stu666 Posted June 18, 2007 Share Posted June 18, 2007 Hi All, Having fitted a winch bumper, winch and steering guard to my 300tdi I found that the weight has dropped the front by 20mm. Any suggestions as to which springs I should fit to raise it back up 20mm? Should I consider replacing front and rear springs at the same time? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
disco tony Posted June 18, 2007 Share Posted June 18, 2007 Hi All,Having fitted a winch bumper, winch and steering guard to my 300tdi I found that the weight has dropped the front by 20mm. Any suggestions as to which springs I should fit to raise it back up 20mm? Should I consider replacing front and rear springs at the same time? Thanks in advance. personally, i'd get 20mm bigger springs!!! Quote Link to comment Share on other sites More sharing options...
RRX Posted June 18, 2007 Share Posted June 18, 2007 Do you have a lift kit already or are you running standard springs? Quote Link to comment Share on other sites More sharing options...
streaky Posted June 19, 2007 Share Posted June 19, 2007 I fitted a new set of HT & Dobinson Springs to my Discovery and shortly afterwards an ARB Winch bumper with Ramsey unit fell into my lap. The weight bought the front down by approx 25mm. My mate Dave gave me a pair of 30mm aluminium spacers which have bought the ride back to the perfect height again. I know that OME make urethane spacers too. It seems a shame to throw away a decent set of springs when a cheap set of spacers will rectify the situation. Quote Link to comment Share on other sites More sharing options...
moose Posted June 19, 2007 Share Posted June 19, 2007 and shortly afterwards an ARB Winch bumper with Ramsey unit fell into my lap. bet that hurt sorry spacers would be the cheaper option and would not change the ride as the spacers are incompressible..... Quote Link to comment Share on other sites More sharing options...
stu666 Posted June 19, 2007 Author Share Posted June 19, 2007 Hi All,Having fitted a winch bumper, winch and steering guard to my 300tdi I found that the weight has dropped the front by 20mm. Any suggestions as to which springs I should fit to raise it back up 20mm? Should I consider replacing front and rear springs at the same time? Thanks in advance. RRX, I am running on standard springs. STREAKY, Where did your mate Dave get the spacers from? This seems like the best solution. Quote Link to comment Share on other sites More sharing options...
disco tony Posted June 19, 2007 Share Posted June 19, 2007 Hi All,Having fitted a winch bumper, winch and steering guard to my 300tdi I found that the weight has dropped the front by 20mm. Any suggestions as to which springs I should fit to raise it back up 20mm? Should I consider replacing front and rear springs at the same time? Thanks in advance. stu, new(ish) post about diff lock testing on here, read on! Quote Link to comment Share on other sites More sharing options...
stu666 Posted June 20, 2007 Author Share Posted June 20, 2007 stu, new(ish) post about diff lock testing on here, read on! Tony, have read it and will give it a go when the disco's back. Quote Link to comment Share on other sites More sharing options...
q-rover Posted June 22, 2007 Share Posted June 22, 2007 Have a look down this page. LR make them as well. Quote Link to comment Share on other sites More sharing options...
