vinny Posted June 21, 2007 Share Posted June 21, 2007 The LT77 in my 90 makes an awful crunch when selecting reverse. The rest of the gears arent bad, a little tight when changing when cold but I can live with that. Whats causing this to happen?? Even with the engine stopped selecting reverse still produces a crunch noise????? Any help with this much appreciated!!!! Vinny Quote Link to comment Share on other sites More sharing options...
Lars L Posted June 21, 2007 Share Posted June 21, 2007 Clutch that's not doing its job properly. Something in the hydraulics is my guess. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 21, 2007 Share Posted June 21, 2007 Drop the oil and see if there's bits of metal in it, otherwise as Lars says, check the clutch mechanism. Les. Quote Link to comment Share on other sites More sharing options...
Ivan Posted June 22, 2007 Share Posted June 22, 2007 Err I thought this was normal as my Discovery does it all the time. Ivan Quote Link to comment Share on other sites More sharing options...
vinny Posted June 22, 2007 Author Share Posted June 22, 2007 Ive drained the oil, checked the small filter and no bits in the oil. In the past few months ive fitted a new slave, master cylinder and reciently heavy duty clutch, pressure plate, clutch bearing and release arm. I think there must be someting worn in the box even with the engine off, handbrake on transfer box in neutral it will slip up and down the gears but try reverse with or without the clutch pressed and krunch..... Quote Link to comment Share on other sites More sharing options...
vinny Posted September 7, 2007 Author Share Posted September 7, 2007 Problem sorted. I replaced the pivot for the clutch arm/mechanisim Quote Link to comment Share on other sites More sharing options...
Gromit Posted September 9, 2007 Share Posted September 9, 2007 Interesting. Mine krunches all the time too. Thought it was a feature, not a bug. Quote Link to comment Share on other sites More sharing options...
