates and location/diameter of the holes.
(I'm putting a plate on both the front and rear of the crossmember)
I'm knowhere near my Landie at the moment co can't get to measure it up :(
Any help appreciated
Guest diesel_jim
The plate is about 5 or 6mm thick IIRC. not sure about the external dimension, but it's only got to fit in the gap behind the crossmember.
the holes for the hitch bolts are:
13/4" x 33/8" (thats 44.5mm x 85.72mm)
diameter is 9/16" (14.27mm)
these are taken from the dixon bate spec sheet for the hitch.
Hi,
made this for mine, IIRC.......
Outer plate 200 x 140 x 10mm, drilled 86x44.5, holes positioned central & 40mm down from top edge.
Inner plate 200 x 130 x 10mm, centralized (5mm top/btm).
Drilled 13mm dia & secured with M12 bolts.
Rod :)
 Share
