poacher Posted June 18, 2007 Share Posted June 18, 2007 Hi Folks, thought I'd share this with you. Customers 300tdi with wobbly crankshaft pulley. Quote Link to comment Share on other sites More sharing options...
sadoldgit Posted June 18, 2007 Share Posted June 18, 2007 fill it with belzona and wrap a coke tin round it good luck, paul Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 19, 2007 Share Posted June 19, 2007 Was it wobbling because the bolt had come loose or was the pulley distorted? The first is common when people change cambelts and don't tighten up the bolt properly - the second I have come across once where the rubber distorted and the pulley ran skew. Quote Link to comment Share on other sites More sharing options...
poacher Posted June 19, 2007 Author Share Posted June 19, 2007 Bolt was fine - threaded ok & took 6 ft bar to get it off Pulley is obviously useless, blokes on about changing the engine Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 19, 2007 Share Posted June 19, 2007 I had a similar thing on a Pajero. Just the pulleys cost almost £300. Les. Quote Link to comment Share on other sites More sharing options...
