rslandys3 Posted June 18, 2007 Share Posted June 18, 2007 How silly / doable would this be? 2.25 petrol block, 2.5 cam and crank, 19J turbo and manifolds, suck through su carb and water injection? Would it blow up? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 18, 2007 Share Posted June 18, 2007 I think the cams are same anyway, but I believe you benefit from put a diesel cam in a petrol model . I think that the engine would go bang at some point unless it has the same compression ratio as a TD. Might be fun to give it a go though if you happen to have the bits lying about. Les. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted June 19, 2007 Share Posted June 19, 2007 How silly / doable would this be?2.25 petrol block, 2.5 cam and crank, 19J turbo and manifolds, suck through su carb and water injection? Would it blow up? I think that you will find that the ports in the petrol head wont line up with the 19J manifolds. Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted June 19, 2007 Share Posted June 19, 2007 How silly / doable would this be?2.25 petrol block, 2.5 cam and crank, 19J turbo and manifolds, suck through su carb and water injection? Would it blow up? I had the same (crazy?) idea a while back, I was informed by Alan Allard who built suck through installations on LR years ago that you can't stop the carb icing satisfactorily even with water heated manifolds etc, it really needs to be EFI. Didn't know about the ports not being the same though . Andy Quote Link to comment Share on other sites More sharing options...
Diff Posted June 19, 2007 Share Posted June 19, 2007 I had the same (crazy?) idea a while back, I was informed by Alan Allard who built suck through installations on LR years ago that you can't stop the carb icing satisfactorily even with water heated manifolds etc, it really needs to be EFI. Didn't know about the ports not being the same though .Andy yep, petrol heads have the inlet and exhaust ports all in a line, whereas the TD head has the inlet and exhaust ports at slightly different heights. Regards, Diff Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 19, 2007 Share Posted June 19, 2007 Well the EFi bit is doable, MS and 4-pot EDIS sounds good to me and there's got to be a good few ponies waiting for proper fuelling & sparking on those lumps. Quote Link to comment Share on other sites More sharing options...
