Chris Davies Posted June 21, 2007 Share Posted June 21, 2007 I've got a smiths water temp guage that would have originally been used with a 2.25 engine, but I have a 2.5 NAD (12J) engine fitted does anybody know if the sender on the 2.5 is compatable with the temp guage or should I swap the sender for a 2.25 one - are the threads the same on 2.25 and 2.5 senders? Cheers Chris Quote Link to comment Share on other sites More sharing options...
Gareth Dickens Posted June 21, 2007 Share Posted June 21, 2007 I've got a smiths water temp guage that would have originally been used with a 2.25 engine, but I have a 2.5 NAD (12J) engine fitted does anybody know if the sender on the 2.5 is compatable with the temp guage or should I swap the sender for a 2.25 one - are the threads the same on 2.25 and 2.5 senders?Cheers Chris If the same gauge was used in both vehicles- the senders should be interchangeable. Otherwise if a new 2.25 sender doesn't fit, make it fit. Quote Link to comment Share on other sites More sharing options...
