nick8556 Posted June 15, 2007 Share Posted June 15, 2007 Hello Does anyone know where i can get longer than standard front half shafts? Many thanks Nick Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 15, 2007 Share Posted June 15, 2007 No - but curious as to why you need them, all the axles are the same length AFAIK? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 16, 2007 Share Posted June 16, 2007 I suppose if you wanted a wider vehicle footprint you could quite easily extend the axle tubes and then fit a longer driveshaft. Getting a driveshaft extended or a longer one made would be expensive I imagine though. Les. Quote Link to comment Share on other sites More sharing options...
russ3120 Posted June 16, 2007 Share Posted June 16, 2007 I suppose if you wanted a wider vehicle footprint you could quite easily extend the axle tubes and then fit a longer driveshaft.Getting a driveshaft extended or a longer one made would be expensive I imagine though. Les. i would just add wheel spacers to get a wider foot print, easier and cheaper. very curious to the reasons for longer half shafts Russ Quote Link to comment Share on other sites More sharing options...
nick8556 Posted June 16, 2007 Author Share Posted June 16, 2007 Hello All Thanks for the replies the reason for the longer half shafts is you can't use wheel spacers in competitions! Regards Nick Quote Link to comment Share on other sites More sharing options...
russ3120 Posted June 16, 2007 Share Posted June 16, 2007 Hello AllThanks for the replies the reason for the longer half shafts is you can't use wheel spacers in competitions! Regards Nick good reason Quote Link to comment Share on other sites More sharing options...
Anorak_Stan Posted June 26, 2007 Share Posted June 26, 2007 I would suggest speaking to Ashcroft as they Make HD Halfshafts, ~Maybe they could do longer ones as well ? LJC Quote Link to comment Share on other sites More sharing options...
Mark Posted June 26, 2007 Share Posted June 26, 2007 You can use wider offset rims in comps though - and it would be a lot cheaper to knock the centre's out of some disco rims, reverse them and weld them back where you wanted them than getting special shafts made up??? just a thought Quote Link to comment Share on other sites More sharing options...
