Brake pipe/fitting sizes
101nut
 Share
1972 2-door Range Rover needs some brake pipes made up. Since wombats around here only have 10mm fittings and don't recognise anything else exists I've got find them myself.
What sizes are the males/union nuts and bleed nipples on this vehicle. I know they're they're imperial and I suspect all pipe fittings are 3/8 UNF but can anyone confirm or deny please? As for the bleed nipples - I have no idea. I just know when I try to get one out, however much I smack it first it'll probably shear off unless I buy some in advance ... in which case they'll be easy ...
AndyG
 Share
