kiall Posted June 17, 2007 Share Posted June 17, 2007 From my flexi hose at the t-pieace on my 110 with brake discs on the back i have a leak , had to renew them all for the mot , at the flare at the rear pipe running along the chassis , need a male taper and the brass t pieace needs a male if i can remember rightly but the hose is male one end and female the other , what am i doing wrong i havent had time to have a proper look but doesn anyone have any advice ? Quote Link to comment Share on other sites More sharing options...
JST Posted June 17, 2007 Share Posted June 17, 2007 Kiall, i am not sure what you are really asking here. where is it leaking in the pipe to union join itself or the pipe union to T piece? you description is correct, pipe is male both ends. try PTFE tape if its a pipe union to t piece leak, if its pipe to pipe union leak then new pipe needed i would suggest. Quote Link to comment Share on other sites More sharing options...
kiall Posted June 17, 2007 Author Share Posted June 17, 2007 basically its leaks where it goes into the t pieace , do u think ptfe will do it even liquid ptfe ? Quote Link to comment Share on other sites More sharing options...
JST Posted June 18, 2007 Share Posted June 18, 2007 not sure, guess you could try it, failing that replace the T piece and the hose. Quote Link to comment Share on other sites More sharing options...
