rekab69 Posted June 24, 2007 Share Posted June 24, 2007 Hi, I need a spare alarm key fob for my 1998 110 the numbers on the back are 3txb, will any lucas 3txb key fob do the job once I have re programed it or do I need one that opperates on a certain frequency...? cheers db Quote Link to comment Share on other sites More sharing options...
rob90 Posted June 24, 2007 Share Posted June 24, 2007 try here Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 24, 2007 Share Posted June 24, 2007 You need the right frequency but any you buy in the UK should be OK, there are 315mhz and 433mhz that I am aware of and possibly others but I think all UK ones are 433. Apart from a sticker on the back when they are new, there is no way I know of that you can tell the two frequencies apart (other than it not working!) The same fob does Discovery 300Tdi age, early Freelanders and most if not all Defenders, because they all use the same Lucas 10AS alarm ecu. You need a Testbook or similar, and to have both key fobs present, to program a new one to the ECU (any fobs that are not present will stop working so there is no need to worry about one if you have lost it!) Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 24, 2007 Share Posted June 24, 2007 try here That refurb kit is a bit of a con, you can buy the button kit from a dealer for less than that...! I think they are only a couple of quid. Quote Link to comment Share on other sites More sharing options...
rekab69 Posted June 24, 2007 Author Share Posted June 24, 2007 The frequency was the part I needed to know about, as there are loads on fleabay.... thanks for the replys guys... cheers db Quote Link to comment Share on other sites More sharing options...
landyash Posted June 24, 2007 Share Posted June 24, 2007 Hi db if its a 433 one you need,I have a brand new one??? Just send me email?? Thanks LA Quote Link to comment Share on other sites More sharing options...
rekab69 Posted June 29, 2007 Author Share Posted June 29, 2007 Hi db if its a 433 one you need,I have a brand new one???Just send me email?? Thanks LA Hi LA, Always the way, I went ahead and bought one on E bay... Thanks for your offer though.. Cheers Dave Quote Link to comment Share on other sites More sharing options...
