currymonster Posted June 16, 2007 Share Posted June 16, 2007 hello. can any body help me wire a 3.9 v8 flap type injection into my hybrid? the wires coming from the main 110 loom are- WHITE/RED TWO BROWNS GREEN/BLUE BROWN/YELLOW BROWN/WHITE BLACK/WHITE wires coming from the engine loom harness are- BROWN WHITE/SLATE WHITE/PURPLE BLACK/YELLOW YELLOW ORANGE/BLACK PURPLE/YELLOW any help would be great. thanks, martin Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 16, 2007 Share Posted June 16, 2007 I have no idea what the wires from the 110 do, the colours suggest the following functions: WHITE/RED - Starter solenoid (+12v when cranking) TWO BROWNS - Permanent +12v live The rest I can't be certain off the top of my head. As for the EFI loom you probably want to check the wiring diagram but the Haynes Book Of Lies says: BROWN - +12v permanent feed WHITE/SLATE - fuel pump relay coil, wire to ignition switched live WHITE/PURPLE - From fuel pump relay to fuel pump VIA A FUSE (10A should be plenty) BLACK/YELLOW - EFI warning light on dashboard, you can leave this disconnected YELLOW - From road speed transducer ORANGE/BLACK - To auto box neutral switch (I guess this is the start inhibit?) the wire is grounded by the switch but I dunno if that's "ground it to make it work" or "ground it to stop it working" PURPLE/YELLOW - To heated screen, you can probably leave this disconnected although it would serve as a handy "idle up" input if you have anything engine-driven like a winch or compressor. Quote Link to comment Share on other sites More sharing options...
streaky Posted June 17, 2007 Share Posted June 17, 2007 I did a cut and paste of this. Some parts may be usefull. Vehicle Wiring Colour Code Table Many British designed vehicles use colour coded cables to assist in identifying the various circuits in use. This is an extract from BS-AU7a 1983 Colour Code for Vehicle Wiring, from the British Standards Institution, 2 Park St., London W1A 2BS. Note that these colour codes may not apply directly to older vehicles. For example, the wipers on vehicles up to 1980 (at least) are not on a separate fuse circuit, so they are not orange, but green. Check the schematic for your vehicle to be certain. MAIN TRACER PURPOSE Black All earth connections Black Brown Tachometer generator to tachometer Black Blue Tachometer generator to tachometer Black Red Electric or electronic speedometer to sensor Black Purple Temperature switch to warning light Black Green Relay to radiator fan motor Black Light green Vacuum brake switch or brake differential pressure valve to warning light and/or buzzer Black White Brake fluid level warning light to switch and handbrake switch, or radio to speakers Black yellow Electric speedometer Black Orange Radiator fan motor to thermal switch Blue Lighting switch (head) to dip switch Blue Brown Headlamp relay to headlamp fuse Blue Red Dip switch to headlamp dip beam fuse Fuse to right-hand dip headlamp Blue Light green Headlamp wiper motor to headlamp wash pump motor Blue White a) Dip switch to headlamp main beam fuse B) Headlamp flasher to main beam fuse c) Dip switch main beam warning light d) Dip switch to long-range driving light switch Blue Yellow Long-range driving light switch to lamp Blue Black Fuse to right-hand main headlamp Blue Pink Fuse to left-hand dip headlamp Blue Slate Headlamp main beam fuse to left-hand headlamp or inboard headlamps when independently fused Blue Orange Fuse to right-hand dip headlamp Brown Main battery lead Brow Blue Control box (compensated voltage control only) to ignition switch and lighting switch (feed) Brown Red Compression ignition starting aid to switch Main battery feed to double pole ignition switch Brown Purple Alternator regulator feed Brown Green Dynamo 'F' to controlboxl 'F' Alternator field 'F' to control box 'F' Brown White Ammeter to control box Ammeter to main alternator terminal Brown Yellow Alternator to 'no charge' warning light Brown Black Alternator battery sensing lead Brown Slate Starter relay contact to starter solenoid Brown Orange Fuel shut-off (diesel stop) Green Accessories fused via ignition switch Green Brown Switch to reverse lamp Green Blue Water temperature gauge to temperature unit Green Red Direction indicator switch to left-hand flasher lamps Green Purple Stop lamp switch to stop lamps, or stop lamp switch to lamp failure unit Green Light green Hazard flasher unit to hazard pilot lamp or lamp failure unit to stop lamp bulbs Green White Direction indicator switch to right hand flasher lamps Green Yellow Heater motor to switch single speed (or to 'slow' on tow- or three-speed motor) Green Black Fuel gauge to fuel tank unit or changeover switch or voltage stabilizer to tank units Green Pink Fuse to flasher unit Green Slate a) Heater motor to switch ('fast' on two or three-speed motor) B) Coolant level unit to warning light Green Orange Low fuel level switch to warning light Light green Instrument voltage stabilizer to instruments Light green Brown Flasher switch to flasher unit Light green Blue a) Flasher switch to left-hand flasher warning light B) Coolant level sensor to control unit c) Test switch to coolan level control unit Light green Red Fuel tank changeover switch to right-hand tank unit or entry and exit door closed switch to door actuator Light green Purple Flasher unit to flasher warning light Light green Green Start inhibitor relay to change speed switch; or switch to heater blower motor second speed on three-speed unit Light green White Low air pressure switch to buzzer and warning light Light green Yellow Flasher switch to right-hand warning light; or differential lock switch to differential lock warning light Light green Black Front screen jet switch to screen jet motor Light