Martin90 Posted June 15, 2007 Share Posted June 15, 2007 My Mazda engine has a stop solenoid with three wires on it. the black is to earth, the white is connected to the starter solenoid and is live when cranking the engine only, this is the way it wa in the RR and it worked fine there so assume it's correct. This leaves the red wire, can anyone tell me where it should go please? Cheers, Martin Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted June 15, 2007 Share Posted June 15, 2007 My Mazda engine has a stop solenoid with three wires on it. the black is to earth, the white is connected to the starter solenoid and is live when cranking the engine only, this is the way it wa in the RR and it worked fine there so assume it's correct. This leaves the red wire, can anyone tell me where it should go please?Cheers, Martin Possibly to the ignition switch????????? Quote Link to comment Share on other sites More sharing options...
Martin90 Posted June 17, 2007 Author Share Posted June 17, 2007 Possibly to the ignition switch????????? Thanks but that didn't work! Any other ideas anyone? Cheers, Martin Quote Link to comment Share on other sites More sharing options...
