pinny Posted June 17, 2007 Share Posted June 17, 2007 does anyone know part number for these tiny bulbs which illuminate the switches heated rear screen fog lights etc it appears lucas dont do these bulbs any part no appreciated cheers chris Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted June 17, 2007 Share Posted June 17, 2007 go to a breaker and fill your pockets with em. The switches on Maestros, montegos, metros etc of the same era are identical internally. Probably others use em too. Quote Link to comment Share on other sites More sharing options...
RRX Posted June 18, 2007 Share Posted June 18, 2007 go to a breaker and fill your pockets with em. The switches on Maestros, montegos, metros etc of the same era are identical internally. Probably others use em too. Can't remember seeing either a maestro, montego or old metro in a scrapyard for years, thought they had all been squashed by now Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted June 18, 2007 Share Posted June 18, 2007 Probably right mate. Some of us are still living in the past! :lol: Quote Link to comment Share on other sites More sharing options...
Thys Posted July 13, 2007 Share Posted July 13, 2007 does anyone know part number for these tiny bulbs which illuminate the switches heated rear screen fog lights etc it appears lucas dont do these bulbs any part no appreciated cheers chris Chris I don't know if Land Rover part numbers differs from Country to Country, but I got 5 from Land Rover Centurion, in South Africa, with the following part number: STC1878. 68 6c7 A0309986 B47PG and with a note "Made in UK" Due to the geographical constraints this is probably useless information, but what I did discover after bying 5 bulbs & holders, was that only one bulb was actually blown. The other 4 made poor contact, and after cleaning the contact surfaces, and "lifting then very slightly, the lights worked! My reply is one month later, but hope this helps! Thys Quote Link to comment Share on other sites More sharing options...
pinny Posted July 13, 2007 Author Share Posted July 13, 2007 ChrisI don't know if Land Rover part numbers differs from Country to Country, but I got 5 from Land Rover Centurion, in South Africa, with the following part number: STC1878. 68 6c7 A0309986 B47PG and with a note "Made in UK" Due to the geographical constraints this is probably useless information, but what I did discover after bying 5 bulbs & holders, was that only one bulb was actually blown. The other 4 made poor contact, and after cleaning the contact surfaces, and "lifting then very slightly, the lights worked! My reply is one month later, but hope this helps! Thys thanks for that ill try yhat part no chris Quote Link to comment Share on other sites More sharing options...
