discojmz Posted June 18, 2007 Share Posted June 18, 2007 just removed the window ecu from the housing in my 96 300tdi to resolder a dry solder joint and regain useage of the electric rear windows. as i was prising the end panel away to slide out the board, my screwdriver slipped and literally just tapped the corner of that green box below, the lucas branded one. instantly it started ticking from its relays and making the indicators all flash round the car. when disconnected it causes the alarm siren to go off, and i have no remote central locking or alarm control now although the car will start etc. if i tap the box again, whether plugged in or not, i get a buzzing sound but i cant single out which component it is coming from i can supply part numbers and a photo if needed, im hoping someone will have come across this problem before! thanks guys Quote Link to comment Share on other sites More sharing options...
