Les Henson Posted June 19, 2007 Share Posted June 19, 2007 Is anyone on here a domestic electrician that could give me some advice via pm please? Thanks Les. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted June 19, 2007 Share Posted June 19, 2007 Fire away ! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 19, 2007 Author Share Posted June 19, 2007 'Fire' is about right. Pm in a few minutes, thanks Lesmond. Les. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted June 19, 2007 Share Posted June 19, 2007 Les Henson :"Any sparkies use this website?" Just occasionally. :-)) Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted June 19, 2007 Share Posted June 19, 2007 Come on Les, let us all hear your question, may even cause a laugh! Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 19, 2007 Share Posted June 19, 2007 Les, i can get you pretty cheap stuff too should you need things. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 19, 2007 Share Posted June 19, 2007 Yep, c'mon Les, we could do with a grin Mo Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 19, 2007 Author Share Posted June 19, 2007 Well I had a slight accident when replacing an MCB in the mains box today. I had problems with the 15amp item tripping every time I used the MIG on a high power setting, so I decided to replace it with a 30amp one insted. £16 later and I turned off the mains, removed the old unit and fitted the new one. Befor I reconnected the power to the shed I thought I had best make sure everything was ok so far so I switched the mains back on. Unfortunately I had somehow caused an short to the earth plate and there was an almighty flash and bang, followed by the mains cutting off. I removed the MCB, checked it (looked ok), so I refitted it and this time turned the mains back on with a long bit of wood. Yet again a flash and loud bang and once again the mains went off After some help from Lesmond it turns out that the first short had left a carbon track on the MCB, so that's why it went bang the second time. So a trip to probably the last huge MCB in the whole of wiltshire, and this time £22 lighter I finally got it fixed and working. Some slight explosive damage to the earth plate though, and even more scared of electricity than I was before. Earth plate in the fuse box. The new 1st MCB on the right with a partially melted contact. Les. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 19, 2007 Share Posted June 19, 2007 I shall henceforth call you "Nigel" due to your new found electrical prowess Is anyone on here a domestic electrician that could give me some advice via pm please?Thanks Les. With hindsight? "Don't" Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted June 19, 2007 Share Posted June 19, 2007 And I thought the Part P Regs were a waste of time? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 19, 2007 Author Share Posted June 19, 2007 Well it's only one wire and two screws. It's not unreasonable to expect it to be easy-peasy. Less difficult than fitting a plug (unless you do the matches thing ) Les. Quote Link to comment Share on other sites More sharing options...
Guest MJG Posted June 19, 2007 Share Posted June 19, 2007 And I thought the Part P Regs were a waste of time? They are....to qualify that I mean they probably will/have done little to save lives but done a lot to line the pockets of thieving sponging electricians... present company excepted of course... This is why a lot of folks will find ways around the regs.... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 20, 2007 Share Posted June 20, 2007 Electrickery is best left to the wizards Mo Quote Link to comment Share on other sites More sharing options...
rtbarton Posted June 20, 2007 Share Posted June 20, 2007 ............. turned the mains back on with a long bit of wood. Les. I use my brother for that sort of thing Quote Link to comment Share on other sites More sharing options...
Les Brock Posted June 20, 2007 Share Posted June 20, 2007 They are....to qualify that I mean they probably will/have done little to save lives but done a lot to line the pockets of thieving sponging electricians... present company excepted of course... This is why a lot of folks will find ways around the regs.... I'll think you will find most Electricians did not want it...The NICEIC (other money grabbing B@surds are available) are doing very nicley though ! Quote Link to comment Share on other sites More sharing options...
Jon White Posted June 20, 2007 Share Posted June 20, 2007 This is why a lot of folks will find ways around the regs.... Correction - that is why alot of people chose to simply ignore the regs........ Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted June 20, 2007 Share Posted June 20, 2007 All part P has meant to me is very little where i work in an industrial environment anybody can do electrical work if they can blag a job. If electrcial work needs to be policed then a proper body should be set up like CORGI for the gas fitters. Quote Link to comment Share on other sites More sharing options...
Superpants Posted June 20, 2007 Share Posted June 20, 2007 With my slightly cynical hat on, NICEIC does seem to be heading more and more towards a CORGI type outfit- they seem to be nicely positioned to take on the mantle of being the approved body when the government eventually decides that us mortals aren't allowed to play with electricaltrickery at all in our own homes. I'd put money on part P being tightened further in the future to stop us doing practically anything. Maybe should re-train as an electrician, register and beat the rush now..... Looks like you let a good quantity of smoke go for your money Quote Link to comment Share on other sites More sharing options...
rtbarton Posted June 20, 2007 Share Posted June 20, 2007 Maybe should re-train as an electrician, register and beat the rush now..... You don't need to be an electrician. Joe Public can do his own work under part P, he just has to get it certified by a council jobsworth or qualified person. Quote Link to comment Share on other sites More sharing options...
Superpants Posted June 20, 2007 Share Posted June 20, 2007 You don't need to be an electrician. Joe Public can do his own work under part P, he just has to get it certified by a council jobsworth or qualified person. Not at the moment, But I'd put money on it changing at some point in the next 10 years...... Quote Link to comment Share on other sites More sharing options...
Guest MJG Posted June 20, 2007 Share Posted June 20, 2007 Also folks.... remember it's just a 'connection' thing. Even under the CORGI scheme as I understand it I can fit a gas fire/ boiler/hob/oven as long as the last bit of the job i.e. the conection to the supply is carried out by some monkey who knows how to solder a pipe.... Or yet again am I talking cobblers??? Quote Link to comment Share on other sites More sharing options...
Nigel H Posted June 21, 2007 Share Posted June 21, 2007 Or yet again am I talking cobblers??? I'm sure cobblers have their own regs. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted June 23, 2007 Share Posted June 23, 2007 They are....to qualify that I mean they probably will/have done little to save lives but done a lot to line the pockets of thieving sponging electricians... present company excepted of course... This is why a lot of folks will find ways around the regs.... The only electrical work I've done in my house is fixing the dodgy wiring done by the professional electriciansmonkeys that installed it in the first place As long as slapdash/incompetent cretins like this are included in the rosta of 'qualified electricians' part P has no value whatsoever. Gas is another matter entirely - no way I'm messing with something that could flatten half the street if I cock up* * although strangely I've no problem with working on my range rovers LPG system, which carries more propane than triggered the Piper Alpha disaster... Quote Link to comment Share on other sites More sharing options...
