90 Mellis Posted July 3, 2007 Share Posted July 3, 2007 Planning my lastest project (200tdi 90), Interested to know what body parts are interchangable between a 90/Series?! Will a Series Truck Cab or Hard top fit?? And also the two piece Front doors?? Quote Link to comment Share on other sites More sharing options...
western Posted July 3, 2007 Share Posted July 3, 2007 Doors will but use the 90 hinges & Series latch striker on the pillar, truck cab roof & back panel should be OK, hardtop not as 90 has a longer body/wheelbase. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 3, 2007 Share Posted July 3, 2007 Doors will but use the 90 hinges & Sreies latch striker on the pillar, truck cab roof & back panel should be OK, hardtop not as 90 has a longer body/wheelbase. Are you sure about roofs Ralph? I thought the defender had a taller screen and so you would have to change roof & screen to be both series or both defender. Also, although the 90/110 is longer wheelbase I believe all the bodywork is the same length overall as 109 CSW sides (sill,B&C pillar) are superseded to the 110 CSW part number and all the doors swap over. Quote Link to comment Share on other sites More sharing options...
muddy Posted July 3, 2007 Share Posted July 3, 2007 I thought the series truck cab roof was shallower and the winscreen is lower and the corners are square not curved as a 90/110 one is so any series roof panel will not fit a 90or 110? back panel off a truck cab should fit tho. Quote Link to comment Share on other sites More sharing options...
101sean Posted July 3, 2007 Share Posted July 3, 2007 Fridgefreezer is right, no series roofs will fit a 90/110 as the screens are completely different. Truck cab back panels are the same. Doors are all interchangeable but strikers and latches will differ. Quote Link to comment Share on other sites More sharing options...
steve b Posted July 4, 2007 Share Posted July 4, 2007 ......the hard tops from series will fit if you change the windscreen to S11/S111 as well. Most def. panelwork has series roots , lower tooling costs etc Cheers Steveb Quote Link to comment Share on other sites More sharing options...
western Posted July 4, 2007 Share Posted July 4, 2007 Are you sure about roofs Ralph? I thought the defender had a taller screen and so you would have to change roof & screen to be both series or both defender. Also, although the 90/110 is longer wheelbase I believe all the bodywork is the same length overall as 109 CSW sides (sill,B&C pillar) are superseded to the 110 CSW part number and all the doors swap over. DOH good spot, I was thinking about to many things at the same time. Quote Link to comment Share on other sites More sharing options...