green Slate Fuel tank changeover switch to left-hand tank unit; or entry and exit door open switch to door actuator Light green Orange Rear window wash switch to wash pump; or cab lock-down switch to warning light Orange Wiper circuits fused via ignition switch Orange Blue Switch to front screen wiper motor first speed timer or intermittent unit Orange Green Switch to front screen wiper motor second speed Orange Black Switch to front screen wiper motor parking cicuit, timer or intermittent unit Orange Purple Timer or intermittent unit to motor parking circuit Orange White Timer or intermittent unit to motor parking circuit Orange Yellow Switch to headlamp or rear window wiper motor feed, timer or relay coil Orange Light green Switch to headlamp or rear window wiper motor parking circuit timer or relay coil Orange Pink Timer or relay to headlamp or rear window wiper motor feed Orange Slate Timer or relay to headlamp or rear window wiper motor parking circuit Pink white Ballast terminal to ignition distributor Purple Accessories fed direct from battery via fuse Purple Brown Horn fuse to horn relay when horn is fused separately Purple Blue Fuse to heated rear window relay or switch and warning light Purple Red Switches to map light, under bonnet light, glove box light and boot lamp when fed direct from battery fuse Purple Green Fuse to hazard flasher Purple Light green Fuse to relay for screen demist Purple White Interior lights to switch (subsidiary circuit door safety lights to switch) Purple Yellow Horn to horn relay Purple Black Horn to horn relay to horn push Purple Pink Rear heated window to switch or relay Purple Slate Aerial lift motor to switch up Purple Orange Aerial lift motor to switch down Red Main feed to all circuits mastered by sidelamp switch Red Brown Rear fog guard switch to lamps Red Blue Front fog lamp fuse to fog lamp switch Red Purple Switches to map light, under bonnet light, glove box light and boot lamp when sidelamp circuit fed Red Green Bulb failure unit to right-hand-side and rear lamps Red White a) Sidelamp fuse to right-hand side and rear lamps B) Sidelamp fuse to panel light rheostat c) Fuse to panel light switch or rheostat d) Fuse to fibre optic source Red Yellow Fog lamp switch to fog lamp or front fog fuse to fog lamps Red Black Left-hand,sidelamp fuse to side, tail and number plate lamps Red Pink Sidelamp fuse to lighting relay Red Slate Lamp failure unit to left-hand side and tail lamps Red Orange Fusebox to rear fog guard switch Slate Window lift main lead White Ignition switch or starter solenoid to ballast resistor White Brown Oil pressure switch to warning light or gauge, or starter relay to oil pressure switch White Blue Choke switch to choke solenoid (unfused) and/or choke to switch to warning light, or electronic ignition distributor to drive resistor White Red Starter switch to starter solenoid or inhibitor switch or starter relay or ignition (start position) to bulb failure unit White Purple Fuel pump no 1 or right-hand to changeover switch White Green Fuel pump no 2 or left-hand to changeover switch White Light green Start switch to starter interlock or oil pressure switch to fuel pump or start inhibitor switch to starter relay or solenoid White Yellow Ballast resistor to coil or starter solenoid to coil White Black Ignition coil contact breaker to distributor contact breaker, or distributor side of coil to voltage impulse tachometer White Pink Ignition switch to radio fuse White Slate Current tachometer to ignition coil White Orange Hazard warning lead to switch Yellow a) Overdrive B) Petrol injection c) Door locks d) Gear selector switch to start As I said at the top.....I couldn't verify 100% that this is all correct for your vehicle, but it might be helpfull if you were completetly stuck. Regards. S Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 17, 2007 Share Posted June 17, 2007 Many of those are indeed correct for the main wiring harness, but with the engine looms LR threw it away and made their own thing up (or used a different standard - the flapper and hotwire colours are different too). Generally the brown = live, white = ignition switched live and black = ground thing holds up anywhere but after that I'd seek out the wiring diagram. I'm pretty sure it's been posted on this forum. Quote Link to comment Share on other sites More sharing options...
Coastcard Posted June 17, 2007 Share Posted June 17, 2007 I have just done this and put details of how I did it on my V8 Auto Conversion topic in Members vehicles. I didn't include the 10a fuse in the fuel pump line though. FF is knowledgeable, so probably do as he says!! FF (welcome back and congrats ), is there a fuse in the original pump line, coz I couldn't see one on the LR wiring diagram. Can you explain your wisdom please for the benefit of all. Also the V8 Owners Forum - Electrical section has a Sticky at the top with the EFI wiring diagram and an explanation. It is fairly logical once you get your head round it, but definately worth some time planning the best routing. Good luck. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 17, 2007 Share Posted June 17, 2007 The HBOL says it's Fuse 18 in a RR which is 10A, and I didn't realise I would need to explain why putting a fuse in a circuit is a good idea but basically blown fuse is preferable to car on fire Quote Link to comment Share on other sites More sharing options...
Coastcard Posted June 18, 2007 Share Posted June 18, 2007 blown fuse is preferable to car on fire Not the way things are going here at the moment I based mine on the Defender diagram. Maybe less to burn in one of these . As said above wisdom would probably dictate a fuse. Quote Link to comment Share on other sites More sharing options...
