Troddenmasses Posted October 17, 2005 Share Posted October 17, 2005 I went for a little greenlaning fun yesterday, as the first (very small) test for my vehicle. I have a number of issues to look at, but the most pressing is that the steering wheel seems to be connected to the steering box with a long strip of rubber. I know that the 6 bolt power steering box was never particularly god, which is why they went back to the 4 bolt variety, but was it really THAT bad? 'Turbocharger' has had a look under the bonnet, whilst I take up the 3" play on the steering wheel, and tells me that the steering box needs adjusting, but can it really just be that, or do you think that it could be anything else. Has anybody here changed from the 6 bolt to the 4 bolt type steering box? If so, does it make much difference? Cheers. Quote Link to comment Share on other sites More sharing options...
landi41 Posted October 17, 2005 Share Posted October 17, 2005 I went for a little greenlaning fun yesterday, as the first (very small) test for my vehicle. I have a number of issues to look at, but the most pressing is that the steering wheel seems to be connected to the steering box with a long strip of rubber.I know that the 6 bolt power steering box was never particularly god, which is why they went back to the 4 bolt variety, but was it really THAT bad? 'Turbocharger' has had a look under the bonnet, whilst I take up the 3" play on the steering wheel, and tells me that the steering box needs adjusting, but can it really just be that, or do you think that it could be anything else. Has anybody here changed from the 6 bolt to the 4 bolt type steering box? If so, does it make much difference? Cheers. Can't answer that box replacement question but in what condition are the universals in your steering shaft? and yes i think you can adjust the box, there is a slotted screw on the top secured with a lock-nut....... The drop arm ball joint is also a place to look for play as well as all of the track rod ends.......... It helps to have an assistant and go thru things point by point.............. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted October 17, 2005 Share Posted October 17, 2005 I lay underneath while Keir waved the steering repeatedly. All 4 TREs and the panhard rod bushes have no movement and the column UJs are fine. I suggest tightening the steering box but other than that I can't see why it wanders SO horribly. It really is undriveable at the moment. Quote Link to comment Share on other sites More sharing options...
LR90 Posted October 17, 2005 Share Posted October 17, 2005 I lay underneath while Keir waved the steering repeatedly. All 4 TREs and the panhard rod bushes have no movement and the column UJs are fine. I suggest tightening the steering box but other than that I can't see why it wanders SO horribly. It really is undriveable at the moment. Tracking? Steering damper? (I'm working through the Disco so can give quite a big list if needed but haven't found the cause of my probs yet either) Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 18, 2005 Share Posted October 18, 2005 A small amount of slack in a PAS box translates to a HUGE amount at the wheel. Adjust it up, bleed it also, then check slacks gain, wheel bearing also worth looking at as they translate into "Vagueness" and may be camoded by the box on top ? Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted October 18, 2005 Share Posted October 18, 2005 Mine played up recently went tight on one lock then lack of feel/play the Power steering pump was on the way out. replaced it and normal service resumed Quote Link to comment Share on other sites More sharing options...
Troddenmasses Posted October 18, 2005 Author Share Posted October 18, 2005 Ok then, have tightened the screw on the top of the steering box. Unfortunately, I tested to see if the steering had play in it before I tightened the locking nut up, so now have PAS fluid all over my drive It is MUCH more driveable now, but makes something of a nasty sound whenever I move the steering wheel. Could this mean that it needs bleeding? If so, how do I go about that? I see a little nut/valve type arrangement next to the screw that I have just tightened up. Is it anything to do with that? Thanks. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 18, 2005 Share Posted October 18, 2005 Ok then, have tightened the screw on the top of the steering box. Unfortunately, I tested to see if the steering had play in it before I tightened the locking nut up, so now have PAS fluid all over my drive It is MUCH more driveable now, but makes something of a nasty sound whenever I move the steering wheel. Could this mean that it needs bleeding? If so, how do I go about that? I see a little nut/valve type arrangement next to the screw that I have just tightened up. Is it anything to do with that? Thanks. Groan is poss low PAS and air. Next to the nut and lock nut is what looks like say a caliper brake nipple....its the bleeds, run engine at tickover, losen niplle, admire even mopre fliud on chassis floor etc, nip up, make sure resivor is full before and after you start... Should do it Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted October 18, 2005 Share Posted October 18, 2005 Mine was sounding like the relief valve chattering. Quote Link to comment Share on other sites More sharing options...
Troddenmasses Posted October 18, 2005 Author Share Posted October 18, 2005 Groan is poss low PAS and air.Next to the nut and lock nut is what looks like say a caliper brake nipple....its the bleeds, run engine at tickover, losen niplle, admire even mopre fliud on chassis floor etc, nip up, make sure resivor is full before and after you start... Should do it Nige Thanks for that - I will try it. Is it just normal PAS fluid in there, or something different? Quote Link to comment Share on other sites More sharing options...
white90 Posted October 18, 2005 Share Posted October 18, 2005 Thanks for that - I will try it. Is it just normal PAS fluid in there, or something different? Just ATF Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted October 18, 2005 Share Posted October 18, 2005 ATF = PAS = anything thin, red and runny (but not Ribena). As LR90 suggested, might also be worth a look to see if you've bent the trackrod yet Quote Link to comment Share on other sites More sharing options...
Troddenmasses Posted October 19, 2005 Author Share Posted October 19, 2005 ATF = PAS = anything thin, red and runny (but not Ribena). As LR90 suggested, might also be worth a look to see if you've bent the trackrod yet I'm pretty sure that I haven't bent anything underneath yet, but it could very easily be the steering damper. I tightened up the box yesterday, and it is MUCH MUCH better. Now it just makes a bit of a noise when I turn the steering wheel. Am going to bleed it today as soon as I have some more Ribena ATF. Thanks for all the help. Quote Link to comment Share on other sites More sharing options...
Ben Reedy Posted October 25, 2005 Share Posted October 25, 2005 I'm pretty sure that I haven't bent anything underneath yet, but it could very easily be the steering damper. I tightened up the box yesterday, and it is MUCH MUCH better. Now it just makes a bit of a noise when I turn the steering wheel. Am going to bleed it today as soon as I have some more Ribena ATF. Thanks for all the help. *idle thought mode on* I wonder if MTF 94 would make the box smoother or last longer? *idle thought mode off* Quote Link to comment Share on other sites More sharing options...
jules Posted October 26, 2005 Share Posted October 26, 2005 Use the stuff thats speced for the Disco 2 as it is more temp resistant so you will not suffer steering fad when working hard with out upgrading the cooler/fitting one Quote Link to comment Share on other sites More sharing options...
