neil00001 Posted June 26, 2007 Share Posted June 26, 2007 Hi all, Fishing for some advice, opened up afont hub on my Disco 1 to tighten up the wheel bearing. Luckily I had put a container under it as about 100mm of oil came out. Is this normal??? Or is it just a case of a deal oil seal? As a temporary measure I have repacked grease into the back of the inner bearings and cleaned and repacked the outer bearings. Cheers, Neil 93 Discovery1 200Tdi Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted June 26, 2007 Share Posted June 26, 2007 I think there is an oil seal at the inner end of each driveshaft inside the axle. These quite often leak. It comes out of the end of the stub axle on 2 out of 4 corners on my disco. Instant gasket round the hub flanges keeps my wheels clean Stu. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 26, 2007 Share Posted June 26, 2007 As long as the oil seal doesn't leak the oil onto the brake disks, oil in the bearings is a good thing IMHO. They will definitely last longer. You may need to top up your swivels a bit as this oil will have come from there. My defender has oil in all its wheel bearings, or a mixture of oil and grease, and I have had no problems. At the back I deliberately destroyed the inner seals by whipping the halfshafts in and out a few times. Quote Link to comment Share on other sites More sharing options...
neil00001 Posted June 26, 2007 Author Share Posted June 26, 2007 Thanks folks, that put my mind at rest, another turn up for the books, my new springs and timingbelt kit arrived from the UK!!!!! Cheers, Neil Quote Link to comment Share on other sites More sharing options...
rejo Posted June 26, 2007 Share Posted June 26, 2007 Hi Neil Just out of curiosity where are you in Holland. Quote Link to comment Share on other sites More sharing options...
