goaty Posted July 1, 2007 Share Posted July 1, 2007 Hi all, On my defender 90 i currently have the pro comp 2in lift kit but want more articulation on the axles. Should i go for some tubular front shock lowering turrets with some dislocation cones or am i best sticking with what i have?? I have rear dislocation cones and am getting the rear shock lower top mounts, and them trailing and radius arms are one the list. Any advice would be great. many thanks Quote Link to comment Share on other sites More sharing options...
Escape Posted July 10, 2007 Share Posted July 10, 2007 Get your vehicle up on a ramp and see which is the limiting factor. I would guess your rear shocks bottom out before the front, so you're best off starting with longer rear dampers or lowered rear mounts. (Classic) Land Rovers tend to have a lot more articulation in the rear. One way to improve front articulating is to drill holes in the bushes between then radius arms and the axle, thus enabling more up and downward movement. The holes should be located straight above and below the bolt. Check out RTI photos for comparison. Quote Link to comment Share on other sites More sharing options...
nickm Posted July 11, 2007 Share Posted July 11, 2007 Get your vehicle up on a ramp and see which is the limiting factor. I would guess your rear shocks bottom out before the front, so you're best off starting with longer rear dampers or lowered rear mounts.(Classic) Land Rovers tend to have a lot more articulation in the rear. One way to improve front articulating is to drill holes in the bushes between then radius arms and the axle, thus enabling more up and downward movement. The holes should be located straight above and below the bolt. Check out RTI photos for comparison. sorry to change the subject but wot wheels n tyres are theses http://best4x4xfar.com/gallery/displayimag...=184&pos=42 Quote Link to comment Share on other sites More sharing options...
Escape Posted July 11, 2007 Share Posted July 11, 2007 sorry to change the subject but wot wheels n tyres are theseshttp://best4x4xfar.com/gallery/displayimag...=184&pos=42 Mickey Thompson Competition Claw 37x13x17 on Predator 17x8 rims with Staun internal beadlocks. Quote Link to comment Share on other sites More sharing options...
nickm Posted July 11, 2007 Share Posted July 11, 2007 Mickey Thompson Competition Claw 37x13x17 on Predator 17x8 rims with Staun internal beadlocks. ta Quote Link to comment Share on other sites More sharing options...
